Page 2 of 7 FirstFirst 123456 ... LastLast
Results 26 to 50 of 156
  1. #26
    Quote Originally Posted by HayRog View Post
    Thanks for the info and very gracious offer Mike. If it gets to that I'll contact you.
    Glad to help ….. here's the thing .. Once you get a DESS code - that means it's on it's way to complete failure …. If it fails in your garage that's not too bad, but what are the odds ???? ……… It's more likely to fail while on a ride - now you have to have it TOWED it to some dealer …. maybe they will fix it immed. , but not likely ….. it could be weeks or months before you get it back …… Now that $135.00 part ( module ) costs you about $750.00. + wait time … if mine fails I would be ordering a new module that day ….. I have read every DESS post on the Forum, and NO Module has EVER healed itself ….. good luck …. Mike
  2. #27
    Houston
    Quote Originally Posted by h0gr1der View Post
    Mr. jcthrone,
    Is the DESS able to be disabled via BUDS? The In Plain Sight key pretty much shows Spyders aren't swiped too often, so is it really as simple as that? Is this an option open via the dealers, I'm getting ready for my first service, so they may be able to head off this issue by a delete.
    Its a simple toggle in BUDS. With or without a valid key in the bike.
    Most dealers do not purchase a sufficient licence to BUDS to allow them to use the setting. A few do and a few independent shops for the reasons in this thread and others.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  3. #28
    Vermont
    Got a DESS error code yesterday, I was hoping never to see this
    Good thing is that the bike ( after a few choice words) started up again 10 seconds later. Will this be the start of a module failure ? I'm hoping not. But thanks to this thread I'm fully informed.
    What year is your spyder?
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  4. #29
    Sep 2014
    USA
    I thought I read somewhere there is a backorder till July on the modules??
    Found one cheaper here
    http://www.2wheelpros.com/oem-parts/...4916-part.html
  5. #30
    NorCal - Northbay
    There is also a TST bulletin out there for when the DESS error comes up again after replacing the module, even with the latest & greatest one... It seems there is a separate antenna that can be replaced! I will try to find the info and post here....
    EDIT: Found it....
    Chuck
  6. #31
    Sep 2014
    USA
    I thought the antenna was part if the ignition switch?
  7. #32
    Vermont
    Quote Originally Posted by hypurone View Post
    EDIT: Found it....
    HI,
    **** I got this message from my Dealership on July 14, 2015 and it said" Summary: This TST explains the reason a customer may experience, intermittently a D.E.S.S error message in the cluster. Type: General
    TST Detail:
    Refer to TST Roadster 2nd Generation D.E.S.S Principal Of Operations( 2014 and UP) to fully understand the principal of the operation of the latest D.E.S.S generation.
    Problem:
    Intermittently the ignition key may not be recognized causing the unit not to start. The D.E.S.S ERROR message will be displayed in the cluster.
    Solution:
    Replace the D.E.S.S module.
    Program the keys using the B.U.D.S referring to the 2014 RT shop manual section Digitally Encoded Security System( D.E.S.S)
    Note" if after the replacement of the D.E.S.S module the problem reoccurs, update the previously opened BOSS WEB Case or open a BOSS WEB case and report situation. *****
    I also posted the above info on a THREAD that I posted on 8/13/2015 Titled " D.E.S.S KEY Code AGAIN !!!!!!!!!!!!!!!!!!!!!!!!!!!! it has 31 pages long & 758 Replies, & 151,906 Views
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  8. #33
    May 2013
    Sacrament0, CA
    Deanna
    C
    Deanna, sorry for the late reply.
    2015 RT-L, 18000 miles, 2 error code to date.
    I cycled the ignition 5 times (per Bluenight Mike) after the last incident - not happened since.
    Wife doesn't trust it ��
    Kinda hoping my Dealer (when I contact them) will bypass the module.
    Anyone on this forum do it ? I'll travel :-)
  9. #34
    May 2013
    Sacrament0, CA
    Just an update.
    Bike left at the dealers this morning (Elk Grove Power Sports) with an explanation of problem, and a request for a new DESS module.
  10. #35
    Sep 2014
    USA
    May not be the module. Could be the DESS antenna too..
  11. #36
    Jul 2011
    Mitchell, Ontario, Canada
    Why?
  12. #37
    Sep 2014
    USA
    Why?
    Why what? Why the antenna?
    2 reasons
    1:If The D.E.S.S. ERROR message is displayed in the cluster after replacing DESS
    Module 710004916, then please replace the Dess Antenna 219800373 sold separately.
    Please do NOT replace the Ignition Switch for the D.E.S.S. ERROR message.
    2:With first D.E.S.S. module production,when the D.E.S.S. module was sending his signal to the
    antenna to read the key chip, the radio frequency produced by the antenna was too strong and
    the key chip was saturated. This saturation changed the data transmitted back to the D.E.S.S.
    module causing a bad reading of the key chip. A ferrite has been added in
    new 710004916 module to reduce RFI/EMI signals.
    Now I know why there was ring ferrite on my first DESS Module and not the replacement. Now they are internal.
  13. #38
    Mar 2018
    Ontario ,way up north
    2 reasons
    BRP sleds have had the same problem.
    2018 RTL , dark blue
  14. #39
    Jul 2011
    2 reasons
    The DESS antenna is nothing but a simple coil of wire. So a continuity check with an ohm meter will tell you if it is good or not.
  15. #40
    Sep 2014
    USA
    Just posted what was on the bulletin. Maybe they use less of a coil of wire than before on the antenna?
    Maybe I will get the old and new OHMS and see what results I get.
  16. #41
    Vermont
    C
    HayRog,
    I am the one that posted about the "turning the ignition 5 times on/off.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #42
    May 2013
    Sacrament0, CA
    Update to update in post #34
    Defective DESS module replaced, codes cleared, done under extended BEST warranty -- good to go
    Replaced with newest version module # 710004916
  18. #43
    Active Member duke50's Avatar
    May 2014
    IL
    I just had the newest version, 710004916 go bad. This would be 3rd replacement. They don't have a fix for the dess issue!
    This time not under warranty. Not a happy camper. BRP needs to have a recall! 2014 RT-S
  19. #44
    Sep 2014
    USA
    Have they changed the DESS antenna??
  20. #45
    Quote Originally Posted by duke50 View Post
    If you want I can guide you thru DIYing yourself …. not hard just time consuming because the FRUNK has to come off ( *********** is full of Hooey that it can be changed without re-moving the Frunk ) …. the Module is $135.00 last I checked & no BUDS is necessary ….. Mike
  21. #46
    Vermont
    Default Question about the D.E.S.S
    HI,
    Has anybody read " MY Thread" D.E.S.S Key Code Again!!!!!!!!!!!!!! Posted 8/13/2015 Replies:771 Views 156,754 31 pages long.
    I am the D.E.S.S Queen.
    The above thread has some Great ideas/and suggestions about the D.E.S.S. module. I have a 2014 RTS-SE6, spyder, and have had the D.E.S.S module replaced twice under warranty,and the switch replaced once( under warranty).
    If I didn't post the above thread no one would have known about the D.E.S.S errors/problems.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  22. #47
    HI,
    Deanna
    Thank G*d for you … I hope your head hasn't gotten so large from this ...that it falls off ...………...….. Mike
  23. #48
    Jan 2019
    Tenn
    I had this issue yesterday 8/18/19 go to you tube and search "Spyder Bad Key Fixed" I tried the fix with the tin foil and it works I did not disassemble the ignition switch as in the video I just wrapped a little tin foil around the trim ring where the key goes and it started just fine no DESS ERROR with a pic of a key
    Going to my dealer tomorrow to see what they say..So far I do not think it is in the module or the antenna. At least for this key issue
    Roger
  24. #49
    Houston
    The tin foil trick is temporary at best. Might get you home from a bad situation but its not a long term fix.
    Replacing the DESS module does not permanently fix the issue either, just resets the clock.
    So far, the only permanent fix is to have DESS turned OFF. Problem gone.
  25. #50
    …… once the DESS fails, it is the signal that in the near future, it will stop working - PERIOD ….. That is what happened with mine, I had a few failures, but I could re-start it …. then none of the various start procedures would work..... if you are out of warranty, you can buy the part @ cheapcycleparts.com and others, for $135.00 and change it yourself …. you must re-move the frunk ( RT models ) to get access to the module which is a couple of inches above the battery on the firewall ….. good luck ….. I'm no longer concerned about the DESS, because " Joel The Biker " cancelled mine this past Sunday ...He is …… Mike
