Results 1 to 10 of 10
    Mar 2021
    LAKE PLACID , FL
    Default Need help with cat pipe
    I bought a cat delete pipe from a spyder member here... It has an extra hanger on it that goes the wrong way. Do I need two hangers on it or can I cut it off???
    It's from a 2016 F3 and trying to put on 2016 F3...
    TJ
    TJRANCH
    2016 F3L
    Durham,Maine
    Do you know the maker, go on there website and make sure it the right one for your bike! That's what I'd do, there may be a funky rubber hanger for that top piece!!
    2012 RTL , Pearl
    Mar 2021
    LAKE PLACID , FL
    Don't know maker .. There is no rubber hanger for it.. Only original hangers for cat.. D0se it really need 2 hangers since it's only about 2 lbs....
    TJ
    TJRANCH
    2016 F3L
    Nov 2016
    Upstate NY
    Cut it off if using on an RT. Not needed. Mine doesnt have the extra hanger. No issues at all.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I installed mine without the third hanger works good on a 2021 rtl
    Jan 2021
    northeast pa.
    what configuration are you going to use, i have one coming tomorrow,, baffle in-out-plug-no plug ..lol
    2020 F3 limited, liquid titanium
    grip puppies
    Bajaron sway bar
    lamonster belt dampener
    battery tender
    19 in freedom tinted windshield
    matte black daytona frunk wrap
    Quadtrac 165/60's
    Mar 2021
    LAKE PLACID , FL
    Quote Originally Posted by fredgal View Post
    Really can't help you.. The pipe I bought must have been some kind of off brand.. Had to cut off extra bracket, then baffle wouldn't work with pipe.
    I did finally get the pipe on and it works... Good luck with yours....
    TJ
    TJRANCH
    2016 F3L
    Jan 2021
    northeast pa.
    Quote Originally Posted by tjranch9 View Post
    ended up with baffle in with no plug in baffle,, sounds great.......
    grip puppies
    Bajaron sway bar
    battery tender
    Quadtrac 165/60's
    Member Jblk9695's Avatar
    Nov 2017
    San Bernardino, California
    Mine was from RLS and yes for some reason the top hanger went the wrong way, so heated it up and bent it in the correct direction and used the original rubber hanger. Works great.
    2015 F3 S , Silver and orange
    Jul 2010
    Las Vegas, NV
    That one uses a rubber donut. Make one out of a car tire sidewall. Picture a rectangle, 2x4”. Bore 2 holes 3/8”. One end on bypass, one end on frame hooks. Measure distance between hooks, bore holes. Slide on. If you don’t have a ruined tire laying around, call me: I have plenty! I can cut you a piece. Joe
    Joe Meyer
