Results 1 to 25 of 26
    Invalid Emails
    Jan 2009
    North Central FL, USA
    Default Lamonster "catch can" revisited . . . . .
    I noticed oil seeping from around the joint between the upper and lower airbox halves, and this was right at the 2K mile mark on my SM-5. It was time to add the Lamonster airbox modification, which because of the photos, was an easy fix. Even though there was probably not more than three or so ounces of oil in the airbox, it made quite a mess. I can see where, if not taken care of, it could drip down the sides of the airbox and onto the exhaust. Probably wouldn't start a fire, but I'm sure it would make some smoke!
    I performed a similar modification on my Buell XB 12 when I installed the American Sportbike airbox. The catch can was made of billet aluminum, anodized black, and although mounted where it could be seen, blended in perfectly and looked like a factory installation. Sometimes when emptying it, there would be a watery oil. Glad I did this mod.
    Aug 2008
    Mashpee Mass,02649
    Quote Originally Posted by opticat View Post
    did same runs better and no oil in air filter thanks Lamonster was easy to do .....
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    Just checked mine last night, and this was after a 300 mile ride.
    Thanks for the tip Lamont.
    2008 GS.....PE # 2888
    Apr 2009
    Lansing, MI
    I just did the same mod, but haven't had a chance to ryde yet due to the weather. It sure was a pain cleaning all that oil out of the air box! I went ahead and installed the Green filter while I had the tupperware off.
    Springfield, MO
    I don't want to take credit for an old idea. This type of catch can has been used for years, I just applied it to the Spyder. Glad it's working for you all too.
    Apr 2009
    Lansing, MI
    I'm going to give you credit anyway because you were the one who provided the info to me!
    Feb 2009
    Chiang Mai, Thailand
    Lamont you are the man, even it was used before on other bikes you were the first to find a way around the problem so in my book you deserve the credit. I do have one little problem, I seem to be getting some oil in the new filter as I checked it last night and when I first set it up the filter was white and now it is a shade of gray and I smell oil wonder what I did wrong as I used all the same parts you did.
    Feb 2008
    South Jordan, UT (Salt Lake)
    I am going to buy the stuff tonight to do this considering I had to take the airbox out to do the spark plugs last night. Seemed like a good time to do it. I had a considerable amount of oil in my airbox.
    2008 GS , ISCI Quantum Blue
    Feb 2009
    Have a problem, my breather filter is full with oil to the point it is dripping what have I done wrong help please and it seem that I have a lot more oil in mine with less miles than what I have seen some of you have posted.
    Very Helpful Member bjt's Avatar
    Oct 2007
    Grand Blanc, MI
    Quote Originally Posted by burg650 View Post
    How about a few pictures of your setup. Somebody may notice a problem by seeing how it's hooked up. Hard to tell what might be wrong by just hearing that the oil is saturating the filter.
    Former Happy Spyder Owner
    Just decided it was time to move onto other things.
    May 2009
    Hobart, Tasmania.
    You need to use the real course open cell type of foam. I picked some up from a place that sells rubber hose and fittings. This stuff is supposed to be fuel proof. I cut some off and let it soak in oil for week or two and it looked fine. I've had it in for around 5000km now and checked it. Its still in the pipe and looks the same as the day I put it in there. Ball point pen gives an idea of scale.
    Nov 2008
    WV: Martinsburg
    I'd like to do this just to be on the safe side but I'm about as technically talented as Tool Time Tim. If I buy the items needed, can someone help me install them at the Gatlinburg event?
    If so, what do I need to get?
    Feb 2008
    Quote Originally Posted by irish2themax View Post
    I'll help you if no else helps you out first.
    Feb 2009
    Quote Originally Posted by bjt View Post
    Found out my digital camera is not working so when I can get one to use I will post photos, in the mean time I removes it and clean it all out and replaced the filter with a new one and I went over Lamount instruction again and don't know where I went wrong. The only thing I can think of is maybe I have it backwards where the line from the engine is coming in should be on the other side.
    Jul 2008
    The line coming in from the engine, goes to the side that dumps into the center of the catch bowl. Be sure to plug or seal off the hole in the air box where the line from the engine was. Hope this helps.
    Feb 2009
    Quote Originally Posted by Big Arm View Post
    That is how I have it, maybe I should try the other way.
    Nov 2008
    WV: Martinsburg
    Quote Originally Posted by SpyderGirl View Post
    Thanks SG. I still need someone to tell me what I need? Or should I just get it there?
    Feb 2009
    Why does it make a difference which way you have the lines coming in and why not follow the arrow? I also notices after looking at a few photos posted of some other catch can that the pipe that I have in the middle of mine if much longer as compare to the one I see in the photos, I have since cut mine as well and also when I re did it I decided to follow the arrow before I posted my problem and now see that I should not. So far I have put only about 50 miles and there is very little oil in the can so I have no idea if it is fix or not, I sure do not want to spend $11.99 every few hundred miles to replace the filter because I can't get this right and it keeps getting soaked with oil.
    Mar 2012
    SWEDEN
    hi ....nice mod im from sweden and i whant to do the same on my bike what is the mod you have put on is it
    Water precipitators or is it a oil separators that we have on air compressors? sorry my bad englich
    Aug 2010
    New York
    Default Air Box oil catch
    Here are some other alternatives. Plastic catch is easily emptied.
    Greenville Tx
    So does Lamonster sell a catch can kit with directions for dumies?
    2017 F3 Limited
    Mar 2018
    south africa
    hi planning to fit mine shortly see yours vents to atmosphere , any issues doing this ?? how did you seal air box??
    cheers deon
    pls email me .ddtoit@amplats.co.za
    Quote Originally Posted by ddtoit View Post
    cheers deon
    Though Lamont's 'Catch-Can' works well, it is more complicated and expensive than necessary to get the job done. I also requires maintenance.
    Early on Lamont and I (and others) did a fair amount of experimentation in this area. A lot of different ideas and designed cropped up. Most of them worked. Some better than others.
    If you check out this link (below) it depicts what I think is the best way to go. Simple, inexpensive and virtually maintenance free. Parts are readily available. I can send you a chunk of open cell foam if needed. I also like the fact that it returns the oil to the crank case instead of collecting it in a can to be drained away.
    https://www.spyderlovers.com/forums/...ight=catch-can
    If you do a true catch can as in Lamont's example. You will need to put some kind of filtration (air filter) where it vents to the atmosphere to prevent contaminants entering the system.
    Mar 2018
    south africa
    Thks im happy with info i will vent to atmosphere via crankcase filter and seal off airbox . Makes sense thks
    Cheers
    Oct 2019
    Phoenix, Arizona
    I don’t see one!
    2008 SM5 , Black/purple
