Results 1 to 25 of 44
    Jan 2019
    Alcamo- Sicilia -italia
    Default Who makes a wide rear sprocket?
    Who is making the rear sprocket as wide as the rim as in the picture?
    Mar 2015
    NEW JERSEY
    Quote Originally Posted by torx164 View Post
    That looks like the standard sprocket. I have a 2015 f3s and it is that big. I need to find that fender!!!
    Default Curious...🤔
    Do you mean as large as the tire in circumference..? the F3 did come with a much larger rear sproket to where it looks like if you got a flat you could ryde home on it... but it is standard...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jan 2019
    That rear sprocket is as wide as the rim, original is not so .....................
    Oct 2014
    Fort Mill, SC
    I'm not seeing that as a wide sprocket either. Looks standard to me. Why would you want a sprocket as wide as that rim?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Mar 2015
    NEW JERSEY
    I think makes it appear so much larger is all the stuff that wraps the wheel is gone. You can actually see all the components back there.
    Jan 2019
    wide rear sprocket to shorten ratios and have more acceleration .....................
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    I think you mean a larger "diameter" sprocket. That's the standard F3/F3S sprocket for North American models. I believe in Europe you have the smaller sprocket like the one on the F3 limited models here in N.A.
    So to answer you question that's a BRP sprocket.
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Jan 2019
    I just went down to the garage to look at my F3 S 2017 and the rear sprocket is much smaller than the one in the picture.
    Jan 2019
    So from you in NordAmerica F3 S comes out with the rear sprocket as wide as the rear wheel (15 ") ?.
    Can't Delete so Left Blank on Purpose
    Jan 2019
    The rays are not identical, mine every ray is divided into two.
    Apr 2012
    Yes, here's mine...
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    Jan 2019
    However, to see if they are identical is very easy, just count the number of teeth in the pinion, how many teeth do you have?
    NorCal - Northbay
    North American F3/F3S's from 15-17 got an 89tooth sprocket. The non-F3's got a 79tooth. Newer F3T/Limited (2018 & up I believe) get the 79tooth instead of the 89tooth....
    Chuck
    NorCal - Northbay
    Quote Originally Posted by WIDOWSSON View Post
    That is the Bobber Kit available from BRP:
    https://can-am.brp.com/on-road/shop/...r-f3-f3-s.html
    Chuck
    Aug 2013
    Northern California
    Actually that is the stock sprocket for the 2016 F3T and Limited as well. In 17 when they added that thing on the back of the F3L they put an RT sprocket on the back. Really took a lot of performance out of the machine. I am not sure if the T still has the larger sprocket or not, but it did in 17. Shame too as it really causes the nanny to wake up way to early and often!
    Houston
    F3T still gets the larger sprocket. Just the Ltd and base model get the smaller one.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jan 2019
    Today I had time to count the teeth of my rear sprocket, I am 79, so what I thought is true! my spyder is a daytona ......
    Jan 2019
    Can anyone tell me how to order the 89 tooth sprocket and if it needs a new belt for assembly?
    From cheapcycleparts.com part# 705502016 79 teeth @ $329.99
    part# 705502187 89 teeth @ $449.99 quite a jump for 10 teeth...
    ​2012 RS sm5
    Feb 2018
    NorEastern, Washington
    Yes, you will need a new belt. The belt you have now gets tight on the smaller sprocket, won't even come close to fitting the larger sprocket.
    2017 F3T - w/large sprocket.
    Regards,
    Don
    2017 F3T , Triple Black
    Apr 2017
    North Central Florida
    You need to consider this move carefully.
    Yes it probably will need a different belt......and belts are VERY expensive.
    IF.....you change the final drive ratio that much, the "nanny" might not like the rear wheel turning at a different speed than it expects.
    It also might throw the speedometer off.
    Of course, your gas mileage will go down.
    They are different belts 705501304 , and 705502157 both @ $309.99
    ​2012 RS sm5
    Houston
    Nanny will go into limp mode if you change sprocket and belt without reprogramming the ECU.
