Results 1 to 12 of 12
    Jan 2019
    Hunter Valley NSW Australia
    Default 622 Trailer wheel hub seal - anyone have the generic part no?
    Does anyone have a part number for the seals in the wheel hub for a 2011 622 trailer aftermarket?
    I found a BRP part number then saw the price which had only 1 less digit . It seems here in Australia we have to buy the whole hub assembly and are unable to buy just the bearings and/or seals.
    2017 RTL
    2017 RTL , White
    Sep 2020
    Platte City, MO
    Can you just get the bearing number and get it from a parts house? You may have to measure the OD, ID, and thickness of the seal,
    but should be able to source those too.
    Peggy and Howard
    Hers: 2013 Spyder ST-S SM5
    Jan 2019
    That will be plan B, I hoped to find all the parts needed before I take it off the road to do the work (i use the trailer for work)
    2017 RTL
    2017 RTL , White
    Feb 2019
    Portland, Oregon
    If you live in a sizeable city, there are many sources that stock bearings and all you need it the number on the bearing and any prefixes or suffixes that indicate if it's sealed. Request US made bearings for obvious reasons.
    There are bearing stores, industrial suppliers, auto stores and more. Bearings are universal, no need to buy from BRP or any mfr that uses them.
    Jan 2019
    I live in a mining region and pretty much anything from anywhere is available. I was able to get the bearing details from others and have ordered them, was hoping to the to do the same with the seals
    2017 RTL
    2017 RTL , White
    Nov 2015
    Chardon, OH
    SKF 14840 and NAPA 14832 appear in this thread. Posts 9 and 16.
    https://www.spyderlovers.com/forums/...ailer-bearings
    Doug
    ”Freedom is not a loophole”
    Mar 2013
    14848 CR seal and L44649 bearing
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Jan 2019
    Quote Originally Posted by PW2013STL View Post
    You're a Legend, thanks!
    2017 RTL
    2017 RTL , White
    Sep 2014
    USA
    Aug 2017
    Australia
    Wink
    Quote Originally Posted by askitee View Post
    Hey mate, how did you get the inner race out? I regreased mine today and the race on one inner side was a bit poor. Have all the bearing and seal numbers from below, just not sure how to move that inner race. In Queensland Australia, so please type slowly, as I don't read very fast
    Dec 2018
    Long Island
    This link may have the information you need. Post #25 has detailed instructions.
    https://www.spyderlovers.com/forums/...r-RT622-owners
    Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
    Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
    2012 RTL SE5 Lava Bronze - 19,675 miles
    Dec 2009
    West Oz
    If it's the cup (inner race) that you're referring to - a solid drift (punch) and a medium sized hammer, working your way around it but at 6 & 12 o'clock positions as your tap it out.
    Or have you done it already?
