Originally Posted by Easy Rider
So you assumed that it was CAUSED by the Stabil.
Maybe the Stabil just failed to PREVENT it.
As I clearly said that I believed that adding too much Stabil caused the gel because the results were repeatable.
Also clearly stated is that I like Stabil.
But perhaps, as you suggest , that adding Stabil failed to prevent the condition then it was a waste of money to add it.
No maybe not.
Without knowing ALL of the conditions present when the "failure" occurred you can not draw that conclusion.
Note that I did NOT actually say I believed excess Stabil could not have caused that to happen.
It is entirely possible that it could.
That is why they have instructions with a proper dose listed.
Earlier in the thread I noted that a couple of my engines ran rough in the spring after I added a bit more than the recommended amount.......and stopped doing that when fresh gas was added. I think I was using 50% over the recommendation. I don't do that anymore.
No maybe not.
uh huh.
