Does the 2014 RT come with a Battery tender pigtail?
Does the 2014 RT Limited have a battery tender pig tail.
Not unless you install one. On the other hand, you can use your 12 volt power in your trunk to plug in a tender pigtail (that's the easiest). Just change your fuse to make that power outlet hot all the time.
The pigtail is generally part of the battery tender when you purchase it. My dealership installed a complementary one, Deltran Battery Tender Jr., with pigtail at no charge when I bought the Spyder. It is fused and I can use it to connect my emergency compressor if necessary.
As above, some dealers do and some don't. If not, my purchasing dealers always added one no $$.
2022 RT Sea To Sky
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Show chrome Trunk Shock
It's a 5 minute job to put a pigtail in yourself.
My next project is to put a plug for my heated riding gear in somewhere the dash switches go. I figure that fused pig-tail can do double duty and supply the heated gear when it's not in the garage on a maintainer. Jobs like these are 'when-I-get-around-tuit...
How will changing the fuse make it hot all the time.
Ozzie Ozzie Ozzie
You are not just "changing a fuse", you are changing the location of the fuse.
The fuse in question can be moved from one location to another, as outlined in the owner's manual.
In one location, it is hot all the time, in the other location, it is switched with the key.
HER ride:
2017 RT-S SE6 Pearl White
My rides:
2000 Honda GL1500SE
1980 Suzuki GS850G
Got spyder home yesterday it had pig tail and new Yusa trickle charger.
Ozzie Ozzie Ozzie
Thanks for the update/resolution report!
Double check and make sure you are using the wrong term. You do not want to use a trickle charger. It will destroy the battery because a trickle charger sends a current all the time. If, as I suspect, you actually have a battery charger/maintainer then you're golden. They are commonly referred to as "battery tenders" which is a brand name. The charge current rating should be no more than 4 amps. The maintainer part keeps the battery charged up by sending a charge current only when the battery charge level drops.
Because of the significant difference in the operation and affect of a trickle charger vs. battery maintainer we like for owners to be clear they understand the difference.
