Originally Posted by Easy Rider
So you assumed that it was CAUSED by the Stabil.
Maybe the Stabil just failed to PREVENT it.
As I clearly said that I believed that adding too much Stabil caused the gel because the results were repeatable.
Also clearly stated is that I like Stabil.
But perhaps, as you suggest , that adding Stabil failed to prevent the condition then it was a waste of money to add it.
The Power of Logic.
Start Thinking.
No maybe not.
Without knowing ALL of the conditions present when the "failure" occurred you can not draw that conclusion.
Note that I did NOT actually say I believed excess Stabil could not have caused that to happen.
It is entirely possible that it could.
That is why they have instructions with a proper dose listed.
Earlier in the thread I noted that a couple of my engines ran rough in the spring after I added a bit more than the recommended amount.......and stopped doing that when fresh gas was added. I think I was using 50% over the recommendation. I don't do that anymore.
No maybe not.
uh huh.
The Power of Logic.
Start Thinking.
