OR; you could spend maybe $2 at a bicycle shop and get a 90° stem adapter and just leave it on all the time. Being made for bicycle tires they are rated for over 100psi. I've had one on our 2014 RT since the first week of owning it. Now a little over 7500 miles later--no problems whatever.
How about using this. Minimal loss of air when removing. Screw off types lose more air. Heck, with 24" of extension you could sit in a chair and inflate. Good ol' Amazon. https://www.amazon.com/Show-Chrome-A...454698&sr=8-37
A push-on chuck is a lot easier to get on the stem. Those kinds of chucks take a fair amount of finger strength to get secure on the stem.
Reason: Fixed quote display
RYOBI makes a nice small compressor with a built in gauge and a clamp on to valve stem. This works perfectly for all tires up to 125#.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Is there any way to install another add on to make getting air in the rear tire easier?
Next time you have to replace the rear tire, do this, before removing the rear tire
mark the wheel on the other side of where the current valve is, now 180 degrees
from that valve drill a new hole for a new valve that is closer to the edge but not where
the new valve will hit anything now install a new metal valve or rubber valve, Yes you will
have 2 valves in the wheel it's no big thing and it works very well.Just be sure
you put it across from the old valve stem so it don't cause any balance problems.
When I had car tires mounted on the front, I had them install longer valve stems. The made checking and adding air much easier. I don't know why BRP uses such short stems. Maybe they are two cents cheaper.
For those of you using the FOBO TPMS, what did you do to make their sending units fit on the short stems. I fond some short (1/2") extensions but was worried about stress to the rubber valves.
thanks johnv
They seem to work fine on 2019 RT. Can't speak to the others but mine are pretty short. I do not use the supplied locks, can't see a need for them.
thanks johnv
They work just fine on my 2021 RT base. No issues, whatsoever.
thanks johnv
I think that for some obscure/indecipherable reason, BRP used shorter valve stems on some of the F3's outta the box (2017?? ) and those were a bit tough to fit the FOBO senders onto!
No biggie tho, when you toss the Kendas & get some proper tires fitted, they'll probably hafta take the valve stem out anyway, so just get the tire fitter to use the next longer length valve stem then - no worries after that!
That said, the valve stem extensions won't be seriously stressing anything - and if they do cause issues, it'll just highlight that you already had a problem that needed fixing anyway!
90 degree brass stem was easy to install and makes Pressure Checks and adjustments sooo much easier. Best $$ spent in a while!
I'll try to post a photo soon.
Reason: forgot to add photo
I used a clamp-on chuck for awhile. Getting it on was no problem, but taking it off was. Tended to get caught on the threads and released too much air in the process. Now I use a threaded chuck. I can reach the valve to screw it on for pretty much any wheel position. Losing air when unscrewing has not been an issue. My compressor has a psi setting, so it checks the pressure at the same time, adding air only if needed - two operations are no longer needed.
Thanks for the photos, redrazor. Unfortunately it’s not that simple for those models with saddlebags. We only have a position between around 4 o’clock and 6 o’clock where we can access the stem. That’s why FOBO is so handy for me
HeliBars Handlebars
Kenda Kanine rear.
Until you can get your air valve moved or if your somewhere without the right sizes chuck, gonto the Harley store and get a stem extender as used foyr an Ultra. Harley has the same problem and have 6" flexable extention. Costs about $10.00. I keep it on the Spyder with my air gauge.
Exactly! That was my interim solution and it does help although it isn't perfect. With two RTs to attend to it does make the rear tire atonement exercise somewhat easier.
This is one way to cure the problem like others have said.
Harborfreight has similar tool, it works for me, While you're there get there high adjustable work stool for about $30, make working on car and motorcycle and Spyder way easier.
‘21 Honda Rebel 1100 DTC Burgundy
‘13 Spyder RT-L Pearl White
Hey Redrazor! You may want to take a look at your belt alignment.........
It was out at the edge because I had to move the bike backwards to put it into the best spot for a photo. Belt changes position from forward to reverse. I knew someone would comment on that. No problem. No problems.
It's the one from " ENKEI " it's the steel one and states it's an 85 degree bend.... it was packaged as " two for $11.00 " .... remember I used it on the DISC brake side of the rim, after drilling the correct size matching hole for it ..... to be safe I would drill the hole near the center if the rim , to prevent interference with any type of tire removal equipment ..... good luck .... Mike
