Results 1 to 20 of 20
    Apr 2015
    Tucson, AZ USA
    Default iPod functioning question with 2015 RT Ltd audio
    I've surfed the forum for what I'm going to ask, but I can't find a direct answer. I hope someone can help me, or minimally clear things up for me.
    I have a 5th Gen iPod Nano connected to the audio system in the rear topcase via the iPod/iPhone connector supplied with the bike. The Operator's Manual shows the following:
    I've connected my iPod but so far I am only able to play all of the music on my iPod, apparently in "name" sequence, -OR- select a playlist and then play the music within it, in what appears to be name sequence as well. The Spyder supplied instructions imply to me that I should be able to select by Album and Artist as well as Playlist. I have been completely unsuccessful in figuring out how to select my tunes by Album or Artist. If I'm reading the instructions correctly, I'm limited to the Left and Right buttons on the left-hand controls with either a push and hold for greater than once second or a shorter push. Can someone help me? I'd love to be able to select by Album and Artist as well as by "everything" and playlists.
    Thanks in advance,
    Rob
    Bryant, Arkansas
    i can only chose a playlist and then toggle through songs or play all the songs in a random or by name sequence
    Cruzr Joe
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    My interpretation
    It specifically says IF Playlist, Album, Artist, is selected.
    I take this to mean selected on the iPod!
    In fact if you select Artist on the iPod the control WILL change the artist, same holds true with Album.
    Fact is most peeps select Playlist
    and as you see you can remotely change the Playlist
    AJ
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    May 2011
    Duncanville, Al
    Works as the manual says with my I-phone 4S.
    May 2013
    Stanton, ca
    If you do not have your iPod music setup with META tags to organize them into Albums and Artists and just dumped all your music on the iPod, then you wont have those selections. An example of this is if you just ripped CD's and did not organize them to begin with, then all you really have on your iPod is a bunch of songs with song names.
    Also Playlists have to be made by you in iTunes.
    I had this problem when I first setup my iPod. All my music was untagged and thus just showed up as a bunch of songs.
    It took me a full day to organize it by adding Artist and Album tags to each song.
    I used some programs called MP3 Tag and Media Monkey.
    Bob
    Jul 2011
    Mitchell, Ontario, Canada
    A stated in the "Roadster Command Center Instructions" when not in motion and in the ipod screen, a long press of the set button will give you the screen to select playlist, album or artist. Then from there you can pick each individual song. The default is playlist, I don't know if that can be changed. Every time you cycle off/on it goes back to playlist.
    https://drive.google.com/file/d/0B9z...ew?usp=sharing
    Jul 2011
    Default Took a picture
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default Leave it to Billy to know the answer!!
    Wow! Now there's something that I'll bet not many folks knew! Thanks.
    Unfortunately, I won't remember it very long, because I never use anything except "playlists".
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    May 2013
    Stanton, ca
    By request I made a video showing how to do it. It will be up soon.
    Bob
    May 2013
    Stanton, ca
    By the way... just a comment.....
    I have noticed in the past other iPod "Nano" users reporting an issue getting full control. I know the iPod "touch" works but seems possibly the Nano does not support the full Apple iPod control protocol?
    If you look at the spec for the Apple protocol there are different levels of support!
    Bob
    Apr 2015
    Tucson, AZ USA
    Default This is it!
    Thank you Billy + Thank you to all others that replied and Finless Bob who PM'd me.
    I had never seen these instructions, and I'm pretty diligent about reading everything. This level of detail sure isn't in my Operators Guide. I even purchased the full repair manual. I had no idea about pressing and holding the SET button while at the iPod device screen. I'm guessing I'd even tried that, but you have to hold quite a long time. This did it; I can now select by Playlist, Artist, or Album. Another link for these instructions that's a little easier to read (4 pages instead of 2) is: http://www.knarfoh.com/pdf_files/Quick_Reference_Roadster_Electronic_Command_Center _Can-Am.pdf
    I believe Bob is going to record a video, which will surly help others that may have a similar challenge.
    This may be the answer for those of you that said you experienced the same dilemma as me. What a great group to be part of.
    Thank you!
    Rob
    May 2013
    Stanton, ca
    I knew that was probably your issue. Yes without having the fold out the manual itself is not very helpful.
    Well, my video is going up now so maybe will help others in the future
    Bob
    SoFlo
    This is "the info" in my opinion to understand the functions.
    A couple weeks back, I had the wife take the original to the office store, make copies and cut them into pages. These small pages she then had laminated in plastic so it can remain in the trunk.
    PK
    SoFlo
    7th Generation Nano with Apple interface adapter to BRP cable worked fully for all handlebar switch functions.
    PK
    IIRC, in order to have songs show up in album lists on the iPod you have to have the library of songs organized by album in iTunes before you sync it to the iPod. iTunes will automatically organize the songs by album. You have to manually organize them into playlists in iTunes before syncing.
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    I hate having to play items by a pre-selected order - my Kawasaki Voyager and my Spyder both play the Nano's playlists in the order they selected. But, it you disconnect the Ipod, select a playlist, choose "Shuffle", THEN plug it back in you can achieve a random order. If you select a playlist through the Spyder's menu it will play in order of artist.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    May 2013
    Stanton, ca
    If you hold down the right button (like your skipping to the next song) for 3 seconds or so, it will switch the iPod to Shuffle mode.
    Bob
    Apr 2015
    Tucson, AZ USA
    That's interesting Bob; I'll have to try it. Per the RECC instructions regarding the left/right buttons: "Long press: Select the previous/next Playlist, Album, or Artist as per the last selection in iPod device screen."
    Rob
    Quote Originally Posted by finless View Post
    Bob
    May 2013
    Stanton, ca
    Quote Originally Posted by robhowen View Post
    Rob
    I actually found this by accident. My wife was in the back and did not like a song so she pressed the right button and held it, next thing I knew the album I was on changed and it started playing songs randomly from my first playlist. I was like... "what happened?" Later she did it again so I asked her to show me what she was doing. Sure enough, she was holding the right button waiting for the song to change. Well it changed alright!
    Bob
    May 2013
    Stanton, ca
    FYI I have a 2011 RTS and there have been a few rev changes in the radio since then.
    So it's possible some things I see may have changed or been fixed!
    Bob
Tags for this Thread
