WIRES - ETC.
Originally Posted by cuznjohn
does anyone know how many wires go to the dess module. i am sure a electronics shop could figure out how to jump it out if they knew what it consisted of
.......There are TWO plugs into the MODULE, with TWO wires in each PLUG........Mike
I would say that its high time for BRP to come out and tell everybody that there is a problem with the 2014-2016 bikes and tell us they are working on a solution But no, BRP is so secretive about things they aren't saying a thing or even saying there is a problem. I would hate to even count how many modules have be replaced and as everybody knows, it's not the FIX. I would hate people to experiment on there bikes and start cutting wires to help bypass the key DESS problem. This would cause no telling what problems to our Spyders. I have a 2015 RTS and haven't been bitten by the dreaded DESS failure, but with all the DESS failures being reported , it sure doesn't give you peace of mind when you get on your Spyder to take a trip.
2008 Triumph Rocket (SOLD)
2002 Honda VTX 1800 C ( SOLD)
Just looked on the BRP parts site, looks like the DESS module is not for sale. My thought was to get one and find a shop to find out what makes it tick. 515 |
710004190 |
D.E.S.S.TM (Digitally Encoded Module) |
Not Available |
well that sounds to me like one set of wires power the module, and the other set are on a open contact that closes when the key is found. so then if the open relay is jumped out, it closes the circuit and the bike will start
I like the direction this thread is going. Only other thing I can think of is that BRP may get the message if they were looking at a class action lawsuit.
Think of it like a phone line. It's not just the connection that's important. It's the information that is passed back and forth is also important. The bank manager calls the bank and tells them to open the safe and give them the combination. The combination can only be used once and never can be used again. They open the safe and the bank is in business for the day. So if you cut the phone line that's is only 2 wires and jumper them together. That does nothing. The bank manager cannot talk to the bank. No one at the bank knows the combination. They can't open the safe. Out of business.
Well it looks like the DESS module is available for the 2016's I had previously looked at the 2014
248 |
710004916 |
Dess Module |
$132.99 USD |
Available |
I'll spring for the cost of the module if we can find someone that can figure it out.
Just A Thought
Any chance that Pitbull/Lamonster have an answer, or a work around, to this problem?????????
2021 Marsala Red Metallic RT Limited
LESS COST MODULE HERE
DESS 4th go around
My dealer just told me that their BRP tech told them they are NOT even working on the problem because once you have the latest and greatest module the problem is fixed unless you have another source of RFI causing the problem...
If it ever stops raining here, the next trip on my Spyder I will put my cell phone and vehicle keys back in the right saddle bag in my cooler and see if the problems returns or not...
JUST MAKES ME PROUD TO BE AN OWNER OF SUCH A FINE MACHINE...
PS I have a GREAT dealer and they are trying to help in any way possible...
larryd
REALLY
DESS issue
That is unlikely. It is more likely that one plug is power to the module and the other is connected to the CANbus network.
Given the amount of computerisation of these machines, I would be surprised if it was a simple as a relay. More likely it sends a message to the starter control circuit that the correct key is inserted, an it is OK to start.
Keep in mind that this is just a guess, but 40+ years working in industrial automation and control makes me think it is very likely.
Maybe Steve will get back to us if he reads this post, I just put in an inquiry with the Dept. of Transportation about who I need to talk to about this issue. Figure I paid enough for the machine and I paid my fair share of taxes so I'll let BRP and the Gov have at it. Owning a $20,000 plus machine that you can't trust is BS.
i am sure it is simple to have BRP turn off the unit through software, but i doubt they will because it will cost them money to have the dealer do it. so my suggestion would be, if a bike goes in with the problem and the module needs to be changed, then the dealer should be able to turn off the function if the owner want it done. OR if a person like me who has not had the problem wants it done, i would pay a reasonable service charge to be hooked up to the BUDS system to have it turned off
I know this is the internet and it's easy to TYPE, SEND and THINK.
But here is reality folks.
As soon as a corporation, any corporation hears "Class Action Law Suit" this is what happens:
Wagons get circled.
Law Firms, already on retainer, get called.
Their advice DO NOTHING UNTIL WE STUDY THIS.
Then guess what?
Time passes.
and passes.
and passes.
Plus here's the icing on the cake:
BRP does respond to their product's shortcomings.
They usually take more time than anyone likes but they come through.
Alright, my flame suit is on.
Have at it.
Reason: making it more like English
How much is it costing them to replace the modules? Gotta be more than plugging in the BUDS and reprograming the system.
Wagons get circled.
Then guess what?
Time passes.
and passes.
and passes.
They usually take more time then anyone likes but they come through.
Have at it.
Just to be clear I'd much prefer to see BRP just correct to problem. But after reading all the post's about this problem I don't see any positive action on BRP's part. I have no intention of flaming you and you bring out an important point. I'm hoping that BRP will promptly rectify this issue once and for all.
Originally Posted by rcturner
Jheck sent this link to BRPCare a few days ago.
Thanks Jheck
I also sent the other DESS thread to them also. Steve at BRP CARE says they always monitor their e-mail. So if that is true, they have been notified of our concerns.
here is another question for the people having the problem. do any of you have another key that is chipped for the bike in your pocket or hidden on the bike. could it be that the reader is reading both keys and causing the problem
I just tried this. With the second key next to the one in the ignition a DESS error comes up. One inch or more away, no error. This again is verification that the transmit signal from the key is pretty weak. That's why BRP says "unless there is other RFI" causing a problem. The weak signal from the key can be easily overpowered by some other RFI.
If we knew what the frequency is that the key transmits on it would be easier to do meaningful testing with other devices that use that same, or nearby, frequency.
One plug is power. The other goes directly to the ECM, not CANbus.
I think some of you missed my earlier explanation, "In 2014 it was changed and the ECM gets the key ID number from the DESS and checks the list of authorized keys. If it matches then OK to run." All the DESS does is reads the digital key number from the key and transmits it to the ECM. The ECM makes the decision if the key is authorized. If the key code get mucked up for whatever reason, the ECM will not find it in its list of authorized keys and gives the DESS error. I can readily understand the idea that other RFI signals can mess up the code the DESS sends to the ECM. That is something that BRP has no control over.
Those of you who get repeated DESS errors, have you tried leaving ALL your electronic stuff behind to see if maybe something you have is causing the problem? Or, if you need to have that stuff with you put it inside a lidded steel can in the trunk. That should trap the RF coming from them. If you then have no DESS errors that will be a strong indicator that something external to the Spyder is causing the problem.
Now, what I haven't seen anyone mention is having the ECM changed out, at least for a test. If, by some chance, there is a glitch in the ECM in the key verification part of the software, then that will create an error, I'm sure.
Looks like it's not just Spyders that have DESS problems it seems to be a problem with most of the Can Am product line, check this out.
https://www.google.com/?gws_rd=ssl#q...not+recognized
I think changing out the ECM as a test would be quite an involved process. What I'd love to be able to do is sniff the canbus and see what the DESS is sending to the ECM. If it's the correct number (no idea how to determine what is correct or not) then it could be a software glitch in the ECM. If garbage is being sent on the bus, then it could be the DESS. By swapping out DESS modules it seems BRP thinks it's garbage on the bus (or a bad read) rather than a glitch in the ECM.
The two times I've gotten a DESS error there were no other electronic doodads anywhere near the key or the module. Both times, taking the key out and waiting a few minutes cleared up the problem.
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
It's not on the CANbus. It plugs directly into the ECM.
