Results 1 to 25 of 39
    Nov 2018
    Claremore, Ok.
    Default Nitrogen in Spyder Tires?
    Has anyone tried using NITROGEN in Spyder tires? I have had NITROGEN in all my vehicles and trailer tires for the last 4 years. it's real nice to not need to hassle with tire pressures on 5th wheel or my flat bed trailer. Just hookup and go. I'm planning on having air sucked out and NITROGEN put in Spyder tires if the damn weather ever warms up enough to ride it.
    Nov 2013
    Oro Valley Arizona
    [SIZE=4]
    Big waste of money in my opinion. I have had a lot of RV trailers and motorhomes that came with it. The only advantage is the small 2-3 Lbs. pressure differential between air at temperature variations. Few places to get nitrogen unless you carry a
    bottle with you. You should be getting the picture by now.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Quote Originally Posted by jaherbst View Post
    [SIZE=4]
    Jack
    …………..Race cars use it, but those folks are rich ………..Mike
    Nov 2018
    Northern NV
    Sure, I use nitrogen in all my tires. About 78% of what's filling my tires is nitrogen.
    2017 F3T , Black, black and more black
    Quote Originally Posted by grumpyoldretiredcop View Post
    And it's CHEAP too!! Free as atmospheric Air, isn't it?!
    Active Member tibadoe's Avatar
    May 2013
    Gladys, VA
    I can't see the need to go the Nitrogen route. Doesn't take but a few seconds to top off a tire if and when needed.
    Joe
    2023 F3
    Oct 2014
    Fort Mill, SC
    Snake oil.
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    Quote Originally Posted by Revalden View Post
    Despite the naysayers that want to criticize every new, different, or unique idea that they don't agree with, it's just like any other farkle on a Spyder; if you like it and want it, then it's worth the cost. I know my local Tire Barn will fill my tires with nitrogen for minimal cost, and refill them for free. If you like it, I say go for it!
    Sep 2014
    USA
    Actually nitrogen is great in winter months I dont have to keep fiddling with tire pressure and they run cooler in summer months when used. May try it again some day
    Jun 2014
    ny
    Nitrogen is better, if available use it.
    Active Member ndspyderlover's Avatar
    Dec 2012
    fargo, north dakota
    I use nitrogen in all my tires. Even tire pressure and my car dealer in Fargo does it for free. It does not leak out of alu inum wheels. Bigger molecules so you eliminate air seepage.
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Nope total waste
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Houston
    Useless Nitrogen tire filling debunked:
    http://www.pedrosgarage.com/Site_5/Nitrogen_or_Air.html
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2016
    LI NY
    Quote Originally Posted by SPECTACUALR SPIDERMAN View Post
    Why, please explain?
    2010 RTSM5
    IMO, using nitrogen in your tires can lull one into thinking one's tires are OK pressure-wise so one gets slack about checking the tires for, among other things, stuff sticking in them. Even though I very seldom have to add air on a weekly basis, at least once a week they get a thorough check as I'm rolling the Spyder to get to the rear tire valve. Think that came from the basic MSF course.
    Sep 2016
    LI NY
    For the fire safety advantage
    2010 RTSM5
    Nov 2013
    Oro Valley Arizona
    Bigger molecules in Nitrogen???? I must search that out and it does not leak out of aluminum wheels??? Where did you get this information? Wandering minds want to know.
    Jack
    Quote Originally Posted by ndspyderlover View Post
    2015 BMW R1200R LC
    The only issue that I see with using nitrogen: what if you do need to put more in; and can't find any?
    It would seem me, that this would negate any advantage that if offered by it's usage.
    But if you like it: go for it!
    Nov 2013
    Oro Valley Arizona
    Thanks for this JC. Everyone should read this information and apply good common sense. (not to mention the money you will save)
    Jack
    2015 BMW R1200R LC
    Apr 2017
    North Central Florida
    Race cars and airplanes have good reasons for using nitrogen........because it is DRY......and it is the water vapor, mostly, that causes pressure differences with temperature.
    Regular air is 70+ percent nitrogen to start with......so all of that marketing hype is just BUNK.
    If your tires regularly lose air, you need to get that FIXED and dry nitrogen is NOT the answer.
    But there are worse ways to waste your time and money I guess.
    Danbury Connecticut
    There are some advantages to using pure nitrogen in your tires, as opposed to compressed air.
    But, those advantages are not realized unless you're pushing the performance envelope, such as racing cars, or aviation tires.
    For most people, normal 78% nitrogen air is just as good as 100% nitrogen.
    The only disadvantage is cost, and only you can decide whether or not it's worth it to you.
    Either way, you're way ahead of the game by checking tire pressure more often.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Apr 2017
    Bunk. Marketing hype.
    Sep 2015
    Muncie, Indiana
    Welcome to a forum with only supportive, productive responses to your honest questions and concerns!
    There are some who historically are self-appointed experts in everything Spyder and more. Just ask them and they'll be glad to tell you. I am sure the only things they have done to, or have on their Spyders (or Rykers) are purely necessary, performance-enhancing, and most of all, never a waste of their money.
    Again, there are proven benefits to nitrogen, whether significant or not is a matter of opinion, and you know what they say about opinions. You can find statistics to support any argument you want to make.
    You do what you want to do and be happy. Only you can determine what is a good vs bad investment, and nitrogen is a minimal investment. Ignore the rest because, to them, you will always be stupid and wasting your money.
    The subject of Nitrogen in tires has come up from time to time since I have been on site. Sad to say, not an expert here. My dealer would install only Kenda's, and Laser alignment is a "what's that?" Nitrogen in tires?..................that would be like going into the 21st Century for them.
    No problem with kicking around the pros and cons. Going to read them all and hopefully learn something in the process.
    My only suggestion is discuss it as much as you want...pro and con. No need to pick at others who do not agree with what you think. They have their perspective too. There is nothing wrong with a lively discussion. We have not had one of those for awhile now.
    This can be a great subject. No need to bring out the knives and guns to hash it out.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Been using N in my bikes since 2009.
    I PERSONALLY like the ride better with N than air.
    I can get N for free. But for me on the Spyder I like I only need to top off twice a year. Once in Mid January and maybe in mid June.
    I have FOBOs so check before each ride.
    I also like the fact that as the tire heats up from the road, the N stays constant.
    Is N better??? I really don't care what the self imposed experts say. I = meaning ME like it.
    So the bottomline = WHATEVER FLOATS YOUR BOAT!
    I started using synthetic oil back in 1973 while stationed in Italy. Everyone said bad idea, but I liked it and found the engine ran smoother. Today - EVERYONE (well almost everyone) says how great syn is.
    Get the point?
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
