Results 1 to 11 of 11
    Aug 2019
    state of confusion
    Default Do the 19 f3t and the 19 f3 limited have the same exact rear sprocket.
    Does anyone really know for sure, just looking for the truth. Might make the difference between buying the t or the limited. Road a f3- t a few weeks ago and this thing had told of balls , very snappy. Just ordered up a limited today , just wondering if I made the wrong decision.
    Mar 2013
    Same size sprocket on the T and L
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    Good choice. Lots of other good things come with the limited . . floor boards, heated grips, auto leveling suspension, rear trunk . . . . really happy with mine
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Aug 2019
    state of confusion
    Are you able to manually put air in on the limited like you can on the t rear suspension.
    Aug 2018
    Florida
    Quote Originally Posted by snowdevil View Post
    Nope . . . all automatic
    2019 F3 Limited
    formerly pman2011 YIRYDE's Avatar
    Sep 2012
    Northern Virginia
    Quote Originally Posted by PW2013STL View Post
    This is why I brought an 2018 T, Brp stopped putting the larger 89T sprocket on for the 2019 F3T's. I drove an 2018T and liked it so much I decided to trade my RT for one.
    [B]
    2018 Intense Red F3T (See About Me under My Profile for mods)
    2010 Timeless Black RT-622 Trailer
    2014 Timeless Black RTS-SE6, 34,300 Miles, traded May 2019
    2011 Timeless Black RTS-SE5, 15,180 Miles, traded April 2014
    Mar 2017
    All 2019 F3's have a 79 tooth sprocket on the rear excpt the "S". {corrected}
    https://www.partshark.com/oemparts/a...ve-system-rear
    Aug 2019
    state of confusion
    Quote Originally Posted by Rattlebars View Post
    All 2019 F3's have a 79 tooth sprocket on the rear.
    So can u change out the 79 tooth for the 89 tooth, or everything will be off on u , speedo, speed sensors . Theoretically should be no problems except ecm programming
    Nope, the ECU gets all upset!
    I don't think anybody's managed to do a rear pulley swap to the other size successfully.... at least not yet!
    Houston
    Not true. The F3S still comes with the larger 89 tooth sprocket. Base, T and ltd come with the small sprocket.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    True...but if you were to UPGRADE to the 89 tooth sprocket and belt on the 2019 F-3 base, touring and limited..and Upgrade the BUDS software..to reflect the change it should work...it won't work on the RT...people have tried...but it should work on the F-3 series...has anybody tried to do the upgrade on an F-3 series bike?...that's the question.
