Results 1 to 11 of 11
Hybrid View
    Feb 2019
    Portland, Oregon
    Funny you should ask. I am currently installing a temporary connection for the heat controller for my heated jacket liner. My plan is to have it in the center where the seat meets the tank. The wires come from the battery (actually the fuse block I installed over the battery) under the Tupperware to the space under the saddle. That way it's easy to see and reach. Temporary because later, when i get the saddle customized (it's not comfy) I'm going to have heat put into it.
    Northern Kalifornia
    Right on, me too. I have an SAE lead with a 15 amp in line fuse coming directly off the battery and up under the seat. Run two sets of heated clothing, or charge my cell phone or charge my Sena's. No holes, no switches and tucks away out of sight when not being used. Also plug the battery tender to it in the winter. Simple, less than $10.00.
    Vermont
    I use a heated controller , it is on the dashboard ,and secured by Velcro and I wrap/and secure the cord around the ignition key. Look at any of my posts/or my Albums for pictures.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
