Page 1 of 3 123 LastLast
Results 1 to 25 of 52
    Default What Does A Sway Bar Do?
    I get a lot of questions about sway bars and what they will actually do for the Spyder. Hopefully, the information below will give you a better idea of how this very critical component works with your shocks and suspension to improve handling and stability.
    To understand what my sway bar will do for you, you have to understand what a sway bar does and how your suspension works. It isn’t rocket science, but it is a subject that is widely misunderstood. Sway bars, as with suspension in general, isn’t something that most people are well versed in.
    This is in no way an exhaustive treatment of this subject so bear that in mind.
    A sway bar (or Anti-Sway Bar) is simply a SPRING which lurks under most vehicles produced today, quietly doing their job with little or no recognition. While the sway bar is a huge component in racing vehicles. It is also critical for the every day driver as it controls aspects of handling and control that no other component can.
    There are several suspension components that work together to give us a safe, controlled and comfortable ride. Improve any one of them and you will likely see immediate improvement in the area(s) that are affected by that component. It would be foolish for BRP to build the best possible suspension for our Spyders as that would be very expensive and not necessarily appreciated by every customer.
    Stock suspension on our Spyders is adequate. Yet there is a great deal of improvement to be had if the owner would like better, more controlled handling.
    What we are addressing in this explanation are the effects of centrifugal force (lean angle in a turn) or any side forces (wind, buffeting when passing a large truck, etc.) and how to best counteract these forces, most notably in the case of our Spyders, excessive lean.
    There is much more to our suspension, shocks in particular, than just countering centrifugal force. But for this explanation I am only discussing lean angle aspects.
    My drawings are crude, but hopefully helpful. Art is not my strong suit!
    1st Picture
    This depicts the Spyder going straight ahead without Shocks or Sway Bar. Just 1 A-Arm is shown on each side to keep things simple. The sway bar has zero effect running straight ahead (unless there is a cross wind or buffeting as in passing a large truck on the freeway. Shocks also have little effect when running straight ahead other than to absorb any bumps in the road. Of course the springs on the shocks hold the Spyder up.
    2nd Picture
    Suspension and body of the Spyder reacts to Centrifugal force (Yellow Arrow) causing the body of the Spyder (Blue Box) to lean to the outside of the turn (exactly the opposite of lean angle on 2 wheels where you must lean to the inside of the turn.) The Spyder does not compensate for centrifugal force. Instead, it attempts to manage it. How well a Spyder manages centrifugal force depends on many factors including the shocks and sway bar. On 2 wheels, centrifugal force must be perfectly balanced. This is done by leaning into the turn.
    3rd Picture
    Shock springs provide equal down force (Green Arrows) holding your Spyder up. Stiffer spring setting will raise the Spyder. A weaker spring setting will lower your Spyder.
    4th Picture
    Inside Shock - During a turn the Shock on the inside of the turn (away from the lean angle) extends. This lengthens the spring and reduces down force to that wheel. Though down force is reduced, this inside shock spring is still contributing to lean angle by pushing down on the suspension and raising the high side of the Spyder body, thus adding to lean angle to some degree. This happens until the inside wheel is lifted off the ground. At this point the inside shock has no effect on lean angle.
    Outside Shock – While turning, the Outside Shock is compressed reducing spring length which greatly increases down force to that wheel. This increased down force resists lean angle.
    The greater the lean angle, the more pronounced both of these shock spring effects are. Here are some basic rules of thumb regarding shock spring effects.
    Lower spring Pre-Load setting, lower ride height, increased lean angle in turns, softer, more compliant ride.
    Higher spring Pre-Load setting, increased ride height, less lean angle in turns, harsher, less compliant ride.
    5th Picture
    Remember, the Sway Bar is a Spring attached at 2 points on the frame (
    Blue Box). The ends of the sway bar are attached to the A-Arms. When going straight ahead the Sway Bar has no effect on the suspension what-so-ever. Therefore, a stiffer sway bar cannot effect the harshness or softness of your ride. The sway bar does not hold your Spyder up, so changing the sway bar will not affect ride height or front end alignment.
    6th Picture
    A sway bar WILL NOT eliminate lean. You actually need lean to make everything go smoothly. It is the AMOUNT of lean that you want to better control with the sway bar.
    A sway bar is simply a straight spring. As with all springs, it is designed to flex with increasing resistance to increased force applied. You can see in this exaggerated picture that a great deal of stress is being applied to the sway bar due to the lean angle of the Spyder body (
    Blue Box). The sway bar is attached to the frame at 2 points. It does not actually bend as depicted, but it is difficult to show how this torsion spring works with my limited skills in diagramming.
    The Sway Bar is always working to stay straight. As the lean increases the Sway Bar applies increasing force to each A-Arm in its attempt to remain straight. Using leverage created by the angle of the A-Arms, the Sway Bar applies force to the Spyder Body (
    Blue Box) in the opposite direction to the lean created by side force.
    Once you ride a Spyder with a Custom Performance Sway Bar, you won't need to know any of this because you will be able to feel exactly what I'm talking about every time you encounter a situation where your Spyder used to lean too much.
    I sincerely hope this helps! Being well informed is the best tool any Spyder owner can have in their tool box.
    Ultimate Spyderlover
    May 2012
    McComb, MS
    Thanks for this detailed answer to a drawn out question.
    Thanks for the explanation!
    But a question: If you hit a bump with one wheel; does that linking of the two sides of the bike via the anti-sway bar then result in a "stiffer" suspension?
    Springfield, MO
    So you're saying the new swaybars will be red?
    Palm City Florida
    Thanks for the explanation.It certainly has given me a much better understanding of what the function of the sway bar is.
    Ivor
    Lamont,
    You saw that too?
    I was trying to keep it simple! I hope this dosn't turn into a 'Try to Stump BajaRon' contest....
    The sway bar will resist any movement that is not equal at both wheels. Slightly at first and more forcefully as the deflection increases. This will be true whether one wheel tried to go down (drop into a pothole) or up (over a bump).
    The shock on that side will also affect action to that wheel.
    So, technically speaking, the sway bar would give you a 'Stiffer' suspension in this senerio. But the effect would be minimal and less than what the shocks would be doing at the same time.
    Quote Originally Posted by Lamonster View Post
    Only if your shocks are Green and your frame is Blue!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    One more thing to point out to some people who may wonder, or think otherwise. The Spyder already has a swaybar (or more correctly anti-swaybar). The effects of the swaybar can be enhanced by installation of an aftermarket, performance swaybar, just as it can be by installing aftermarket, performance shocks. All suspension systems on production vehicles are compromises. Compromises on springs and damping (coil-over shocks on the Spyder), compromises on swaybar stiffness, and compromises on performance vs. production costs. Many rides never feel the need for performance components, or may prefer comfort over performance, and the factory stuff suits them fine. Others don't want the ride harshness that may come with the package, while some may not have the knowledge or skills to select performance components in such a way that they work well together. For those of us that may have special needs, such as doing a lot of mountain riding or carrying a heavy load, performance items like Ron's swaybars or some Elka shocks may be just the answer. The Spyder isn't deficient in the handling department (except for maybe the OEM 2010 RT), but if you feel a need for more than the factory offers, aftermarket componenets may be for you. We don't all need them, but those that want them are glad they are available.
    Jun 2012
    Concord, NC
    But the added feeling of "stiffness" is much more desirable than the loss of control feeling you get when your suspension goes all "whoppyjawed"
    Aug 2012
    CO
    Stiffer, softer... are the kids asleep? what kind of forum is this anyway!??
    JLohPhotos
    2008 GS , Millennium Yellow
    Invalid Emails
    Jun 2012
    Laguna Niguel, CA
    Red is fine. You gave me a headache. I think I'm in a coma.
    Quote Originally Posted by shelbydave View Post
    Is that a NASCAR term??
    Ron,
    I didn't mean to throw you a curve... And the effect that I mentioned is; of course, absent if you hit a bump or hole with both front wheels...
    Jun 2012
    Concord, NC
    Quote Originally Posted by asp125 View Post
    This reminds me of the jokes that were flying about when Viagra sponsored Mark Martins car a few years back..
    Jan 2009
    austria
    thanks .. all this things are not so easy to understand (with my english..)
    what I always wanted is : the two front shocks are "connected" - so if I make a curve the shock on one side gets softer.. the system makes the other one to get stiffer in the same moment
    would help a lot to have the comfortable suspension AND no body-roll in the curves - fits perfect on the spyder concept ..
    OK - if somebody understands what I mean ..
    ( its an old Jaguar-Car system)
    Ron,
    Not a problem. Anytime you cover a protion of a larger subject like this there are always questions about the parts that are left out. Like Scotty's adding that there is already a sway bar on the Spyder just like there are Shocks on the stock Spyder.
    This was not meant to say that everyone should rush out and buy a sway bar, shocks, or any other suspension part for their Spyder. I was hoping to give people an idea of what they can expect from changing to a stiffer sway bar so they can decide if this is something that would benefit them or not.
    But Hell; we're already sold!
    Mar 2012
    Beaverton, Oregon
    Ron
    I am on the list for a sway bar and I have Elka Stage 1 R+R. My question is once the sway bar is installed, should I be expecting to be changing the Elka settings in any way?
    Cant wait!
    Larry
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    (My guess would be that you might be able to soften up the preload just a tiny bit...)
    Now let's see what the gurus say!
    Active Member WingmanRT's Avatar
    United States
    Default Sway bars
    More importantly, when will the anti sway bars for the RT be arriving?
    Paul "Wingman" Metheney
    2020 Can-Am Spyder RT Limited
    2020 RTL , Red
    I think that Ron said after November 12th...
    Quote Originally Posted by bmwlarry View Post
    Ron
    Cant wait!
    Larry
    It depends, but probably. Especially if you have stiffened things up to control lean angle.
    Typically the shock spring setting is increased to help counter lean angle. If you look at picture #4 you can see that the outside shock spring resists lean angle but the inside spring (to a lesser degree) is working to increase lean angle. By stiffening spring preload (or getting heavier springs) you increase the differential.
    In other words, you widen the gap. I have no idea what the numbers might be but just picking values out of thin air for example...
    Let's say we have stock springs providing 250 lbs of down force each while riding straight ahead.
    In this fictitious turn, the compressed outside spring provides 400 lbs of resistance to lean angle and the extended inside spring adds 100 lbs. of force, Increasing lean angle. The shock springs are actually working against each other to a certain degree in any turn. In this example the differential is 300 lbs of effective force resisting lean angle.
    We decide we want to decrease lean angle with shock springs so we up the spring rate, or get heavier springs. Now we have 300 lbs of down force from each spring
    In the same turn the outside shock spring now provids 600 lbs of resistance to lean angle while the inside shock spring adds 150 lbs of force increasing lean angle. We have gone from an effective lean angle resistance of 300 lbs to an effective lean angle resistance of 450 lbs. Though the inside shock is contributing more to lean angle than before, the outside shock more than makes up for that increase.
    Again, I'm throwing out bogus numbers simply to make the point. Our resident shock experts would know exactly how this all pans out in real numbers.
    Motorbike Professor
    Mar 2008
    Allegan, MI
    To further complicate matters, The shock damping serves to resist both spring forces. In effect, that delays the spring reaction, or slows the rate at which the force is applied. To even further complicate things, the damping is usually not applied the same on compression and extension, and the damping may not be linear...being stronger at one end or another of the compression/extension, or being stronger on quick acting forces than on slow acting ones. Suspension is a very complex science, and a balancing act for sure. That is why Ron has been so careful in working out the details, and testing the results before releasing his products. It all has to work together, and work like Goldilocks would want it to...not too strong, not too weak, but just right.
    I believe that the 2 most complicated components on the average vehicle are the fuel/air delivery system and the shocks. Speaking difinitively about either one will usually get you into trouble in one respect or another.
    I am always reminded of the twin Amal carburetors on a 650 Triumph Bonneville. If you want to lose your hair, your youth and your mind early, try to tune a set of these!
    Motorbike Professor
    Mar 2008
    Allegan, MI
    ...especially the concentrics. The slide bores wear out and make them impossible to tune. My 65 has Monoblocks, they aren't quite as finicky. Of course I have lost my youth, still have my hair, and I'm not real sure about the other one.
    San Antonio, TX
    I'm buying a 2010 RT. is there something i should know about the handling?
