Page 12 of 44 FirstFirst ... 2891011121314151622 ... LastLast
Results 276 to 300 of 1100
  1. #276
    Vermont
    Quote Originally Posted by Tnpapa View Post
    Did the turn on and off 5 times without rebooting trick and the spyder started. Drove it to the dealers and it is in the shop as we speak. 2015 rts se6 with 4100 miles.
    The D.E.S.S. module is under warranty, have your dealership OPEN UP A CASE WITH BRP, and be sure your dealership logs the info. and get a copy of the repair order. So if it happens again ( I hope it does not) you will have a record of it. Also, if it happens again TAKE A PICTURE and show it to your dealership. Then they( dealership ) can say it did not happen.
    The first time I had the D.E.S.S. module replaced was on July 14, 2014, miles on Spyder at the time was: 6,994, the second time that I had the D.E.S.S. module( part # 710004190) replaced was on Aug. 28th, 2014 the mileage was 8,740, and my dealership replaced the Switch( part # 710004413).
    Keep us posted on what happens. Please post on this thread.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
  2. #277
    Invalid Emails
    Nov 2013
    Nashville
    Just called the dealer and he said they reprogrammed the keys and everything looks good. They want to keep it for a few days to see if it does it again.
  3. #278
    Vermont
    Also my dealership reprogram both keys ( that I have) and they replaced the switch( part # 710004413) on my 2014RTS-SE6. Keep us posted on this, good luck! Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  4. #279
    Invalid Emails
    Nov 2013
    Nashville
    Just talked to the service department and since they reprogrammed the keys it has not failed again. They have opened a case with BRP and are awaiting further instructions from BRP. They will replace the module if Brp instructs them too.
  5. #280
    Vermont
    Thanks for posting. I hope BRP tells your dealership to replace the module. If they do would you post the part # for the module.
    The second time when I had the module replaced, my dealership reprogrammed keys. At the same time the dealership replaced the switch.
    I hope you it does not take to long to get the module replaced.
    Let us know what happens.
    Good Luck
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  6. #281
    Vermont
    Has anyone had the" D.E.S.S. Key code "show up on the F3 spyder models?
    If so please post on this thread, I am curious.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  7. #282
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    My new module is on the way.
    I can still get it to reset - BUT I just know that on a long ride 100s of miles from a Dealership it will give up the "Ghost".
    No hassle from Dealership or BRP. Just need to wait forever being on the Left Side of the USA.
    When the fix is made will post the Part #, but expect it to be what has been posted previously here.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  8. #283
    Invalid Emails
    Nov 2013
    Nashville
    Going to pick up the bike in a few. Module was not replaced. Having them print out the brp case number in case I have problems again.
  9. #284
    Vermont
    Quote Originally Posted by PaladinLV View Post
    AJ
    AJ, What are the steps that you use to reset your spyder?
    Can your dealership put a rush on the "New Module" so you are not spyderless?
    Looking forward to seeing your post of the Part #.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  10. #285
    Invalid Emails
    Nov 2013
    Nashville
    Deanna
    TNpapa- I got mine started with 4 or 5 quick turn on and offs without letting the bike reboot per this thread.
  11. #286
    Vermont
    Good Luck! Did you pay for reprogramming the keys?
    Reprogramming the keys is under warranty, the second time that I got the D.E.S.S. my dealership changed the module, and reprogrammed the keys, and I did have to pay, because it is under warranty.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  12. #287
    Vermont
    That is what my dealership said to do, and I posted on this thread. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  13. #288
    Feb 2015
    Las Vegas
    Deanna
    Not Spyderless, still use every day since once it's cleared it will not reoccur for months.
    To reset, if not interference from outside source, I've had to remove the positive lead from the battery and touch it to ground.
    As for "Rush" . . . the word is not in the French vocabulary
    AJ
    Deanna
    2014 RT-S
    2014 RT/S , Black
  14. #289
    Active Member Mike Ard's Avatar
    Apr 2015
    Boise Idaho
    I wonder if given the difference between the RT display and the F3 display my bad key error isn't the same problem as the d.e.s.s error.
  15. #290
    Invalid Emails
    Nov 2013
    Nashville
    Deanna
    No charge Deanna, just without my ride from Monday until today. Had them print out the brp case number.
  16. #291
    Vermont
    Deanna
    AJ
    AJ, I had the module replaced twice with in a month last year. ( July first time, Aug. second time).
    So you did not try " Turning the ignition on/off immediately, do not let the system shut down for 4 to 5 cycles"? That is what my dealership recommended to me when I had the D.E.S.S. Key code show up.
    I think "Rush" should be in the French Vocabulary, then you are not spyderless.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #292
    Vermont
    Quote Originally Posted by Mike Ard View Post
    The next time you get the bad key error on your F3, would you post a picture on this thread?
    The module is under warranty, take a picture and show it to your dealership, then your dealership can not say it did not happen. Also, on this tread their is some excellent info for you take to your dealership. Keep us posted on what happens. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #293
    Vermont
    If you get the D.E.S.S Error again( which I hope you don't) please post on this thread.
    I would like to keep this thread going so new/and current spyder owners know where to look for excellent info. that I/and other spyder owners have posted on this thread. That is good to know that your dealership printed out the brp case # for you. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  19. #294
    Apr 2015
    Boise Idaho
    Here is a picture of when it happened last time.
  20. #295
    Vermont
    Thanks for the picture! Good Luck
    Keep us posted. Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  21. #296
    Apr 2015
    Boise Idaho
    The dealer just called and BRP is going to replace the entire D.E.S.S module this time. I guess last time they just replaced the antenna.
  22. #297
    Vermont
    The D.E.S.S. module is under warranty". Do you have any warranty left on your spyder?
    Would post the part # of the new D.E.S.S. module?
    How many miles do you have on your spyder?
    What year is your spyder?
    Will your dealership reprogram your keys?
    Have the your dealership put in a switch( ignition switch)?
    I had the D.E.S.S module replaced twice on my 2014RTS-SE6 within a month apart. ( the first one replaced in July 2015, and the second replaced on Aug. 2015, and the dealership reprogrammed the both keys, which I posted on this thread.
    Were you stranded when you got the Key code?
    Good Luck!
    Keep Us posted on what happens.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  23. #298
    Feb 2015
    Las Vegas
    Deanna
    The quick on/off never worked for me.
    New DESS module and ignition (part numbers as you previously described) have arrived at Dealership. Took @ 8 days from Quebec. Installation scheduled for Friday Morning.
    I assume (never a good idea - lol) that since I am receiving a New Ignition also, that I will get a new set of keys, nes pas
    AJ
    2014 RT-S
    2014 RT/S , Black
  24. #299
    Vermont
    AJ
    Why did it take 8 days from Quebec to get you?
    With your "New Ignition" your dealership should reprogram your keys( the originals) to your "New Ignition". When I had my 2nd D.E.S.S. module replaced, and my first switch replaced my dealership reprogrammed my keys and gave me a new trailer lock.
    Let me know if you get a "New set of keys" since you are getting a new Ignition.
    Keep us posted!
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  25. #300
    Feb 2015
    Las Vegas
    8 days from Quebec to Las Vegas seems acceptable.
    Beside the only thing that comes and goes quickly to Las Vegas is MONEY!
    Thanks for the info on the key, but that kind of bothers me.
    If the same key is used with a new ignition switch , then that says to me ALL Spyder RTs a Keyed alike and only the DESS module chip is different????
    Confused.
    And if they only reprogram the key and the teeth are the same why do you need a new trailer lock?
    More confused.
    Obviously I'm missing something or can't see the forest for the trees
    Thank Deanna
    AJ
    Keep us posted!
    Deanna
    2014 RT-S
    2014 RT/S , Black
