Page 2 of 2 FirstFirst 12
Results 26 to 46 of 46
Thread: gas mileage
  1. #26
    May 2015
    Urbana, Ohio
    I have a 2014 RT Limited and I get an averaged of 35 to 39 mpg with a average of 5 gal per fill up (around 180 to 200 miles per tank). Do not want to run too low in gas (don't like to walk ). Driving normal and hot like an speed demon will give you a better gas milages and driving 65-70 mph on highway is better than 70-85 mph.
  2. #27
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    keep an eye on who is posting what mileage. The new 1330 ACE engines get much better mileage and have a different tank capasity. Most RT owners (998 twin) have disconnected the fuel and temp guages because they aren't that good. When you do this the fuel and temp appear on the panel digitized. They replace the dash guages with outlets or other guages (voltmeters, ampmeters, oil pressure etc). The best way to know is to run out of gas but also know the tank does not hold 6.6 gallons. There is air space and the most I have gotten ,without running out of gas, was 5.4 gals. Also remember the different model 998 twins get different mileages. Mine is an RS
    VERY wise advice for the OP, who stated he had a 2011 RTS. There are folks in this thread talking about their mileage on 2014 RT's, and those are a completely different animal when it comes to fuel mileage.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
  3. #28
    Most I ever put into my tank is 6.45 gallons. That is of course assuming the meter on the pump was accurate!
  4. #29
    Default How To Get The Best Mileage?
    1. Keep your bike in tip-top shape.
    2. Make SURE that your tires are properly inflated.
    3. Present the best possible aerodynamic profile that you can...
    Keep the windshield at a low position
    Don't add stuff to the bike that sticks out into the airflow
    Get the adjustable lower air deflectors, and run with them in the center position
    Don't add a hitch to your bike
    4. Carry the least amount of cargo in the bike as possible; excess weight KILLS fuel mileage
    5. Your right wrist...
    Shift early
    Roll the throttle on gently, and accelerate NO faster than is absolutely necessary
    Cruise at a slower speed... With my 2010, I found that there was a 6 mpg difference between 62, and 72
  5. #30
    Jun 2013
    I don't understand the "run out of gas" concept to see how far you can go.
    Given that you won't know where you will be when that happens . . . could be in traffic, when a semitrailer is bearing down on you from behind . . . it seems to be a less than safe thing to do. Knowing how far you can go by running out of gas only shows how far you could go on that particular tank . . . ryding at highway speeds with strong winds, and cruising down Skyline Drive at 35 MPH on a beautiful day can effect gas mileage by as much as 10 or more MPG on my 2013 RT LTD.
    On my ride to Tucson, and back, there were times I refueled when I could only add two gallons to the tank, because, according to my Garmin, the next gas station was 100 miles away . . .
    Use your Trip A and Trip B functions, and calculate your MPG when you fill up if you need to know your MPG . . . but remember, it will change, based on how you are ryding . . .
  6. #31
    Jun 2015
    Hendersonville, NC
    Default Mileage
    Quote Originally Posted by bensallen View Post
    I know the Spyders aren't known for great gas mileage and I just got mine today so a couple of "Newby" questions, so be kind please. LOL I read that the tank holds 6.6 gallons. When I picked mine up it was near the red on the gauge. It would only hold about 4.7 gallons before the pump shut off. I rode quite a bit after that and the gauge got back down to the "red" and I filled up again and, again, it only took about 4.5-4.7 gallons to fill up. I had ridden only about 120 miles. Questions,,, is that normal to only take that little to fill up? Is there that much left in reserve? I feel like my mileage sucks but then again my trike only has 2200 miles on it (2011 RT-S) so it might not be completely broken in. I hope that when I get used to the proper shift timing my mileage will improve. What are you guys and gals getting?
    I have just under 2000 on my 2014, semiautomatic & am getting about 32 mpg. That's mostly mountain riding, so I feel that's pretty good. When fueling don't put the nozzle in very far & you can put more in than the automatic shut off allows.
  7. #32
    Very Active Member dlby's Avatar
    Nov 2014
    Indiana
    I have a station close to home
    Pushed the limit as far as i dared last week
    Was sble to actually put 5.4 gallons in
    Normally its 4.6 etc
  8. #33
    Mar 2016
    Punta Gorda, Florida
    Default Gas Milage
    brought my first Spyder a week ago three rides have taken my about 250 miles, kinda short but waiting on mods as i'm handicapped. My 2012 Spyder RTS with 998 is averaging 26.7 mpg with mixed city / highway miles.
  9. #34
    Jan 2015
    Outside L.A.
    Since this thread was picked back up... i seem to only get about 150 miles on my 15 RT. I am hoping it improves as i only have around 850 miles on it so far. Also the tires were fairly low so hoping the increased pressure helps to get me to 200.
  10. #35
    Quote Originally Posted by Stranger1759 View Post
    So what is your trick get to get the most MPG?
    Always shift @ what RPM?
    Avoid speed's over what MPH?
    Any other thoughts?
    I know that RPM, shift points etc... depend on motor size and transmission variable's.
    For the Record:
    9746.6 miles
    248.067 gallons
    39.3 mpg overall average.
    Best:206.6 miles 4.762 gallons: 43.4 mpg
    Worst:163.9 miles 4.628 gallons: 35.4 mpg
    I run with the windshield JUST off of it's lowest possible positioning, and I usually keep my adjustable air deflectors (BRP's) in the center position, so as to reduce aerodynamic drag.
    I shift at no more than 2,500 rpm when getting into 4th, 5th, and 6th.
    I usually set a pace of 53 mph on two-lane roads, and 63 mph out on the four-lanes...
    I also run 93 octane fuel, and I set the tire pressures at 20 psi up front, and 25 psi in the rear.
  11. #36
    Dec 2014
    Lee's Summit, MO
    Shift early
    For the Record:
    9746.6 miles
    248.067 gallons
    To get the best gas mileage, I make sure to plan my trips so I am always going downhill with the wind to my back.
  12. #37
    Default GAS MILEAGE FOR 1330
    Quote Originally Posted by latony007 View Post
    #1., at around 2,500 mi. it will begin to improve........#2. "fairly low" & "increased pressure" are useless terms...........#3. "only get about 150 mi. on my RT" ????.....I think you mean before you REFILL IT ???.... This is not telling you How many MPG's you are getting............See Hayfield's post above on how it's done................None of what I just said was meant as any sort of SLAM..............Mike
  13. #38
    Active Member Scotts8826's Avatar
    Jun 2014
    Kansas
    Short answer: The gas mileage stated by the OP falls into the typical range for the model and year of his RT.
  14. #39
    Jan 2015
    Outside L.A.
    i hear you Mike, #2 was about 15-16 in the front and about 23 in the rear, increased to 20 in the front and 28 in the rear. #3 no i mean 150 miles before all the bars are gone and i start getting worried about finding a station before it goes belly up. I cant remember exactly what i put in it but it was around 5+ gallons, i know it was the most i have ever been able to put in it since i got it having never run it down to zero bars before. And thats me running with the stupid ECO mode on pretty much all the time. I try to shift around 3-3500, i know it wants you to shift a little earlier but i dont like it that low.
  15. #40
    Quote Originally Posted by kngfsh27 View Post
    It couldn't hurt...
  16. #41
    Bossier LoUiSiAna
    http://www.pure-gas.org
    Im no expert but ive found Ethanol free will get you better mileage Rpm range 4k-7500. Seems to be sweet range on the 998's
    I wasn't there but I still care! POW /MIA VETS
  17. #42
    Jun 2014
    Southern New Jersey
    After reading everything it seems to me that every fuel gauge is different. On my 2013 RTL the fuel gauge was horrible. When it indicated that I was just about empty I still had a half a tank of gas. When I got my 2015 the gauge seems to be pretty accurate. Of course I am not getting anywhere near the millage the manual says i should get, but it is a lot better than the 2013. I go by approximate millage from my last fill up as well as my gauge for fill ups. I have less that 1K miles on my 2015 so I expect a lot better millage as the season goes on.
  18. #43
    Feb 2013
    Louisiana
    I tanked up today and rode 180.3 miles to empty. I set my cc at 72mph.
    At 134 miles: 2bars and low fuel light
    At 154 miles: Zero bars, low fuel light
    At 180 miles: engine s/d, flipped kill switch and coast to shoulder.
    I was carrying 1.5gal in a 2gal can in my left saddle bag.
    I simply wanted to eliminate the anxiety of low fuel light and confirm bike range at hwy speed.
    Keep 3 Down..!!!
  19. #44
    Jan 2016
    NZ
    I've got a 2012RTS, I ran it to the point where it died on me. I managed to 70km when the light came on. I also worked out that I can get 35km per bar. I disconnected the old fuel and temp gauges and replaced them with a voltage and oil pressure gauge. I also use 98 octane.
    Sent from my HTC_PN071 using Tapatalk
  20. #45
    Default OCTANE
    Quote Originally Posted by Glenn B View Post
    Well that's 11 points more than it needs .....but it will run on that...............IMHO using any gas gauge to determine how far you can travel on the amount you THINK is in the tank is foolish......Especially where you live if you are in the " outback "..........good luck......Mike
  21. #46
    That sure beats walking uphill in four feet of snow, in a blizzard at 10 below zero, to and from school back in the 50's.
Tags for this Thread
