Results 1 to 20 of 20
    Active Member MNF3's Avatar
    Jul 2018
    Southern Minnesota
    Default Can I raise the passenger seat up on 2016 F3t
    I am 6’3, my wife is 5’. She can’t see around me at all. Is there a way to raise up the passenger seat a few inches? I have the stock seat.
    Thanks.
    The Journey IS the Destination
    2016 F3-T , Intense Red Pearl
    Active Member MNBK's Avatar
    Mar 2017
    Circle Pines, MN
    I have the same bike and my only thought is to take the passenger seat to an upholsterer and see if they can help by adding some more foam?
    Dave....
    2016 Red/Black F3T w/ Audio
    Bajha Ron Swaybar, BRP driving lights
    F4 Windshield, Ultimate Tallboy Seat
    BRP Passenger Backrest
    Custom Dynamics fender lights
    Tricled Rear Bag lights w/ Flashing Brake Modulator
    Wolo Horn, Lamonster's Bungee Buttons
    Spyderpops Bumper Skid
    Quote Originally Posted by MNF3 View Post
    Thanks.
    There are a few here who've done this MNF, so a search & a bit of reading might get you the answers you're after - type ' +seat ; +raise ' into the Search bar up toward the Top Right of the page; click on the 'Search Titles Only' box; then hit the magnifying glass to submit the search. Not everything that shows on the results returned will be applicable (some talk about just lifting the lid to open, others about holding it open... ) but a quick read of the thread titles that hopefully briefly ask the poster's question should help you identify the threads likely to help you most.
    Good Searching, I hope you find what yuou're after.
    Mar 2021
    Maryland
    That's going to be a whole lotta foam , but interested in an answer as my wife is 4'8" and I am 6'2".
    I already installed Pierre's 6" risers so her feet could reach the passenger floorboards.
    She has the same complaint about not being able to see ahead of us so she has to constantly watch my shoulders to que her on which way to lean so she doesn't really get to enjoy the ride.
    And I don't really want to cut up my Corbin so something like that it out of the question. There has to be some sort of cushion you can just strap on to act as a riser.
    2020 F3 SE6
    2020 F3 , Black
    Jul 2018
    Southern Minnesota
    Did the searching and didn’t see any real solutions that would add 3 or 4 inches. I will pull the seat off and see what I can come up with.
    Hmmm, maybe Motorcycle Dave, one of our Sponsors here, could help? Give him a call, or at least check out his link via the logo's on the Home page (& below) - but he always recommends that you call & discuss your needs with him anyway, only please be aware of any time-zone differences.
    http://www.motorcycledave.com/
    Jul 2018
    Southern Minnesota
    I will do that!
    May 2013
    Apex, N.C.
    I suggest buying an extra rear seat and having an upholster person add a couple of inches. That way you are not messing up your stock seat. I have a corbin seat that I purchased that needs a cover. If you were closer, I would suggest taking something like that and adding foam to it for the passenger. Good luck.
    May 2021
    Daytona Beach FL
    I'm interested in hearing what you come up with. My wife is shorter than I and would like to see forward a bit more.
    2020 Spyder RTL Chalk/Black
    2020 RTL , Chalk / Black
    Mar 2015
    Brockport, NY
    Just keep in mind her new center of gravity as you raise her up.
    2014 RT-S Pearl White
    Jun 2021
    Dunsford Ontario
    My wife sits above me and looks funny when we ride wish it was lower. Try a good pillow for your wife to get her higher.
    2019 F3 Limited Pearl White
    Jul 2018
    Southern Minnesota
    Being in Minnesota it will be 3 months before I get a ride, but I will keep you informed on what I try.
    Feb 2020
    Minnesota,USA
    Quote Originally Posted by Brentc View Post
    And some women have a "completely different COG"
    If in Doubt, Don't Do It!
    Feb 2020
    CT and ME
    LOL I keep thinking of something like this:
    https://www.chiccousa.com/shop-our-p...751140070.html
    It even has cupholders...
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Linden, CA
    Quote Originally Posted by MNBK View Post
    That is what I was going to say.
    My take on using a thicker piece of seat foam is that it depends on what you want to achieve, and how much of a height change you need. ..... The heights of the people involved aren't really what matters. The DIFFERENCE in seated body height DOES .... that will determine how much foam or brackets you will need. .... IMHO, I think that in your case, the difference in heights is too large to manage...... PS: the forward area that She can't see (because of your helmet) is not really very much. Some folks can adjust to life .... some can't... .... good luck with this .... Mike
    Feb 2020
    Minnesota,USA
    Let Her Drive! After all, "What Could Go Wrong"?
    I did the "let her drive" thing and ended up having to become a two Spyder family. She is currently on her third Spyder in 11 years.
    Mar 2017
    Circle Pines, MN
    We also went to the two spider family route.
    Dave....
    Mar 2015
    Fritch, Tx
    From having built several motorcycle seats over the past 20 years, I can tell you Arma Flex insulation is one of the best choices for building seats. It can be found in 3' x 4' sheets at HVAC supply houses and costs around $60/sheet for the 1" thick here where I live. It is also available in 2" thickness, but I don't know what the cost on that is. You could use that cut to the proper shape then glued together with contact cement and stacked to attain the height you need. That foam is firm enough that a 3 to 6 inch stack with a good cover should be pretty stable. Let her do a test sit as you add layers. Once the appropriate height is attained, then get an upholstery shop make a cover with D-rings or parachute snap buckles to hold it down. There is a chance the Arma Flex might be a tad firm for her tastes so a final top layer of seat cushion memory foam from Walmart makes a pretty comfy choice. Buying the whole cushion is easier than finding the foam by itself. Those cushions come in different densities so do some Charmin style squeeze tests before buying.
    good luck
    Last edited by cruisinTX; 01-17-2023 at 04:57 PM. Reason: Exposed hidden URL's iaw Forum policy
    Those who say " I can't" will always be right.
