Results 1 to 25 of 29
    Member Williebbaker's Avatar
    Oct 2013
    North Little Rock AR.
    Default My $35 version of "magic mirrors"
    After I had been taking my mirrors on and off several times over the years for various MODS on my 2010 RT.
    My clips broke here on the retainer portion of the top Clip. See the piece from the broken clip?
    One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on (magic mirrors). I thought I might give it a try. So here is what I came up with;
    The parts I used were:
    6 each -Magnets from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium
    6 each Steel Washers
    12 each Countersunk wood screws
    1 ¼ inch long metric screws
    First of all instead of the washers being cut down to fit inside the clip socket, I made it so the washers would fit over the clip while it is still in the socket while using the same screw holes but longer screws. You will have to remove the clip so you can pick up the holes. See pictures below.
    Once the holes are picked up they should be counter sunk (the screws must not protrude above the surface of the washer).
    Now proceed to do the rest of the washers. Here’s how mine looked when I finished.
    Now let’s prepare the clips, first I had to modify the good top clip to match the broken one.
    To be continued on my next post. See you next time
    [IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image010.jpg[/IMG][IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image012.jpg[/IMG]
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    looking forward to the next installment......
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Oct 2013
    Default My version of "magic mirrors"
    Next trim the tab on the bottom two clips and then use afile so that the washer will sit flush and remove the metal retaining clips.
    Now let’s install the plastic clip and the metal washer,note the slight “apparent” misalignment (it is necessary) for the center holeis the focal point not the outside perimeter.
    Next let’s preparethe bike side, first the magnet, screw and washer assembly is shown below:
    More on the next post only because I don't know how to do it all at once. Sooooo see you next time!
    Dec 2015
    Oakley Utah
    Where is the thread with the previous steps? This starts with 'next ...'
    2014 RTL Platinum
    Oct 2013
    Default My Version of "Magic mirrors" part three
    Remove the existing stud pin screws and replace them withthe magnet screw and washer assembly see picture:
    By loosening the screw that holding the Tupper ware as shownbelow, this will allow for the Tupper ware slight movement to accommodate thespacer washer for the magnet:
    After all the magnet assemblies are installed reattach themirror assemblies.
    Aline the screw heads in the hole of the washers with aslight push and BAM! You have your very own set of “SNAPP MIRRORS”
    I hope this helps someone outthere save some money and time !
    Thanks for your time!
    Oct 2013
    Default My version of magic mirrors part 1
    Sorry for the confusion but I will add it now.
    [IMG]file:///C:/Users/WILLIE~1/AppData/Local/Temp/msohtmlclip1/01/clip_image002.jpg[/IMG]
    One day as I was passing by my RT, I bumped into my mirror and the darn thing nearly fell off. I was furious at first, but then I remembered reading about using magnets to hold the mirrors on. I thought I might give it a try. So here is what I came up with;
    6 each -Magnets – from “eBay” - Round Countersunk Ring Magnets 25 x 10mm Hole 6mm Rare Earth Neodymium-( 350916709551 )
    pic 4.jpgNow proceed to do the rest of the washers. Here’s how mine looked when I finished.
    Next trim the tab on the bottom two clips and then use a file so that the washer will sit flush:
    Whichever way you look at it or whatever order you might get it in, it looks like you've made a pretty good start on your own version of these Willie, Good Stuff! Well Done!
    Jul 2010
    Las Vegas, NV
    Default Clever
    Nice!
    Joe Meyer
    Jul 2016
    Kamloops B.C.
    I thank you for all the work you put into this. I have a question. in the parts list you said 6 steel washers, but it there one for each plastic "clip" and 2 on each magnet?? so, shouldn't that be 18 washers, or am I missing something?
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nov 2015
    Myerstown, Pennsylvania
    Quote Originally Posted by bcer960 View Post
    Ray
    Good point! I was wondering that too. They look like brass washers. How about the sizes on the washers too please?
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Oct 2013
    Default answer to the washer question
    Thank you for your interest in my post. Now to answer the washer question. you will only need 6 washers ( 3 for each side ). the part number for the (steel) washers is 03830 and I got them from LOWES. You have to make sure that they are made of magnetic material.
    Oct 2013
    the two washers that are on the magnets are PN " AN416 " washers and they are smaller and are only used for spacing.
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by Williebbaker View Post
    Thanks for giving the part numbers, but i am a bit confused on there only being 6 washers....
    You put the washers on the mirror side, and in the post i quoted, you are saying put the washers under the magnets. I was hoping to do this this weekend, so any clarification would be much appreciated.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Jul 2016
    Kamloops B.C.
    OK, sorry, we were writing at the same time....
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Very Active Member wmh9680's Avatar
    Nov 2015
    Tinley Park, Il
    I like this, I think I'm gonna try it
    2014 RT Limited Matte Silver, Belt Guard, RT Dash Mount, Show Chrome Can-Am Spyder RT Passenger Arm Rest, Show Chrome Full Size Brake Pedal,Best shop manual, Spyder keycover with hole, Utopia drivers backrest, Showchrome trailor hitch, ShowChrome Acc Trailer Acc Rack, 2014 CA Spyder RT-RTS Master Collection-HDSv5, Airhawk Cushion, Spyderpops bumpskid, Ipod cable, Led lights, Driver Hiway pegs, Shorty Antenna, Pin Striping, ECU flash, TriAx adjustible handlebars,
    Will it ever stop--NO
    Jul 2016
    Kamloops B.C.
    I have had them on for a year. They work great. The only thing I suggest is keeping the top clip on the mirror. This hook is only used to "hang" the mirror off, and doesn't take any force putting the mirror on and off.
    Last year when I first used this system, I was on a long trip, and hit a pot hole, and the mirror came off. Now, I had a tether, so it just dropped, but it actually did it a couple times on the trip. I put the top clip back on the mirror, and have not had another issue.
    Ray
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nov 2015
    Tinley Park, Il
    What size were the washers, I tried looking the number up and it did not work, Thanks, Mike
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by wmh9680 View Post
    I'm pretty sure they were 1" fender washers. but not 100%
    ya, just reviewing, and that's what they are
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nov 2015
    Tinley Park, Il
    Thanks, Mike
    Nov 2015
    Tinley Park, Il
    Thanks, Mike
    I just ordered the magnets, they come from overseas, can't wait
    Nov 2015
    Tinley Park, Il
    Just received the magnets and 1 was cracked, may try to JB Weld it before separating it from the others. I mistakenly showed them to my friend and when he tried to separate one he broke it into 3 pieces.
    Jul 2016
    Kamloops B.C.
    The problem is, when a magnet is broken, the magnet field drastically changes. If it broke into 3, you now have 3 magnetic fields, and I do not if it will hold.......
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nov 2015
    Tinley Park, Il
    Thanks, I guess that one is trash, what about the one that is cracked on one side
    Jul 2016
    Kamloops B.C.
    look closely, it is probably cracked through. If so, it is also "new" magnetic field. It MAY work, but I wouldn't trust it, as I think it will break at some point.
    2017 RT-S
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    Glo-riders
    Front Grills
    Third Brake light
    Larson Scanner
    Nov 2015
    Tinley Park, Il
    Well, I have proceeded to break 3 of the 4 magnets, guess I dn have the magic touch, you gotta keep a close eye on these little suckers, they wanna jump around and play bumper cars a lot
Tags for this Thread
