Results 1 to 15 of 15
    Very Active Member Star Cruiser's Avatar
    Jan 2008
    Wasaga Beach, Ontario
    Default Left Side Bag Release
    I am having trouble opening the left side bag. I have to pull the release button (on the back compartment) very hard and press on the bag with my hip to release.
    Is there an adjustment to tighten the release cable or adjust how tight the bag seals to the main plastic?
    NE Illinois
    Quote Originally Posted by Star Cruiser View Post
    I just had the same issue. Yes, there is some sort of cable adjustment but I had the dealer do it. The work was covered under the warranty.
    MEP
    ​2019 F3 Limited
    Jan 2008
    Quote Originally Posted by MEP View Post
    Thanks,
    I am bringing my 2012 RT-S into the dealer tomorrow for an oil change so I'll ask about having it adjusted while I am there. Thanks too, for the Quick Reply. (I have the extended warranty, so don't expect an issue
    Same here. The RT goes in on Tuesday for a warranty fix.
    2010 RTS-SE, Orbital Blue
    Sep 2009
    illinois
    Thanks,
    I'd be careful, because if they fix it under extended warranty, they may charge you the $50 copay.
    May 2013
    Stanton, ca
    You can adjust it yourself pretty easy.
    Bob
    RT-S PE#0801 timeless's Avatar
    May 2010
    Punta Gorda, Florida
    Default BE Carefull
    Quote Originally Posted by finless View Post
    Bob
    Be carefull removing this particular piece of tupperware. The tabs are rather brittle & break off quite easily!!!!!
    Yup! I snapped one of mine...
    But the good news, is that with eight bolts holding that panel in place; I doesn't seem to affect anything!
    Bob,
    thanks for the picture!!
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Bob,
    I broke 2 off my old RT I just drilled a hole opposite. where the bolts went in and replaced them with Zip ties once they are pulled tight they. Hold the panel as secure as before
    If fact it makes it easier to remove and refit it if you need to
    Eddie Sheppard
    Poole Dorset UK
    Get a Spyder - See the World
    Sep 2014
    Fayetteville,NC
    In the picture above, I believe Bob did as I did and removed the three short screws from the black lower piece that includes the "mud flap" to get extra room to the adjuster. Otherwise I could not quite get my fingers around the adjusted.
    May 2015
    TX
    Default Video for this somewhere ??
    Quote Originally Posted by timeless View Post
    I need to adjust both sides...I have know idea where to start, no time to take to dealer.
    May 2013
    Stanton, ca
    Quote Originally Posted by Diamond Dave View Post
    Go to this video at 4 minute mark and I show you what screw to remove to remove the rear panel. Ignore the removal of the trunk lid.
    Bob
    May 2015
    TX
    Default Thanks guys !!
    Bob
    All I have to say is you guys rock !!! after watching the video, took apart the bottom cover got right to the adjustment , which did not want to turn..... it works smooth as butter now ,
    Thanks again !
    Blessings
    May 2013
    Stanton, ca
    Glad you got it resolved!!!
    Bob
    Jul 2016
    Winder, GA
    I had a little time this morning, so I removed the necessary panels and made the adjustment on my left side bag. Worked like a champ; I am now a little happier.
    2014 RT Limited , Stock Cognac
