Results 1 to 13 of 13
    Ft Pierce/Lk Placid
    Default Successful Lanyard For Ryker Key
    Lanyard attaches to a zip-tie tightly installed onto the key. Lanyard is slightly taught attached to right side of handlebar, which prevents lanyard from "flapping in the breeze".
    Mar 2019
    Oviedo, FL
    What’s the primary purpose of this setup?
    Kansas
    You need a a yellow lanyard
    Ft Pierce/Lk Placid
    Quote Originally Posted by Gsrodeo47 View Post
    "Eventually" the plastic tabs will fatigue due to snapping on & off the knob thingy, and you will lose your key going down the road! PLUS, you are much less likely to lose a key if attached to lanyard, vs. being by its lonesome.
    Ft Pierce/Lk Placid
    Quote Originally Posted by KC61 View Post
    I'm gonna add blue stripes on the yellow hood cover.
    Kansas
    Sure would be nice if you could leave the damn thing in your pocket.
    Mar 2019
    Oviedo, FL
    I just leave my spare on my keychain. Primary goes in my pocket when not riding.
    Active Member mikeyuberalles's Avatar
    Feb 2019
    Clearwater, FL
    You can. Once the ryker has been started, the key fob can be removed.
    The display will give a warning about the key missing (down at the bottom), but you can operate just fine.
    Kansas
    Quote Originally Posted by mikeyuberalles View Post
    There ya go, problem solved. Seems like a good solution. Start it then put it in your pocket.
    Ft Pierce/Lk Placid
    But the warning keeps you from seeing on your display what you WANT to see - no solution at all.
    Mine is the best one.
    Kansas
    Quote Originally Posted by Aufgeblassen47 View Post
    Bragger
    California
    looks like an accident waiting to happen.
    Ft Pierce/Lk Placid
    Quote Originally Posted by DirkDiggler View Post
    How in the blue blazes possible?
