Dual horns - will the factory circuit support a 2nd horn?
Does anyone know if the factory horn circuit on a 2018 f3 limited can support a second horn ? TY
Reason: Removed Prefix - this is not a HowTo: DIY thread... & expanded title to briefly ask the question ;-)
2014 RTL bought in 3/20 with only 6,000 mi.
Came with Garmin 660
Car tires in 5/20; Elka stage 2 front shocks in 10/21
Dual horn kits from Lamonster and Sling Mods work … so I guess the answer is yes.
Love my Spyders
2016 F3L Steel Black purchased 7/16/2016 Sold 3/11/2023 (22,500 mi)
2014 RTS Circuit Yellow purchased 3/2/2018
2020 RTL Petrol Blue purchased 1/27/2023
Girls on Spyders #3195
No more 2 wheels
2020 RTL , Lamonster floor board riser Petrol Blue
I have dual Bad Boy air horns mounted on our F3 models. Wired in a 40 amp relay direct to battery, energized by OEM horn circuit, leaving the OEM horn is "play", too. Followed Kevin Story's lead with using different tones, creating a train horn dissonance. The less load difference one places on the CANBUS system, the better. Also, the switch in the handlebars is not rated for high amperage draw.
pauly1 - SpyderDeb's 'wrench'
IBA #48220 SS1000 BB1500
Depends on total amperage. Keep it below 10 amps, it may be okay.
2014 RTL Platinum
I used a relay kit from Amazon to connect dual horns. I'm not sure it was necessary. But it seemed to be in doubt. This kit switches full power from the battery to the horns via a relay switch activated by the factory horn button circuit.
_________________________________
GR Horst - Reading, Pennsylvania, U.S.A.
Ozzie Ozzie Ozzie
As others have said, if you are looking to add a full blown air horn like Lamont’s 18” long ones, no it won’t support it.
But…….you can certainly use the stock horn wiring and connectors if you replace your stock horn with something like the Wolo Bad Boy. It is designed to be plug and play. I believe Spyderpops description hasn’t been updated to include later model F3. I had one on my ‘16 F3 and now on my ‘21 RT.
https://spyderpops.com/the-bad-boy-h...odels-2015-16/
Harrington, Australia
HeliBars Handlebars
Kenda Kanine rear.
