Results 1 to 5 of 5
    Nov 2015
    Cypress
    Default Heated gear connection on F3T
    Next to the key on the left there is a hole with a plug in there now. I have seen some kind of covered connector that will fit right in that hole. Where can I find this plug? What are others using?
    Buckskin
    2016 F3T , Pearl White
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Buckskin View Post
    Buckskin
    I have my heated gear connector run up through my handlebars. I then use a 24" extension to attach it to my gear. I'll post a few pics later.
    2020 RT Limited , Chalk
    Mar 2013
    Maumelle, AR
    Buckskin
    I posted pictures of my power for my heated gear. Hope it gives you some ideas.
    I was at Spyder Rendezvous last year and saw a red F3L with that same set-up. As soon as I got home, I changed mine from under the seat. This set-up is far better.
    Jul 2016
    Chesterfield, VA
    Default Heated clothing on a F3T or L
    I been looking at your idea to get your 12 V source for heated clothing. Another choice would be to attach this cable to a mounting port on through a panel. Example would be at (https://www.thewarmingstore.com/gerb...-port-kit.html)
    My thought is the flexing a power cord could develop an open or a short in the 12V supply. Your cable would be flexing year around even when not in use. I plan to use this on my F3L in the next few weeks.
    Tom Westendorf
    Nov 2015
    Cypress
    Tom, been to the warming store and already ordered that port mount. I'm going to try to see if it will fit in that hole that is now for the heated grips, if not, will find a flat panel area and mount it there.
    Buckskin
    Will post some pictures when I get it done.
    Quote Originally Posted by tates View Post
    Tom Westendorf
