Results 1 to 9 of 9
    Yanceyville,NC
    Unhappy "Black Hole" Lesson learned ...
    OK ... I messed up. Note to self ... Never use the back seat as a parts tray. So, while installing my "Magic Mirror Mounts" from Lamonster, I dropped two of the old plastic mounts into the dreaded BLACK HOLE. Now the real question is ... Where do these parts actually wind up AND can they be retrieved?
    2015 RT Limited , Circuit Yellow
    Jul 2011
    Mitchell, Ontario, Canada
    They reappear on the street at the end of my driveway. Your welcome to drive up to Canada a see if your parts will appear here.
    Sorry could not resist.
    Aug 2013
    SF Bay Area
    They fall into a small very inaccessible pocket under the seat. Two options, Remove the seat and get better access to the pocket or try a string with a magnet on the end and go fish. I misplaced a garage remote and couldn't find it then I washed the bike and road it around the block without a helmet and heard the rattle. Used a magnet and string with a small hook tool and fished it out. Fallen things don't fall through, at least not on the newer bikes.
    2021 F3 Ltd , Magna Red
    Sep 2012
    Stetson, Maine
    They fall down on top of the plastic inner fender. After awhile they will fall out. The only way I know is to remove rear cargo module. This gives you access to the inner fender well. Bruce
    New to Sue and I
    Gone but not forgotten
    RTS 2011 SM5, 95,000 miles
    Bossier LoUiSiAna
    Got lucky 1 time on ST when (trying to save time)I was going to prop my atm card on dash & slid between dash glass & benzel to top of engine, I had to disassemble some top components to access, in HOT parking lot. Other items lost to the darkness 2 bad headlights (one on each side) as my large hands fumbled when removing. So glad was not the new replacements, know the plate underneath catches stuff , just accessing is such a pain, & the follow up cleaning from seeing the unexposed areas that accumulate whatever. Now for any work around the "PIT" it is covered with rags tucked in to help prevent
    May 2018
    Chateauguay, Qc, Canada
    Dropped the seat sleeves into the black hole. Had $30 borescope from General Tools and went looking in there and found it. Got a coat hanger and did some borescope fishing and got it out. Felt good about what I had done. Taped up the opening to prevent that from happening again.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
    Mar 2019
    Las Vegas
    LOL.. Me too.. I was installing my dash cam and I was using that for my parts bay too.
    A very small nut used to mount the camera do my dashboard fell into the locking mechanism and prevented the cable from moving.
    I couldnt open my seat to get gas until I used a very long screwdriver to jar that nut loose..
    Mar 2015
    forrest above Reno, Nv
    Last year I noticed how dirty the under seat plastic was. I cleaned it and stuffed soft foam in all the " black holes" . Much cleaner a year later. I set up a card table ( or use my table saw ) and plastic bags taped to the parts I remove. No more parts left over or lost.
    2014 RTS , Circuit Yellow
    Yanceyville,NC
    Ya know ... if that's an invite ... We might take you up on that next summer. As long as black fly season is over. Had enough of them as a Boy Scout in the 60's in Algonquin Park. Hope there's a campground near you.
