06-15-2015, 10:30 AM
#101
I'm not thrilled about the new fuel stops distances. You are making it impossible for the 998 to go between stations without having to stop to empty a gas can. Not much of a time savings there. If it is windy or uphill I can not make 165 pulling my trailer with the 1330 and I know there is no way that a 998 pulling a trailer can make it.
Maybe we will have to go in two groups, those that can make it and those that can not.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
06-15-2015, 10:41 AM
#102
And another thing, if we are traveling around 55 mph it would take 3 hours to go 165 miles. That is a very long time to be in the saddle, even for someone who rides long distance frequently like I do.
At 55 I might make the 165 distance, don't know as I don't usually travel that slowly but it is still too far for the 998 pulling a trailer.
2010 RT- 622
06-15-2015, 10:44 AM
#103
![Quote](images/misc/quote_icon.png) Originally Posted by SpyderAnn01
Believe me Ann I looked and tried to find all stops within 145 miles at the max. If Rancheria has gas and are open then that leg will be 62 miles and then 100 miles to Teslin. That is the only one that could be 165 miles between gas stops.
Believe me it's not me, but where gas is available that is dictating where we have to stop.
Gary(who lives is BC) pointed out that 7 of the stops I had first planned on did not have gas. This is why I had to create a new list.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
06-15-2015, 10:46 AM
#104
2012 Mileage
I pull a trailer with my 2012 998. There is no way I can make 165 miles between gas stops. Should my wife and I simply plan our own gas stops? I can do about 130 depending on speed and rolling terrain?
06-15-2015, 11:08 AM
#105
From everything I've read, we should drive on the top of our tanks and buy fuel as it's available. I'm bringing a 1-gal can that will ride in my passenger seat. If someone needs it and I don't I'd be glad to share. It can be refilled whenever we stop.
06-15-2015, 11:35 AM
#106
![Quote](images/misc/quote_icon.png) Originally Posted by PrairieSpyder
1 gal may be enough spare for a 1330 but not for a 998. Gas station spacing was a concern of mine when I was planning on going. I think what PW is saying is that's how far apart the gas stations are. Somebody better do some serious looking & planning about gas stops & how much spare you need to carry. For your sakes I sure hope I'm dead wrong! Based on my travel experience I suggest for the 998s you plan on 110 miles max pulling a trailer @ 50 to 55 mph for a tank & no more than 20 miles more for each gal of spare gas.
![](signaturepics/sigpic14672_7.gif)
06-15-2015, 11:36 AM
#107
I am only planning where we stop for gas. Where we stop for food, breaks, pictures, and so forth I have no say, but I have to think that we will be stopping more often that just for gas.
06-15-2015, 11:43 AM
#108
![Quote](images/misc/quote_icon.png) Originally Posted by tbhlaw
This is why I tried to find gas every 140 miles. If Rancheria Lodge has gas then you should have no issue, but plan on the distance to be 165 miles and carry extra gas. There are no other gas stations available between Junction and Teslin (then at Rancheria lodge) which is 162 miles.
06-15-2015, 11:48 AM
#109
06-15-2015, 11:51 AM
#110
![Quote](images/misc/quote_icon.png) Originally Posted by WasWinger
The lowest fuel mileage reported by a member of our troop is 26. I based the 140 mile max based off of that as that would take 5.4 gallons. I don't see anyone with the 1330 needing extra gas since your mileage would have to drop below 30 in order to not make 165 miles on a tank.
06-15-2015, 11:54 AM
#111
BTW based on 26mpg an extra gal would get the 998 182 miles.
06-15-2015, 12:10 PM
#112
![Quote](images/misc/quote_icon.png) Originally Posted by PW2013STL
Pulling a trailer??? With headwind on the Interstate I have been as low as 16 mpg. Best I've ever gotten pulling my non-aero trailer is 24 mpg. From all I've read on SL 26 is on the high end for optimistic planning. But since I'm not going feel free to tell me to butt out!! I just want it all to work out well for you all!
06-15-2015, 12:23 PM
#113
I appreciate your input and fell free to share!
The lowest I ever got with the 1330 was 30 mpg pulling the trailer on an interstate doing 80mph into the wind.
There will be no interstates on this ride and our highest speed should only be 60 so that will help.
I can only use what I am told so if 26mpg is not correct then we may have issues, but it doesn't change the fact that gas stations are far apart on some sections of our trip.
Again - those riding Spyders with the 998 motor should plan on carrying extra gas.
06-15-2015, 03:37 PM
#114
Rancherie Gas
Tried to call the Rancheria Lodge to see if they have gas. Could not get through however. Maybe someone else more familiar with calling in Canada can try. Bought 2 roto pax 1.75 gas cans in case. If you search for Rancheria Lodge Yukon you can find the number but I guess there are country codes and exit codes i know nothing about.
06-15-2015, 03:40 PM
#115
Let me apologize for causing an uproar. I thought the reason for the change was to eliminate extra gas stops, I didn't realize that this is all that is available.
2010 RT- 622
06-15-2015, 03:55 PM
#116
I just call direct with area code and number, just like in the States. Using my cell phone. No need for country codes, etc..
06-15-2015, 04:02 PM
#117
Thanks Ann
06-15-2015, 04:21 PM
#118
PMFJI, but aren't you having a support vehicle or two traveling with you? Can't that carry extra gas? The support vehicle for the Road Warriors ride last week carried a large gas tank and pump with them. Maybe you could do something similar?
Trb-- (Roger)
2022 White Pearl F3T
Spyder States Visited
![](https://www.spyderlovers.com/forums/maps/map.png?states=NJ.NY.CT.MA.VT.PA.MD.DE.VA.WV.NC.TN.KY.OH.IN.IL.MO.AR,NH)
06-15-2015, 04:27 PM
#119
![Quote](images/misc/quote_icon.png) Originally Posted by Trbayth
You are welcome to come drive a support vehicle for us, unfortunately we do not have BRP sponsorship for our ride, like they did last week and the cost of a chase vehicle is more than any of us cared to spend.
2010 RT- 622
06-15-2015, 04:29 PM
#120
If only I could. I just thought I remembered reading in one of the earlier posts that you were going to have a support vehicle with you.
My bad.
Trb-- (Roger)
06-15-2015, 04:36 PM
#121
Gas Planning
"It is what it is" between places that have gas. We will carry gas for both our bikes. Our gas cans carry 1.75 gal. Each. Travelling at highway not freeway speeds we will be close to empty maybe once or twice depending on what is open or closed. But this will be a "go with the flow trip" for us. We also will stop on our own probably more frequently to "top off" and stretch.
We greatly appreciate all the planning and want those who have spent their time on our behalf to know we are grateful to them.
06-15-2015, 04:49 PM
#122
06-15-2015, 04:52 PM
#123
I think it was very good you brought it up. On a trip of this sort everyone needs to be well aware of what you're dealing with. This uproar helps accomplish that! In some ways I wish I was going with you all, but on the other hand in some ways I'm glad I'm not! Have a great trip!
06-15-2015, 04:56 PM
#124
Call to Rancheria
Diect dial to number on Rancheria website through Verizon with ipone did nir work. I now have tried email.
06-15-2015, 05:17 PM
#125
Their website is weird.
2010 RT- 622
