Results 1 to 5 of 5
Thread: F3T - rear shox
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default Solved: F3T - rear shox
    SOrry guys, its solved in meantime. It should work the same as on F3s.. so lets see..
    Hi Guys,
    as i am not an owner of F3T, i would like to ask you if it is possible to change the rear shock?
    My friend is bit heavy and we need to go for new front but also back would be great.. I just dont know how it is with that pillow back there....
    thanx for tips
    Martin
    Nov 2012
    North Las Vegas, NV
    Should just be two bolts. The airbag is separate.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Quote Originally Posted by Martin Slovakia View Post
    Hi Guys,
    thanx for tips
    Martin
    I'm pretty sure I read that a member here ( Peteoz ) changed His shocksa to " Wilber brand ) and is very happy with them …. I think He has said He's on the LARGE side …...PM Him …. Mike
    Mar 2015
    Default thanx
    thank you guys.
    Martin
    Harrington, Australia
    thank you guys.
    Martin
    Martin, I know you said it was “solved in the meantime”, but if you are going with Wilbers, make sure the supplier understands it’s an F3T not just an F3. My supplier sent me F3S shocks, thinking all F3’s are the same, and they have an incorrect bottom fitting for the F3T/L.
    HeliBars Handlebars
    Kenda Kanine rear.
