Results 1 to 25 of 37
    Very Active Member Martin Slovakia's Avatar
    Mar 2015
    Bratislava, Slovakia
    Default What is the best first upgrade to SPYDER or RYKER?
    Hi guys, so many questions I have received lately, what should be the first upgrade for new owner of SPYDER or RYKER.
    My answer is bit different, and probably something that many would not expect...
    BTW, what was your first upgrade you have done?
    Link to more VLOGS by MartinTheVlogger here
    https://www.martinthevlogger.com/vlog-1
    Aug 2019
    southwest oHIo
    TIRES.
    HER ride:
    2017 RT-S SE6 Pearl White
    My rides:
    2000 Honda GL1500SE
    1980 Suzuki GS850G
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    a sway bar has to be near the top of the list????????????
    BIG F
    Danbury Connecticut
    The very first thing:
    GET A LASER ALUGNMENT
    The Spyder tracks like it's on rails when properly aligned.
    When not aligned, you'll feel like you're riding behind a big truck, and it can be so unstable you'll rue the day you ever saw a Spyder.
    You're probably not going to do a lot of night driving at first, so next I'd go for things for comfort such as handlebars and seats, maybe suspension upgrades.
    Then go for more lighting to increase safety.
    After the stock tires wear out, and they will, get better tires.
    Just my opinion, I could be wrong. I'm sure someone on this forum will be delighted to let me know.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Sep 2020
    Middletown, NJ
    It took less than 300 miles for me to realize my 2020 RT suspension was not up to my riding abilities. 1st - sway bar, 2nd - tires, 3rd - shocks.
    2020 RT base , Chalk White
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Martin Slovakia View Post
    Lights. Assuming you already know you want to keep the bike, add lights. You WON'T be seen and the more lights you have, the better off you are. After that, ride for a while (unless you've only upgraded bikes and already know what you need/want) before you decide. For example, before I ever took delivery of my current ride, I knew I'd need a backrest and I knew I'd order one from Utopia. (I also knew it would take a while to get so I ordered a new Big Bike backrest from another vendor to use in the meantime.)
    Apr 2020
    Upstate NY
    I have only done one upgrade - a Cal Sci windshield - it was a significant upgrade from stock.
    Current Rides:
    2015 Spyder ST-S SM5
    2016 Honda Gold Wing ABS/Navi
    2022 Royal Enfield Classic 350
    2021 Royal Enfield Himalayan
    Linden, CA
    IF I WERE TO GIVE MY OPINION AND YOU KNOW ABOUT OPINIONS..... EVERYONE HAS ONE, I would have to say get rid of that crapy seat
    the designer who came up with the seat should go back to flipping burgers at a fast food place... the Ryker seat is a bad joke....
    The seats on the RT and F3 are OK but I can cure most all the problems they have but the Ryker seat , not so much....
    #1.- Tires ... #2.- lazer alignment ... #3.- Utopia backrest for 2014 RT ...... then I did about 75 more things ( not kidding ) ...... Mike
    Sep 2020
    La Luz, NM
    For me, first upgrade was brake pedal riser. Short legs.
    Next on deck, handlebar riser. Have it, just need to go do my wrenching.
    2020 RT-L , Lamonster brake pedal riser Red
    Very Active Member Peacekeeper6's Avatar
    Sep 2019
    Reno, NV
    1) Any that make your riding position comfortable and safer; i.e. bigger brake pedal, handlebar risers, backrest, etc.
    2) Any that makes your bike track straighter; i.e. laser alignment, BR sway bars
    3) Any that makes your bike safer; i.e. LED lights, fender lights, trunk-mounted brake/turn/running lights, etc.
    4) Any that makes your bike easier to work on: MAGIC MIRRORS
    SIGNATURE PIC CURRENTLY UNDER CONSTRUCTION
    2016 Toyota Sienna SE - hers
    2002 BMW 325i - his
    1994 Chevrolet Silverado K1500 Sportside Z71 - whoevers vehicle is in the shop
    2009 Harley-Davidson Sportster XL883 Low (Vivid Black) - his
    2018 Can-Am Spyder RT Limited - hers
    2007 Harley-Davidson Sportster XL883 Low (Pearl White) - hers (SOLD 02/29/20)
    2011 Tao Tao 50 - whoevers bike is in the shop
    2007 Reinell 186 FNS - the dog's
    1995 Fleetwood Flair 27R - EVERYBODY'S !
    Harrington, Australia
    Quote Originally Posted by Peacekeeper6 View Post
    Yes, riding comfortably is a big plus........and it’s interesting that we are all different in making ourselves comfortable, Peacekeeper. I tried the bigger brake pedal, but all it did was push my size 15 EEEWide boot off the floorboard, making it far less safe for me
    HeliBars Handlebars
    Kenda Kanine rear.
    Active Member Dmetcalf's Avatar
    Jun 2017
    Texas
    This is a bit of a challenge for me because there have been so many in my opinion significant upgrades. But I agree in that any Safety related upgrade should be at the top so for me it has to be the BajaRon sway bar.
    2016 RT-Ltd
    Bajaron swaybar
    Spyderpops trunk light
    Elka stage 2 front shocks
    Extra longbrake pedal
    brake modulator
    Rivco dual flag holder
    with American and Texas flags
    Lamonster Magic Mirrors
    missing belt guard
    Lamonster led fog lights
    Baker air wings
    2019 Silverado Duramax dually
    2019 Cyclone 4007 toyhauler
    Rivco brand footrest
    spydermanexhaust.com exhaust
    Vermont
    My first upgrade/farkle on my 2014RTS-SE6 was:
    painted dashboard.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Sep 2020
    Orlando, Florida
    Wolo Bad Boy Horn!
    Sep 2019
    Reno, NV
    Quote Originally Posted by Lynn8964 View Post
    Wolo Bad Boy Horn!
    I disagree, only because the horn is RARELY used when compared to the other mods.……unless you’re one who likes to lay on the horn, of course.
    2002 BMW 325i - his
    Sep 2020
    Platte City, MO
    It's kind of like a parachute: it's rarely used, but when it is, you definitely want it to do its job. And a loud horn does its job better.
    Sep 2020
    Orlando, Florida
    Safety first! Where I ride in Central Florida, there have been many instances of drivers coming into my lane without looking when I was driving I4 to work and back home. And a few that looked me in the eye and took the lane from me anyway! I installed an air horn on the Gold Wing I rode then, and if it didn't discourage them, it at least got the other drivers around looking and seeing the situation. A loud horn was the first mod on my HD ultra classic and Kawasaki Versus 1000 I've had since the Wing, and the second on my 2017 spider RTL purchased at the end of September last year.. The first was to have the ECU flashed by Monster Fuel because I had been lurking about this board for about 6 months prior to buying the RTL doing research. Installed the horn while waiting on the ECU to return. To me, it was a necessity because of the weak horns on most bikes that don't get anyone's proper attention.
    Jan 2019
    Hunter Valley NSW Australia
    Quote Originally Posted by Steve W. View Post
    TIRES.
    Ditto squared - if the bit holding the road isn't doing a good job then the rest is pretty secondary.
    2017 RTL
    2017 RTL , White
    Active Member 308gunner's Avatar
    Oct 2017
    covina california
    The first upgrade ...was the front and rear shocks...which was by far the most expensive but yet most effective upgrade
    For the spyder.
    Dec 2020
    North Germany
    because I couldnīt even make a testride before buying (no handbrake) I jumped around in a german spyder-forum and get informated. 1st things (except the handbrake) I let mounted was swaybar and endlinks from JSS, because I have no stability in the lower back, so I have to minimize the wanking. 2nd was changing the rear-shock to the FOX because my weight plus the weight of the wheelchair and -holder wonīt work with the OEM-Sachs
    2020 F3-S , pedalbox black
    Aug 2020
    Il
    Quote Originally Posted by 308gunner View Post
    For the spyder.
    Out of curiosity, do you do your own service or do you recommend any shops near you?
    Default Cognac dashboard
    painted dashboard.
    Deanna
    You're Welcome ...................Mike
    Feb 2020
    CT and ME
    One of the first and best things I did to my F3 was to install middle footpegs. They make getting on and off the bike much easier.
    My Mods:
    Elka Stage 5 rear shock with spring preload adjust
    Monster Stage 2 ECU
    Pedal Commander
    RLS cat delete
    Baja Ron sway bar
    Baker Air Wings upper and lower
    Viking saddle bags
    Third pegs
    Vredestein tires front and rear
    Mad Stad windshield
    X-creen windshield deflector
    Front and rear drive cam
    Garmin Zumo XT
    Heated gear wiring
    Lamonster LED headlights
    Lamonster LED foglights
    Lamonster frame mount cupholder
    BRP heated handgrips
    Lamonster drivers backrest
    BRP passenger backrest
    Lidlock handlebar end helmet locks
    Barkbusters Storm handguards
    2020 F3S-SS , Titanium/Black
    Oct 2017
    covina california
    Quote Originally Posted by Pirate View Post
    I have a good Private mechanic..he's about 45 mins away from me
