Page 4 of 4 FirstFirst 1234
Results 76 to 91 of 91
  1. #76
    Aug 2013
    So youre using a jack on a lift, makes sense.
    Just messin' w/ya.
  2. #77
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Quote Originally Posted by SNOOPY View Post
    Just messin' w/ya.
    Really only need it if you want to lift the wheels,
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
  3. #78
    Oct 2007
    Johnson City TN
    Default This is other reason
    I use jack stands,remove wheels to do a full service. They wanted $500.00 to do a 10 hr service. This lift has paid for its self. This lift is stable even with this heavy sxs.
  4. #79
    Mar 2012
    NJ
    OK Coz, Give us the long term 1+year update. How's this lift working out for you?
  5. #80
    Very Active Member coz's Avatar
    May 2011
    cincinnati, ohio
    Default it's great
    i raise it halfway to swap exhaust, while sitting, for example. i put the bazooka pipe back on fri. to ride on saturday. the new pipe ( elbow only ) goes to powdercoater this week. then i'll swap it back, while sitting. i'm too old and crickety too be crawling around on the concrete floor. the lift could not have worked out better. you should get one !
    it was fun while it lasted.
  6. #81
    Mar 2012
    NJ
    How mobile is it with nothing on it? Can it be moved at all with nothing on it to do other things in the garage?
    Sent from my Venue 8 3830 using Tapatalk
  7. #82
    May 2011
    cincinnati, ohio
    Default easy
    it's actually very easy to roll around, for it's size and weight.
  8. #83
    Jun 2013
    Milford, Ohio
    I think a one year upgrade could be diamond plate on the front wheel extensions. You can buy the thin stuff at lowes pretty cheap.
  9. #84
    May 2011
    cincinnati, ohio
    Default great idea
    adding some bling to the lift. i'm going to look into that. thanks.
  10. #85
    May 2011
    cincinnati, ohio
    Default many uses
    also makes a nice furniture painting lift, minimizing bending over.
  11. #86
    Mar 2012
    NJ
    Hahaha...
  12. #87
    Mar 2012
    NJ
    I still really need to do this...
  13. #88
    Jun 2014
    Wickes, Arkansas
    Default Rear Decal
    Is that a Masonic Decal on the back of that bike?
    Quote Originally Posted by bmwlarry View Post
    Here is a pic of my setup.
  14. #89
    Mar 2012
    NJ
  15. #90
    Sep 2014
    mathias,wv
    Default Harbor freight Lift
    They went on sale today for $299. with coupon!!
  16. #91
    May 2011
    cincinnati, ohio
    Default good deal
    Quote Originally Posted by tip View Post
    that's a good deal. i paid 2 bills for mine,used, in very good condition.
