Results 1 to 17 of 17
    May 2012
    pa
    Default Stripped T-40 and T-45 oil drain plugs
    I was attempting to do the 1st oil change on my 2014 RT and ended up stripping both the T-40 and T-45 oil drain plugs. I don't know what they used to secure the plugs but now there is a nice round hole where the T's fittings were. The plugs would not loosen. Anybody have an idea as to how I now remove the plugs, other than taking it to the dealer?
    Jul 2010
    Las Vegas, NV
    Default Yep
    The one is an Allen the other a torx. Try beating them in with a hammer. Normally, just the first mm Is ruined. Get it in( use a metric Allen socket) with a hammer, and replace with a dimple drain plug. Horrible design!
    If you can't remove, use a chisel first, then an easy out. Replace plug. Call me if you get stuck. Joe
    Joe Meyer
    May 2012
    pa
    Quote Originally Posted by cptjam View Post
    Joe, thanks so much. The service manual say's they are both T's, that would explain my problem. I guess you can't believe everything you read.
    Jun 2013
    queens ny
    if your really not a shade tree mechanic i would think your best bet would be to have a shop do it for you. it will most likely need to be heated to get it out. the one thing i have found out about the bikes is, they don't use the best of bolts to put it together. i have stripped a few bolts so far. good luck
    Dec 2012
    Murphy, NC
    Default Drain Plugs
    Depending on how quickly you need to change the oil and if you don't have replacement plugs, I would order magnetic hex plugs that allow you to use a socket wrench. several companies carry them. I ordered mine from goldplugs.com.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Pre-order your replacement plugs...
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Thread sizes
    What are the thread sizes so I can get them pre-ordered?
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
    Jun 2013
    NE South Carolina
    Quote Originally Posted by LJspydee View Post
    http://goldplug.com/#plugfinder
    Use 2014 RT for selection
    Default Varies...
    most common are the M12x1.5 and the M14x1.5 The oil on the threads tends to crystalize like varnish (the original loctite) and the best way to get them out is to beat on them to break up the seal. Next steps are like Joe said. Try beating in a socket drive allen or torx that way you break the seal and have a good shot at getting them out. But as mentioned have some replacements on hand.....
    First, I have no financial interest in Dimple Products Incorporated, and second, I have no axe to grind with Gold Plug LLC. That said, the Gold Plug LLC 14 mm magnetic drain plug, MP-02, listed in their plug finder as the one for the Rotax 1330 engine is NOT the same as the BRP OEM M14 x 1.5 engine drain plug or the Dimple engine drain plug. The only thing all three plugs have in common is size, 14 mm. If one attempted to use the Gold Plug MP-02 plug I doubt it is long enough to fully engage the threads in the oil sump. The Gold plug does not accommodate the O-rings required for the OEM and Dimple plugs. Try it at your own risk. Dimple can charge what they do for the pair of plugs because to the best I can determine they have the corner on the market, for now. JMO.
    Do you have a link and/or part numbers available for the Dimple products?
    Jun 2010
    Las Vegas
    Just changed out a friend's plugs yesterday to dimple. Here is the link to their website. http://magneticdrainplugs.co/canamspyder.php
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Thanks!
    (How is Joe's Bike? )
    Jun 2014
    Schenevus NY
    There have been numerous threads here over the years about these drain plugs with people announcing theirs are Torx or theirs are allen. I've come to the conclusion that it could be any combination of the two depending on what was in the parts bin that day during engine assembly.
    Your best bet is to replace them with either the Goldplugs (what I did) or the Dimple and not stress over it. If you later take the bike to the dealer for an oil change they may complain about the change and make noises about voiding warrantees. IANAL but they would have to prove that the drain plug change actually caused whatever warranty issue you're claiming.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    May 2012
    pa
    I finally I got both plugs removed with a lot of brute force. Using a combination of heat and taking Joe's advice, hammering in a 6mm hex into the T-40 did the trick. You are correct, the Gold Plug is too shallow to catch the engine drain thread. The BRP plug is about 2 inches with a couple of O-Rings. I just ordered a set from Dimple.
    Danbury Connecticut
    Quote Originally Posted by Trbayth View Post
    With all due respect I have to disagree.
    My dealer was ABSOLUTELY DELIGHTED that I changed to the hex head dimple plugs.
    They were pleased as punch, and then ordered a set for their own bike.
    IBA #47122
    2020 RT Limited Asphalt Grey
    Jun 2014
    Schenevus NY
    Then count yourself as a very lucky person with an awesome dealer.
    Who's your dealer? Might be worth a trip up to CT for me if I do need something.
    Trb-- (Roger)
