Results 1 to 16 of 16
    Active Member USAF's Avatar
    Aug 2022
    NY
    Default 2022 RTL - where is your battery tender connector located/routed?
    Hey guys, I want to install a battery tender connector. Where are you guys routing it for easy access?
    Last edited by Peter Aawen; 09-25-2022 at 11:42 PM. Reason: Expanded Title to briefly ask the question ;-)
    2022 Spyder RTL
    Dec 2020
    Hartwell, Ga
    Easy access is relative to each individual.
    I have mine inside the frunk, this way I have to unplug it to close the frunk lid. There are lots of post's where people have driven off with them still plugged in.
    Another location is anywhere on the front suspension that is easily accessible by you.
    Very Active Member SLICE's Avatar
    Aug 2022
    manatee county Florida
    dealer installed mine and located it on the right side near the spring.
    i have a remove before flight doohickey coming from the plug to the
    throttle as a reminder to unplug it.
    Northern Kalifornia
    Mine comes directly off the battery up under the seat and then hangs out over the right handlebar. No forgetting it's plugged in. Unplug it and store it back under the seat. Also handy for charging phone, GPS, heated clothing, and intercom on the fly.
    Aug 2022
    NY
    Well I ended up putting it on top of the Left Radiator Fan support by the front suspension. It had little hooks that locked it in place as if it was meant to go there.
    2022 Spyder RTL
    Feb 2017
    Same with my wife's 2021 Sea to Sky. The cable has a small red "Remove Before Flight" banner attached as a reminder to, well, remove.
    2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
    Oct 2021
    Wichita, KS
    Mine is located in the frunk and hangs out of the zipper. Easy Peazy connection and protected. I would not want it hanging out around the suspension exposed to the elements.
    Peter Pan has struck again!
    Active Member Pooch's Avatar
    Feb 2018
    Texas Hill Country
    Quote Originally Posted by FrogmanDave View Post
    Same here… had the dealer install it.
    2021 RT Ltd, Marsala Red/Black, Dark
    New course heading Mr Sulu: 2nd star to the right and straight on til morning...
    May 2019
    Michigan
    Same here, dealer that sold me my Indian Springfield sold me my RTL this year. Provided and installed on a complimentary basis for each bike.
    2022 RT Ltd, Deep & Dark Marsala
    Active Member Schreckftw's Avatar
    Oct 2020
    OH
    I brought mine out of the back of the battery box and out to the a-arm. I zip tied it all along the way. The wire tucks up under the plastic cover there. Made it very clean looking and easy to get to.
    2021 RT Limited , Deep Marsala Red Metallic (Dark)
    INDIANA, USA
    Default Battery Tender
    ...I have mine in the frunk too. Never forgot to unplug so far. The wife unplugs my plug so I will not forget.
    She will get a tag soon and installed it. She almost forgot last time. ......
    ENJOY YOUR LIFE WITH A SPYDER
    Florida Swamp
    It is nowhere right now, but I am watching this thread for the most likely place.
    Don't normally need one, since Florida can ride year round.
    I am putting 4 gauge cable in so the charging hook up can also handle a jump start.
    I have the tools to make up welding cables. No problem building one.
    2019 F3-S , Black & Silver
    Jul 2022
    California
    My "22 came with the pigtail already installed in the frunk.
    2022 RT Limited , Petrol Metallic
    Aug 2022
    NY
    Quote Originally Posted by Schreckftw View Post
    You have a pic you can post ?
    2022 Spyder RTL
    Member slyfox's Avatar
    Jun 2021
    spokane, WA
    I put mine in, hooked it to the battery ran it behind the frunk and out the left side, there is actually a spot that will hold the wires in place. when i plug it in it's right there just grab the wire and plug in. love it. 2021 spyder rtl
    Active Member davehirst's Avatar
    Feb 2017
    Christiana PA
    I have mine under the seat. I let it hang out when charging, then stick it back under the seat when unplugged. I also eliminated the lock on the seat, so I don't have to use the key to get to the gas.
    2015 RT S , None Tried one, but took it off. Didn't like it Black and Silver
