Page 2 of 2 FirstFirst 12
Results 26 to 43 of 43
  1. #26
    Mar 2020
    Detroit Michigan
    Does this antenna hookup to anyting? Because I'm having problems and I lefted it up and the whole thing came off plus antenna wire so what does it connect to.
  2. #27
    Jun 2011
    Near Lexington, NC
    Richie: I hope I haven led you astray about the antenna thing. The thread you referred to above were about older bikes and far as I know those problems have been fixed. I only meant that the "loose wire" hanging down might be the antenna....but honestly I have no idea how newer ones are configured. If what you have is indeed the antenna, it doesn't connect to anything; it transmits a signal to the DESS. I'm guessing you have other problems with your ignition. Hopefully someone who knows about these things will chime in and give you better advice.
    Two Wheelers from 1963-2011
    Three Wheelers:
    2011 RT(Red)
    2014 RT(white)
    2016 F3T(red)
    2022 RT current ride(silver)
    __________________
    2016 Slingshot
    2018 Vanderhall
    2019 Slingshot
  3. #28
    Mar 2015
    forrest above Reno, Nv
    I think ( just my @ cents here) that the DESS problems have do do with a faulty " little black box" that is not made by Can Am. Once they got it right ( from an off site manufacture) the DESS problems seemed to have stopped. I have replaced the original ( 2014)with a later one part # 710004916. The old one was made In India and was # 710004190. Haven't had the DESS signal of death in years and feel confident to take my anywhere.
    Lew L
    2014 RTS , Circuit Yellow
  4. #29
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    Lew
    The problem with the 2014 & a few 2015s, dealt with signal saturation.
    BRP was never able to pin-point the problem.
    Some of those that had their Module replaced with the updated version (2015) still had problems and in most cases replacing the ignition cylinder corrected it.
    Some people like me were fortunate enough to have the dealer replace both at the same time.
    Yet some never experienced the problem at all and some just needed the module. I cannot remember anyone just having the cylinder replaced.
    One definitive fact was once the problem appears, it typical goes down hill by becoming more frequent and more difficult to clear.
    By 2016, it seems the problem all but disappeared.
    I have always recommended anyone with a 2014 TRY to get both units replaced as THAT solution is the only one that always seemed to work.
    My problems started at about 5500 miles and was replaced 3 months later. So from @ 8000 to until today no problem, but still hold my breath every time I turn the key.
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
  5. #30
    Sep 2014
    USA
    DESS Bulletin
    Attached Files Attached Files
  6. #31
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by RichieRich007 View Post
    Post pictures of the DESS antenna wire ends. Depending on what they look like. Pulled out of the connector, chewed by rodents. Maybe they can be reconnected or you can order a new DESS antenna.
  7. #32
    Feb 2015
    Las Vegas
    Kind of like closing the gate after all the horse got out!
    AJM
    2014 RT-S
    2014 RT/S , Black
  8. #33
    Sep 2014
    USA
    The DESS antenna mounts to the top of the ignition switch and runs down to the DESS module and plugs in to it.
  9. #34
    Active Member Jheck's Avatar
    Jun 2015
    sherburne, ny
    Quote Originally Posted by Questions View Post
    Hi all,
    I have a 2014 RTS with 4,900 miles and the darn DESS code came up. I was stranded for approx. 20 minutes. I pulled the key out and walked away and then came back to bike and it started. I called dealer today and they initially said they could not do anything unless the code was present. I said that doesn't make sense. They then asked me to continue riding it until the error happens again, then take a picture of the error code. Well someone posted a pic of the error code so I took a picture from this site and I will be dropping off my machine today to get it fixed showing them the pictures. Unbelievable !!!! This is a huge problem and it seems no one cares to much about it. Plus they are telling me its 3-5 days to even get a new module in. There goes another week of no riding.
    Bumblebee
    I’ve got a 2014 RTS also. Had the DESS system problem at about 5 or 6,000 mile the dealer replaced the Module and no problems since. Nearing 24000 miles. The extended warranty has just run out so I’m going to find someone with a buds system that can just shut it off.
    Someone offered to do that a couple years ago, but I was reluctant to do it with the warranty still in effect. Didn’t want to give them any excuse not to cover me if I needed it.
    If anyone is capable of doing this near the central New York area, I’ll pay ya what you need.
  10. #35
    Quote Originally Posted by Jheck View Post
    a couple of years ago a Forum member - Joel The Biker - did mine ...... PM Him and see if you can work something out ..... it took less than 10 minutes .... I think He is located east of Binghamton NY ..... good lucfk .... Mike
  11. #36
    Jun 2014
    Schenevus NY
    Joel did mine too on my ST. Good guy and it literally takes just a couple of minutes.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
  12. #37
    Mar 2008
    Hesston, PA
    Joel also did mine several years ago on our way to Americade in a rest area parking lot along the road...GREAT GUY... Good luck...
  13. #38
    Jun 2015
    sherburne, ny
    I’ve sent a PM to Joel but as of yet have not received an answer. I’ll give it a couple weeks.
  14. #39
    Houston
    I would be happy to help with your DESS but my shop is in Houston and I am in Durango at the moment.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  15. #40
    Vermont
    It is my understanding that 2014 and later that reprogramming was not required, after changing out the DESS, since the key code was stored in the ECM. So your tech should never had to reprogram.
    In 2015 I had the D.E.S.S module replaced twice( I also started a very long thread about the issues that I had with the D.E.S.S ), and the second time the dealership reprogrammed the keys, and replaced the rear trunk lock.
    I have a 2014 RTS-SE6.
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
  16. #41
    Vermont
    Quote Originally Posted by Lew L View Post
    Lew L
    LewL:
    In 2015 I started a very long thread about the DESS module and the issues/problems that I had.
    Since than I have not had the DESS signal of death in years. I also have the part # 710004190.
    I also take/ride my spyder any where.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  17. #42
    Vermont
    https://www.spyderlovers.com/forums/...!!!!!!!!!!!!!!
    The above is the link for the DESS info.
    Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
  18. #43
    Danbury Connecticut
    I haven't had a problem on 2020 after about 4,500 miles and 6 months.
    I know, that's only one data point.
    IBA #47122
    2020 RT Limited Asphalt Grey
