Results 1 to 20 of 20
    Jul 2017
    Woodbine, Iowa
    Default Replace Spark Plugs in 2015 RT
    I cannot believe there is no videos in changing spark plugs in a 2015 RT Spyder. I am going to be doing it in a short time. I thought there would be some videos in how to get to them. I guess I will find out when I do it.
    Asphalt Grey
    Lamonster RT phone mount
    Sena SMH-10
    Lamonster Belt Tensioner w/ larger roller
    Spyderpops Missing Belt Guard
    Garmin's GPS
    Jul 2015
    Saint Michael, MN
    I have a spark plug change coming up on my 2015 RT soon. I too, looked for a video and was surprised that I could not find one. Let us know how it goes!
    Gunner
    Default Well....
    Might just be that the spark plugs today last a long time. Not an item changed that often so no videos on changing them. Also depends on how far your search went as there are other places such as you tube, Facebook etc that may have some. Shop manual always a good go to book....
    Sep 2009
    La Valle, WI
    It is a big job. The front fairing, frunk and air box have to come off. Sold my Rt before that time came. But likely will be doing it on my F3L.
    2018 F3 Limited , Oxford Blue
    Jun 2010
    Las Vegas
    Quote Originally Posted by JP58 View Post
    I don’t remember needing to take the front trunk off.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    May 2013
    Edmonton Alberta, Canada
    You don't have too but it does make it easier to remove the airbox...
    2014 RT-Ltd , Cognac
    Mar 2013
    Quote Originally Posted by Purple Guy View Post
    I agree. Last time tried to do it leaving the frunk on, but struggled with it and then I took it off. Made the whole job easier.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    May 2017
    Perry Hall, Md
    Quote Originally Posted by gerald37 View Post
    You mean something like this? Its for a 2011 but its something. "Search" is your friend
    https://m.youtube.com/watch?v=EQTNMYSTdIc&t=63s
    2011 RT , Yes Blue
    Quote Originally Posted by Docster View Post
    Video of a 2011 will do him no good. Nice try though!
    May 2017
    Perry Hall, Md
    2011 RT , Yes Blue
    Jul 2017
    Woodbine, Iowa
    It has to be a 2014 or newer. It is the three cylinder 1300 engine.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Jul 2017
    Woodbine, Iowa
    How many miles do most ride before changing plus?
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    BRP says change them at the 28k service with the trans filter on the SE6. But some are going much further. It is difficult to know if they really need changing at 28k as Iridium spark plugs do not show wear or visible deterioration as do conventional spark plugs.
    Active Member pjweimer's Avatar
    Aug 2012
    Pataskala, OH
    Default 44,000+ miles...
    ...and still have original sparkers in our 2014 RT Ltd. At 28,000 miles I did all the noted maintenance tasks, but the spark plugs. Bought them but as the bike starts easily, pulls with power and no detectable hesitations or misfires thought I'd avoid the task until I noticed performance issues that would indicate the need.
    2014 RT Ltd Silver Platinum Satin, Ultimate Seat, rider and passenger backrests, Vented Windshield, Adjustable Side Wind Deflectors, Chrome Tri Axis Handlebars with GPS Support, Trailer Hitch Kit, RT-622 Trailer Silver Platinum Satin, Stebil Air Horn, BajaRon's Sway Bar, Spyderpops Bumpskid bike and Trailer, R/T grills, SpyderSisters Front Trunk Pockets, SpyderSisters Sunshade, Spyderflaps Mud Flap, many TricLED lights
    2014 Limited , Silver Playinum Satin
    Jul 2017
    Woodbine, Iowa
    Quote Originally Posted by pjweimer View Post
    I have 27,000 miles on mind. I am doing the oil change and transmission filter but mind runs so good I may skip the plugs for now. I have purchased them and was planning to do them.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Houston
    Don't forget fuel and air filters that are also due.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jul 2017
    Woodbine, Iowa
    I have already changed both fuel filter and replace the air filter with a K&N air filter.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
    Nov 2012
    North Las Vegas, NV
    Well, you could make a video.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Sep 2016
    clark county indiana
    Default hahahahhaa agreed !
    and make it a good one , lots of information and the lighting has too be pretty good also !
    Jul 2017
    Woodbine, Iowa
    When I do change the plugs I will try to make a good video. So it won't be to long I will start after removing the Tupperware and I will show removing the air box which I understand has to be done. Some say the frunk has to be removed and others say it does not. I will try without but it is no real job to remove with both sides of Tupperware off. I have had mind off one time when I replaced the DESS module. I have done most all the service on mind. Oil change with the Transmission filter, gas filter, K&N air filter and brakes bleed all that is left is Spark Plugs. I don't know for sure when I will do them but will try to post a video when I do.
    Asphalt Grey
    Sena SMH-10
    Garmin's GPS
