Results 1 to 17 of 17
    Mar 2016
    Santo, Tx.
    Default When shifting to 1st or reverse
    When shifting to 1st or reverse the shifting shifts hard, not a smooth shift, is that normal?
    Dec 2014
    Lee's Summit, MO
    If by hard, you mean that it makes a clunking noise, yes it is normal with the semi-auto transmission.
    Mar 2016
    Santo, Tx.
    Quote Originally Posted by kngfsh27 View Post
    OK thanks
    Jul 2016
    N.C.
    Yes, it's just the clutch 'opening' and nothing to be concerned about. Enjoy your ride.
    Mar 2016
    Willis, Michigan
    BRP calls the clunk into first "positive engagement". While first always clunks on my SE6, reverse doesn't always. I haven't paid enough attention to see if there's a pattern, but lately, it's been slipping very smoothly into reverse most of the time.
    Default Klunk...!!
    Typical and especially with big twins. In neutral the crank is spinning but the gear box is idle. When you joint the idle gearbox with the spinning crank you get a klunk. Same with reverse. Once you have engaged first the gearbox is spinning so all shifts after are more of a merge and smooth. Relax all is well down there..
    Mar 2016
    Willis, Michigan
    Ahhh, so if I paid attention and found my "pattern", I'd find that when I'm in first and hit reverse, it's smooth, and when I'm in neutral and hit reverse, it clunks. Thanks, Chupaca!
    Apr 2014
    Beloit Kansas
    Quote Originally Posted by ruralgirl View Post
    my own experience is ......any shift out of neutral will clunk, rev or 1st.
    shift from rev to 1st is butter, have never actually tried 1st to reverse. I almost always park it
    in neutral so I don't have to step on brake to start, which involves getting aboard etc.
    Mar 2016
    Santo, Tx.
    Thanks for all the imput..............
    May 2014
    Benson, NY
    Default Clunk is gone
    "Positive engagement" I love it. The spin doctor at BRP that came up with that deserves a raise. Now that I think of it as "Positive engagement" the clunk is gone.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Active Member Mikel53's Avatar
    Amarillo Texas
    Default Clunk
    when you first start it up with a cold engine it will clunk more than when engine is warm
    Mike Campbell
    Amarillo, Texas
    2015 RTL "intense red pearl"
    Aug 2013
    Northern California
    Default Music to My Ears
    When I am leading a group of 20 spyders on a group ryde, all I have to do is count the Klunks and I know everybody is ready to go!
    Quote Originally Posted by Pirate looks at -- View Post
    If I'm riding with you: please remember to subtract one of the "clunks"...
    I will probably have just dropped my helmet!
    They gotcha covered.
    Jul 2011
    Mitchell, Ontario, Canada
    What I wonder about. Every motorcycle with a wet clutch that I have ever owned or driven has clunked going into gear from neutral. Some were worse than others but still they all clunked. Why would you expect the Spyder to be different?
    It might be folks dipping their feet into motorcycling for the first time...
