Results 1 to 6 of 6
    Apr 2014
    Claresholm, Alberta
    Default Is there already a Trailer wire harness connection?
    On a 2014 RTS, I noticed there is a fuse that says trailer; does anyone know if the wiring for the trailer connection is in the bike somewhere?
    Last edited by Peter Aawen; 05-24-2023 at 11:14 PM. Reason: Expanded title to briefly ask the question... ;-)
    Mar 2013
    Maumelle, AR
    Unless the previous owner installed a wiring harness, you don't have one. It's an optional item.
    2020 RT Limited , Chalk
    Jan 2019
    Hunter Valley NSW Australia
    Under the seat there is a panel under which there is a connector that is meant to be "decoupled" to allow a trailer harness to be inserted between the two connectors on the '17 RTL, it may exist on the RTS. The picture below shows the approx location of the cover under the seat on another model
    One of the pins is an Active from the battery, the rest are the required circuits for indicator/brake/tail lights. I used one of these from Amazon for the plug wiring.
    2017 RTL
    2017 RTL , White
    Apr 2014
    Claresholm, Alberta
    Quote Originally Posted by askitee View Post
    Thanks, I have a look at that.
    Jan 2021
    Descanso, CA
    One of our sponsors offers this plug-and-play harness https://www.lamonstergarage.com/trai...019-lamonster/
    If you have a 4-wire trailer plug you will also need https://www.lamonstergarage.com/trai...019-lamonster/
    Otherwise you will have to make your own 5-to-x harness.
    Jan 2019
    Quote Originally Posted by rideaway View Post
    I also made the harness - our trailer connectors use 7 pins. I bought the required deutsche fittings from AliExpress to maintain the waterproof connections - it looks the part and has been very reliable.
    2017 RTL
    2017 RTL , White
