Page 1 of 3 123 LastLast
Results 1 to 25 of 66
    Active Member Gonzo5776's Avatar
    Aug 2018
    Woodbridge VA
    Question What oil do you use on your Spyder?
    Hi everyone,
    Just curious, what oil you guys and gals run in your spyders and why?
    Thank you and have a great day.
    2012 Can Am spyder RSS
    Weekend rider
    Very Active Member bodymanpainter's Avatar
    Dec 2009
    Yulee, Florida
    Amsoil 10W40, I have used it in all my Spyders (4) and no problems and the transmissions all seamed to shift much smoother.
    Toby
    2020 RTL
    Active Member fjray's Avatar
    Aug 2015
    central oregon
    Active Member Soulman327's Avatar
    Aug 2018
    Indiana
    Quote Originally Posted by fjray View Post
    Exactly!
    (but I still read every one)
    "If I was any better, I'd be dead!"
    "The sun's always shining...otherwise it would be dark!"
    "God looks out for the stupid, so I keep Him pretty busy!"
    Aug 2018
    Woodbridge VA
    Quote Originally Posted by bodymanpainter View Post
    Toby
    Thanks for the option, XPS kits are pricey.
    Weekend rider
    May 2018
    Columbus, Ohio
    Indeed :-) OP is going to get a LOT of answers to this and I hope it does not result in another locked thread. No clue why some folks are so passionate/stubborn about their oil choice being the only one that's valid.
    My main comment to the OP is to ensure that a synthetic is used per the BRP recommendations in the owner's guide. Now, me, I use Amsoil in everything except my Z06. Chevrolet put Mobil 1 in it from the factory and I continue to use it for that car. I have read several independent (NOT paid for by lubrication interests) testing reports and have talked with two engine builders who tear down and build high compression engines for a living. As a result, Amsoil is the choice I made, but I really don't think you can go wrong with any synthetic oil made today. They are extremely good.
    Also, I do NOT sell Amsoil, nor do I know anyone who does. I have always ordered directly off of their website......
    2016 F3 Limited in Pearl White-LaMonster GPS mount, LED fog lights, BajaRon anti-sway bar, Doc Humphrey's vibration dampener
    2013 Harley Davidson Softail Breakout CVO/ 110ci of potato-potato goodness
    2016 Ducati Xdiavel/ A street demon with a belt and forward controls
    Use whatever you want as long as it meets the API service specifications specified in your operators guide. Also do not add any oil additives or use oil meeting API service specification SM as warned on pg 95 of your operator's guide because it can cause clutch problems. Remember too that the only way you can tell how your oil is performing is to have it analyzed.
    Northern Kalifornia
    Amsoil 10W40.
    Default Oils......
    XPS Blend....get my kit on eBay at good prices shipped to my door free.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Faribault, MN
    Castrol Power RS Racing 4T 5W/40 with BajaRon Oil change kit, I get a good price and good oil wear reports, bike runs smooth.
    Safe Rides,
    David and Sharon Goebel
    Both Retired USAF Veterans
    IBA 70020
    I use Canola.
    It makes my sweet potato fries taste better!
    Aug 2018
    Woodbridge VA
    I use Canola.
    Lmao!
    Weekend rider
    May 2009
    Connecticut
    Valvoline 10w40 Synthetic Motorcycle oil from Walmart at $6.75 a quart. Most important is Using a JASO M2 Rating and Not just Jaso . Unless you use BRP oil.
    Sea Doo GTI-SE 90 Jet Ski!!
    Aug 2018
    Woodbridge VA
    Quote Originally Posted by Sarge707 View Post
    I like affordable!
    Weekend rider
    Very Active Member BoilerAnimal's Avatar
    May 2016
    East central Tennessee
    +1!
    On the road again...........and forever young!
    2013 RT-S SE 5
    Yesterday is a cancelled check.
    Tomorrow is a promissory note.
    Today is cash.......spend it wisely.
    Springfield, MO
    Boerne, TX
    I use whatever my neighbor has in his garage when it is time to change my oil.
    I traded my 2014 RT for a 2017 Mr. White RT-S. I am George Lewis. I live two miles from Boerne, TX. I am 89, retired USAF and Sony Corp. I also have a GW MotorTrike. My email: scoot62@aol.com
    SAVE THE CHUPACABRA
    If you have not been to Luckenbach, your journey is not complete.
    Aug 2018
    Woodbridge VA
    Quote Originally Posted by Mr. White View Post
    Lol. I like ur style Mr. White!
    Weekend rider
    Aug 2018
    Woodbridge VA
    Thanks for the magnetic drain plugs btw.. Amazing product!
    Weekend rider
    Vermont
    I use the Valvoline Motorcycle Oil, 4T Stroke Full Synthetic, 10W-40. It has the Superior Wet Clutch protection, and it exceeds API SERVICES SJ/SG/SF, JASO MA2.
    I have a 2014RTS-SE6, and I switched OEM oil to the above in 2015. I have been using the above oil since then with no issues.
    Deanna
    Last edited by Peter Aawen; 07-17-2022 at 11:55 AM. Reason: Removed orphan size cmd...
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Apr 2015
    Green Bay, WI
    I am truly amazed at how many Spyder riders have their motor oil analyized **. I'm not against it, I just know dozens & dozens of sport bike riders & racers who beat the hell out of their engines reving to 12K-15K rpm & above who never tested their oil--me either. Both of my engine failures were the valve seat melting out of the aluminum head--using NOS at the end of the 1 mile land speed run--the 1st crossed the finish line at 193 mph & the 2nd at 196 mph. I have no idea of the speed when the valve seat separated from the head but I doubt it was oil failure. Like I said--I have nothing against having it tested--maybe I'm learning something--the Spyder has a low power-low rpm engine. Maybe it saves the clutch.
    Apr 2011
    GREENVILLE, SC
    VALVOLINE 4T FULL SYNTHETIC 10-40
    i buy it from Walmarts web page... $7.37 per qt...
    Quote Originally Posted by SPYD3R View Post
    This Valvoline is what I used to use because ( it is great oil ) & I got a couple of cases at a fantastic price ….. I am now switching to the Shell Rotella T-6 ( which also is a superior oil ) because I got a few gallons at an even better price …..both of these oils are Full Synthetic ……………. Mike
    Apr 2015
    Green Bay, WI
    I use Extra Virgin Olive Oil because it matches my lifestyle..
