Results 1 to 20 of 20
    Aug 2018
    illinois
    Default Front tires - Has anyone tried 165/60s?
    Trying to find new 165/55 R15s for the front. Not having much luck. Has anyone tried 165/60s?
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Tire rack
    A very good tire from what I read hereon, Verdestein Quatrac = 165/60R15, $100.67/tire from Tire Rack
    Aug 2018
    illinois
    Thank you, didnt know if the 60s would be ok in the fenders, pretty tight with the 55s
    Aug 2018
    illinois
    Thank you, but havent had any luck on the 55s on tire rack
    Feb 2022
    New Zealand
    I have just fitted up the 165/60 R15. No clearance issues at all.
    Quote Originally Posted by rperry View Post
    If the tire fits under the front fender ( and the 165/60 does ) It should never rub .... the tire and fender remain equally spaced from each other because the fender is attached to the HUB .... same as the wheel / tire ..... Currently the Quatrac is the highest rated tire that will fit our bikes ..... I am trying out a new tire I found ... the RIKEN HR, this is for the REAR only it's a 215/60-15 which is what just about everybody here is using ..... PS these are AUTO tires and your dealer may not want to MOUNT them. but auto tires places can ..... PPS if you use an Auto tire the PSI needs to be lower than stock ie. 15 to 17 front and 18-19 psi rear ...... Mike
    May 2017
    Mesa, Arid-Zone-A
    Additional size option is 175/55R15. I had those (Federal Formoza) on my 2014 RTL with no fitment issues. And.... They looked great..... Jim
    Semper Fi
    Dec 2020
    Hartwell, Ga
    Correct me if I'm wrong but I thought most were using the 205/60-15 for the rear. If not, what is the difference between the two?
    Very little! It basically comes down to what's available in your neck of the woods - either size is usually more readily available than a 225/50R15
    Active Member Garf's Avatar
    Oct 2017
    Ortonville, Michigan
    175/55R15 on my 2017 RT....Love um!
    Gary
    2017 RTL Asphalt Gray Metalic
    1987 BMW K75s
    The difference is 10mm or about 3/8th in. .... and the Vredestein's largest size is 205/60 or 205/65 -15 ...... Lots of folks here have switched to Vredestein's ...... Mike
    Vermont
    HI rperry,
    I am running the 165/60 R15 tire size, I found Continental Contiprocontact's on Tire Rack.
    I replaced the OEM's on 6/24/2016 with the above tire. The space between the fenders and the tire is about 1/2 inch( of the thickness of my pointer finger). These tires do not rub on the fenders.
    I have a 2014 RTS-SE6.
    The ratings on the above tires are: WET..................... 7.0 Good Wet Trac. 7.1
    DRY......................7.7 Good Cornering :7.5 Dry Trac: 8.0 Steering Response: 7.7
    I haven't had any problems with the above tire.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Active Member Piratezz's Avatar
    May 2020
    Heesch Noord- Brabant The Netherlands
    I fitted 175/60-15 Michelin's on my F3s, and they fit just fine, I learned from Mike that not all tires are created equal, but for me they fit like a glove, that's too tight...So me thinks you won't get in trouble fitting the size you stated
    Swaybar (Ron's)
    Pedalbox, Awesome Upgrade...
    2019 F3s , O.E.M. Black, Black, Black
    Mar 2015
    Fritch, Tx
    Another good online tire source that I have had very good luck with is Tires-Easy.com
    Those who say " I can't" will always be right.
    The OEM tire sizes on the Spyder are oddball sizes that hardly anyone else other than Kenda makes. If those sizes are used on any cars I'm not aware of it. That's why you can't find them.
    Active Member MarkN's Avatar
    Mar 2022
    Mio, Michigan
    Just to throw something else into the mix, I just fitted 175/65R14’ on my RSS with no problems what so ever. I know it’s not the same but I just wanted to point it out.
    2012 RSS
    2022 RT Limited
    2021 Ryker 600
    2021 600 , Black/Yellow
    Nov 2018
    Claremore, Ok.
    I have 165/60s on my 2015 RT-S Federal Formosa AZ01. Got mine at Walmart.com $55.00ish picked up and took to my tire dealer got them mounted and balanced.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
    Aug 2018
    illinois
    thank you!!
    Vermont
    rperry,
    I am running the 165/60 R15 Continental Contiprocontact I got in 2016, they have 24, 115 on them. I change the OEM to Continental Contiprocontact's.
    I have about a finger's thickness between the fender the tire( look at My Albums ) for pictures.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
