Page 1 of 5 12345 LastLast
Results 1 to 25 of 117
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    Default Peacekeeper6 Mod Thread
    I will attempt to document all of my modifications on our 2018 Spyder RT Limited, complete with difficulty level from a scale of 1-4 (1 being the easiest) and some tips that have helped me during installation.
    1) Trunk Mounted Double Flag Holder Set
    Difficulty Level - 1
    Tips - This was probably THE easiest mod I’ve ever done.
    Notes: I really like this mod, because I thoroughly believe that every biker
    should be patriotic and fly the Stars and Stripes. Since I served with
    the 101st Airborne Division (Air Assault) out of Ft. Campbell, KY, I’ve
    decided to also fly the Screaming Eagle. I’m both proud and honored to
    fly these colors on our bike.
    2) Lamonster Magic Mirrors
    Tips - Do NOT be afraid to knock the living crap out of your original mirrors.
    Also, these magnets are STRONG. Do NOT let them hit each other
    because the possibility of breaking them is very high.
    Notes: This is A MUST mod. Anytime you perform an oil change, light
    upgrade, etc, you WILL have to remove body panels, and the side
    view mirrors are the first to be removed. Also, these magnets
    significantly reduce vibrations and improves visibility. If you can
    only afford one mod, make sure this is the one.
    3) Next Gen LED Bumpskid
    Difficulty Level - 2
    Tips - Jack up the bike to provide some much-needed room. Use some
    C-clamps to immobilize the front of the bumpskid for accurate hole
    placements. Use SHARP drill bits, especially when drilling through
    the metal frame for the rear bolts. BE CAREFUL you don’t hit any cooling
    system components while drilling, so TAKE YOUR TIME.
    Notes: While this isn’t a necessary mod, I feel that it’ll save body panels
    in case I accidentally hit or run over objects. This was my first LED
    component, and I was extremely impressed with the quality of its
    light output. It has inspired me to upgrade my stock headlights and
    fog lights.
    4) Lamonster RT Spyder Cuff with Lamonster Approved Phone Holder
    Tips - Use the “rubber band” for a more secure install. I installed it
    on the right side because (1) I’m right handed, and (2) I feel that the
    left side of the handlebar already has enough buttons and levers.
    Notes: There is a reason why this is one of the most expensive cup/phone
    holders in the market. The quality is second-to-none. In addition, this
    was my first RAM mount, and didn’t realize how versatile and fully
    customizable it makes your bike. This Lamonster product is very
    well-made, and gives me confidence in purchasing other items from
    them in the future.
    5) Spyclops II LED Light
    Tips - Measure the LED strip and cut it at the indicated line. Power can be
    tapped on either side, so think about how you’re going to place it under the lip
    of the front hood. Ensure it clears the front of the hood when opening and
    and closing it.
    Notes: The bumpskid LED caused me to purchase this item. I thought about
    getting the ones that install on the A-arms, but I felt that that it would be over
    the top and didn’t like the way it looks as compared to the Spyclops. Plus,
    it looks cool, lol.
    6) Lamonster Ultra Bright LED Headlights
    Tips - I didn’t have a sharp knife or a proper bit for my Dremel, so I drilled a
    a hole ¼ inch from the edge with a bit that was the same width of the wire.
    Then, I used a pair of tin-snips to cut the rest of the plastic off. Quick and easy.
    Install the controller box OUTSIDE the cap because there’s no room inside. Use
    strong Velcro to secure it AT THE BOTTOM half of the cap where it curves downward.
    Notes: This mod is not only aesthetically pleasing, but it provides an added
    safety feature that cannot be stressed enough. I haven’t tested it out at night
    yet, but I’m quite sure it’s a definite improvement over stock. I like the fact that
    it doesn’t have a fan that can fail, which is probably the reason why it’s more
    expensive than other LED headlights. You get what you pay for, right ??
    7) Lamonster Ultra Bright LED Fog Lights
    Difficulty Level - 3
    Tips - Start with the right side first to familiarize yourself in this bitch of a project.
    Use a stubby flathead screwdriver to pop off the cap. It’s a straight install from
    here on out. The LEFT side, however, is where it gets interesting. Popping
    the cap is probably the easiest thing here. Again, unless you have dainty-
    sized hands of a 5th grader, you’re gunna be cussing yourself and the BRP
    engineers to no end. I must’ve spent about 2 hours trying all different ways to
    install the cap back with no success. I decided to leave it off because I came
    so, SO close to throwing the cap 98 mph out of my garage and onto the street.
    I’ve decided to keep the cap and will reinstall it when I take the frunk off in the
    future should I decide to upgrade to the Baja Ron Swaybars. If ANYBODY has
    a tip in reinstalling this cap, please let me know.
    Notes: This mod really wasn't THAT necessary, but it really bothered me when
    the fogs were turned on, and it was the only yellow light shining through
    a sea of white LEDs. It also bothered me that the black plastic cap was kicking
    my ass, but I'm sure it'll find its rightful place once I take the frunk off. Oh well,
    sometimes you win, and sometimes you lose.
    8) High Mount Brake/Run/Turn Taillights with Plug-n-Play Harness
    Difficulty Level - 2.5
    Tips - Measure twice (thrice, quadruple), drill once. Once you get over the fact
    you’re gunna be drilling a hole in your $25k bike, the rest of the install is pretty
    easy. Tons of parts to take off and reassemble, but it’s pretty fun because I feel
    like our Spyder is like LEGO for adults, LOL.
    Notes: Really, BRP should have designed something similar from the factory.
    This mod is one of my favorites because, as stated above, it was fun taking
    apart the rear end of the bike for the first time and putting it back together
    WITHOUT any issues. No tools were thrown from my garage !! Plus, the level
    of the lights is just right for the vehicles in the back, a DEFINITE safety
    feature. The Lamonster wiring harness made this install quick, easy and painless,
    so if you absolutely HATE wiring, the added price is worth it.
    9) Diamond R Passenger WEB Armrest
    Difficulty Level - 1.5
    Tips - Prior to removing the seat, put a piece of cloth on top of the dreaded Black
    Hole in the back to prevent accidentally dropping a nut or bolt into it and never
    seeing it again.
    Note: It was a toss-up between these armrests and the BRP ones. I like these a
    touch better because it's longer, which offers more comfort. I spoke to the owner
    of Diamond R when I was ordering it, and he was REALLY nice. The armrest and
    baseplate are robust, and the chrome pieces adds some class to our bike.
    Disclaimer: If you are wondering about my mechanical skills, I can safely assure you
    that I am NOT a mechanic by trade. I own a variety of cars/trucks, and am able to do
    simple DIY projects like oil and oil/air/cabin/fuel filter changes. I own a 1/2-ton Silverado, and have
    replaced the radiator, alternator and in-tank fuel pump. I also own a 3-Series BMW
    and have replaced window regulators (4 times !!), radiator (once), thermostat/water pump/
    expansion tank (twice), brake pads/rotors (twice), in-tank fuel pump (twice). My BMW,
    while it's been a GREAT car to drive, is NOTORIOUS for weak window regulators and cooling
    system. It has given me a good reason to learn to DIY many projects and have saved
    time and money by doing the jobs myself.
    Also, I'd like to thank the many Spyder DIYers who have documented their work on YouTube.
    Without your help and guidance, owners like me would have a very difficult time in many
    of our mods and DIY projects.
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Mar 2015
    forrest above Reno, Nv
    Nice write-up Lou. Skiing this week????
    2014 RTS , Circuit Yellow
    Sep 2019
    Reno, NV
    Quote Originally Posted by Lew L View Post
    Thanks Lew.
    My grandson is going to spend the weekend with us. Plus, my season pass has blackout dates this weekend.
    So to answer your question, no I'm not going skiing. I have a few Fridays off coming up, and will text you when I'll be going up to Rose.
    Dang, wish I was retired....
    2002 BMW 325i - his
    Active Member Airborne's Avatar
    May 2019
    Tasmania, Ausralia
    Where do you get the time to work!
    Sep 2019
    Reno, NV
    Quote Originally Posted by Airborne View Post
    I work Monday to Thursday. These mods were installed in the last 2 months or so during the weekends. They're really not THAT time-consuming, and I don't use any powered screwdrivers when taking off or placing back the tupperware. I find it very therapeutic to take each screw off each panel by hand and reinstalling them in its original hole. Call me "anal", but I'd rather be called "thorough" or "precise", LOL.
    2002 BMW 325i - his
    May 2019
    Tasmania, Ausralia
    Got it, nice to find another 'Airborne Warrior' on this site. Nice mods by the way.
    SoFlo
    Not sure how long it has been since you installed the foglights. The cap should be installed to prevent water and debris from entering the inside of the foglight housing. Once inside it is very difficult to clean.
    Sep 2019
    Reno, NV
    I just installed it last Saturday, 2 days ago.
    I don't really like to ride in the rain (I'm a fair weather rider with no real rain gear), so that's not a concern. I'll try my best to avoid any puddles or wet spots on the road.
    I did try to unhook the left fender to gain a bit more access, but I think my bumpskid was preventing it from moving. Because of this, I didn't bother to unhook the air intake. Like I said, when I decide to remove the frunk for the sway bar install is the time I'll try to reinstall that stupid cap.
    I should just run a few strips of duct tape across the opening in the meantime, lol.
    2002 BMW 325i - his
    Sep 2019
    Reno, NV
    Thanks !!
    HOOAH !!!!
    2002 BMW 325i - his
    Sep 2019
    Reno, NV
    10) Lidlox Helmet Lock (pair)
    Tips - Pretty straightforward install. My 4-year old grandson could've probably put this on for me.
    Notes: Looks to be a high-quality product. It's my first Lidlox, and I might buy one for my Harley. It's really nice not having to put our helmets in the compartments, although I worry about drunk people at rallies using our helmets as makeshift trash cans, LOL.
    (This mod is no longer installed and was replaced by Lamonster IPS Bar End Caps)
    2002 BMW 325i - his
    Active Member seaweed's Avatar
    Oct 2015
    Fort Lupton, Colorado
    Quote Originally Posted by Peacekeeper6 View Post
    I would worry more about the drunk folks using the helmets as barf bags rather than trash cans.
    Dean Secord AKA seaweed
    Veteran: U.S. Air Force
    2015 RT-S SE6
    My Mods:
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by seaweed View Post
    We were in Branson, Mo. last summer. Beautiful day, went into a restaurant to eat dinner. While in there, a thunder cloud full of rain passed over. Our helmets were FULL OF WATER. Since it was a very warm evening we just poured the water over our heads and put them on. Ya just gotta do what ya gotta do.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Very Active Member samewok's Avatar
    Oct 2011
    Jacksonville,Ar
    Mine got used as trash can.
    4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
    15 rt , yes Black
    Sep 2019
    Reno, NV
    Welp, I just ordered the Two Brothers S1R slip-on exhaust.
    ANYTHING sounds better than that OEM can that sounds like George Jetson's car, LOL.
    I'm hoping that the cat will help muffle the sound and makes it bearable at highway speeds. At least, I'm doing my part in keeping our breathable air clean....
    2002 BMW 325i - his
    Sep 2019
    Reno, NV
    11) Two Brothers S1R slip-on exhaust
    Tips - I found that it was easier attaching the slip tube to the muffler with the supplied hook springs first prior to connecting it to the bike. Removing the nut that mounts the OEM muffler was tough with just a regular-length ratcheting wrench, so try to get more leverage by attaching a metal tube at the end of the wrench. I didn't have a tube, so I used Vise Grip pliers and that did the trick. Also, the Vise Grips helped to attach the TBR clamp to the supplied TBR muffler hangar bracket.
    Notes: I'd have to say that out of all my mods so far, I absolutely LOVE this one. IMO, it makes it sound SO much better than the OEM muffler. It's not obnoxiously loud, probably because I decided to keep the catalytic converter. (Hey, I'm just doing my part in keeping noise and carbon footprint at a minimum, lol).
    Last edited by Peter Aawen; 02-29-2020 at 10:52 PM. Reason: Removed all the extraneous 'hard returns' & line feeds. ;)
    2002 BMW 325i - his
    Sep 2019
    Reno, NV
    12). Wrap My Spyder 758 SI and Phoenix decals
    Difficulty Level: 1.5 (the bigger decals take more skill and technique).
    Tips - TAKE YOUR TIME !! Otherwise, it’s not very difficult at all.
    Notes: I LOVE how it just transforms our bike into something more eye-catching and unique. I tried to install the BIG Phoenix on the frunk, but ended up botching it. So I removed it (with choice words, I might add) and instead installed the smaller Phoenix, which was A LOT better. Going to be interesting to see how they’ll last.
    2002 BMW 325i - his
    Feb 2012
    Spring City,Utah
    Great write-ups Lou. I have been buying parts from the folks at Diamond R since the early 2000s when all the made were Royal Star accessories. Met them again at D3WR last Summer and bought a Wounded Warrior cup holder and cup from them. I had clamp on flag holders on the luggage rack but they were always tilting. The trunk mounted poles look nice and are always upright. U S Flag and a Temple Riders Flag. Although not a vet I have always had Old Glory somewhere on my bikes. I have the black out wrap from Wrap My Spyder on the lower part of the windshield and it looks good and has held up to bugs and road debris very well so your wrap should do very well.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2019
    Reno, NV
    Thanks Paul.
    Yeah, can't remember the name of Diamond R's owner, but he was very personable and patient that I just HAD to give him my business. After a few months with it, I wish there was some sort of locking mechanism so the armrests doesn't move once it's set at a certain position. Other than that, I have been getting a lot of compliments with it.
    Many are also digging the decals from Wrap My Spider. I'm hoping to get some custom ones with our names, kind of like the names of fighter jocks stenciled on the side of their F-15s, F-16s, F/A-18s, etc. Hoping that someone will read this post and point me in the right direction....
    2002 BMW 325i - his
    Nov 2018
    Waynesboro, PA
    Thanks Paul.
    Many are also digging the decals from Wrap My Spider. I'm hoping to get some custom ones with our names, kind of like the names of fighter jocks stenciled on the side of their F15s, F16s, F18s, etc. Hoping that someone will read this post and point me in the right direction....
    WrapMySpyder will custom make something for you if you have something in mind. Just give Pete a call. As long as your not in a rush.
    My Spyder
    2012 RTL , Brown
    Sep 2019
    Reno, NV
    Quote Originally Posted by CopperSpyder View Post
    Thanks Copper !!
    2002 BMW 325i - his
    USA
    I just got done doing this, and I removed the frunk to do it. IMO taking the frunk off is less stressful than trying to get the cover back on the left fog light with the frunk on. I would rate this as about a 3 on your scale, the air intake tube is a chore getting it back on while trying to land the frunk. Takes 2 people too.
    https://www.spyderlovers.com/forums/...=1#post1507940
    h0gr1der
    Feb 2012
    Spring City,Utah
    Thanks Paul.
    His name is Allen at DiamondR. Wrap My Spyder will make anything you need just call and explain what you want.
    Happy TRAils/NSD
    Paul
    2012 RT L
    TRA
    PGR
    Venturers #78
    TOI
    Sep 2019
    Reno, NV
    Quote Originally Posted by h0gr1der View Post
    Kinda dreading this because it looks very daunting.
    I'm sure it's not as bad as it looks....
    2002 BMW 325i - his
    Sep 2019
    Reno, NV
    Yeah, I'm thinking of starting an e-mail correspondence with them.
    2002 BMW 325i - his
    USA
    It's typical Spyder. Looks bad, really pretty easy. Watch the excellent video by PurpleGuy. https://www.youtube.com/watch?v=dNd2...ature=youtu.be
    The only thing I missed was the Battery Tender harness which I had glued into the frunk grommet, and the USB/Audio cable with a grommet under the frunk liner. Not hard at all. Typical of Spyder procedures, took me about 4 hours, now that I know I could probably do it in 2. It's not heavy, just clumsy to handle. Luckily the frunk has hooks that hang it while you get everything reassembled.
    h0gr1der
