Joe and Ann Squared Away my 14 RT-L at Spyderfest.
Had a laser alignment done at a dealer in early April. Kinda watched the dealer techs as they did the alignment and left the dealership less than confident that the alignment was done correctly. Told Ann that I already had a laser alignment done and asked if they would check it. She said sure and that they wouldn't charge me if the alignment was correct.
Ann checked the air pressure in all three tires (dealer didn't), Joe jacked up the rear end and spun the rear tire forwards and backwards to check belt alignment (dealer didn't), Joe and Ann got my input on whether the handle bars were straight (dealer didn't), Joe and Ann included me in the entire process by explaining what they were doing (dealer didn't). Even after having my Spyder laser aligned using the Outlaw/ROLO patented system by a dealer, Squared Away found my left tire toed in and my right tire toed out. What's even more disturbing is that Joe found the outside jam nut on the left tie rod only finger tight. After watching the Squared Away team's meticulous attention to detail and since they included me in the process from start to finish, I'm now convinced my Spyder is properly aligned.
The next day I noticed that my belt had wandered towards the outside of the rear pulley. Called Ann to discuss it and she said to bring it back to them at vendor village. Their busy day was just beginning but they took me in right away and Joe tweaked my belt alignment...no charge. Asked Joe about a intermittent noise (sounded like the brake was dragging in one spot) I was getting from my rear wheel and he recommend cleaning the brake dust off the spring with a tooth brush. Did that when I had my Spyder on jack stands cleaning it following my 1100+ mile ryde home...noise gone!
Bottom line to this rather long post is...if you get the chance to have your Spyder Squared Away by Joe and Ann, take it! I promise you will not be disappointed. They are true professionals that CARE about you, their fellow Spyder ryders.
EXACTLY the same treatment at our Tucson event!! Profeesional, informative and attention to detail worthy of an aircraft mechanic!!! Like I have a completely different Spyder!!
John thank you so much for the kind words. It was a pleasure working on your Spyder and I look forward to seeing you again.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Need my new toy aligned
Hey Ann, we finally took delivery of our 2014 RTS. first one was damaged. Now we want you guys to check the alignment and get us squared away. Any chance you will be coming to southern Cali. (LIke Hemet area)in the near future?
Thank you again for all of your advice when I was trying to decide on the new toy.
David and Liz Neitzke
Originally Posted by Hemet Spyder
Hey Ann, we finally took delivery of our 2014 RTS. first one was damaged . Now we want you guys to check the alignment and get us squared away. Any chance you will be coming to southern Cali. (LIke Hemet area)in the near future?
I'll check my schedule! You are welcome to ride to Las Vegas anytime.
2010 RT- 622
1st on my list when we attend Spyders in the Redwoods is to get Squared Away!
Ann, you are very welcome. You and Joe earned the "kind words". Best of luck to you both. Thanks again for your personal touch while at SF.
Ann you both told me about it at Spyderfest and I watched you at work as well.I wish you both all the very best with Squared Away.
COLORADO
Your Laser Alignment was recommended here on SpyderLovers, I live in Estes Park Colorado. Will you be coming to LOVELAND, Fort Collins or Denver area this summer.
Thank You
Three Wheel Rally in Deadwood
My wife is headed to Deadwood for the Three Wheel Rally July 12-17. Any chance you will be there?
Sent SpyderAnne a PM
Quickest way to get a response is to PM her or Joe (cptjam) Hope to meet you at 3 Wheel Rally...going to be a great rally....
SpyderLovers Sponsor
Deadwood
Yes, we are going to Deadwood!
Joe Meyer
Colorado
Thank You
We go where we are invited. Put together a group, and we will come. Weekends, weekdays, whatever works for your group. Often, we do Friday-Sunday, or Sat-Mon.
Joe Meyer
But how about Atlanta, GA? I think I could wrestle up several folks to do this alignment, but what is the minimum number for y'all to come?
We would need 24.
2010 RT- 622
