Results 1 to 8 of 8
Thread: Satellite radio
    May 2015
    East Northport
    Default Satellite radio
    I am thinking about buying a Rt spider and would like to add a gps and a satellite radio Like I have on my GL 1800 dose anyone have a suggestion on how to do this, if can be done. This my first post any information will be appreciated
    Thank You
    Sep 2014
    USA
    If you buy the RT Limited it comes with a GPS..
    Franklin, NC
    I have both on my RT. You'll need to have the entertainment harness.
    The RT Limited does come with a GPS installed... one down, and one to go!
    Satellite radio...
    Two choices: BRP, or the cheap method.
    (I chose CHEAP! )
    If you buy a 12 volt XM receiver (I got the XM Onyx), you can make a spot for it in the top trunk; next to the plug that'll hook you into the "infotainment Center".
    You'll just need to have the patch cord that allows you to tie in an MP-3 payer; NOT an I-pod.
    Mount the antenna in the top of the trunk, plug in the power system, and output from the XM receiver, and you're in business!
    Mar 2015
    Advance, NC
    I just installed satellite radio on my 14 RS-S, its in the fronk and I used the water proof? Audio from big bike parts. I had to filter the noise out of the 13.8 socket line with a home made noise filter. I used a bridge rectifier with a filter cap in a large pill bottle. The antenna is stuck on the clutch reservoir plate. I also use a cb hand held from the fronk with my left over Goldwing head set when riding with radio people.
    Vermont
    I have a 2014RTS-SE 6 and I have a Sirus X-m in my car. Sometime in the future I would like to have the Sirus x-m on my spyder. Any thoughts or suggestions Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Mar 2012
    Florida Space Coast
    I had both but on by the dealer when I bought my 2011 RT.
    Invalid Emails
    Aug 2013
    Default Mounts for your GPS and Satellite Radio on your Spyder
    Quote Originally Posted by J48cruiser View Post
    Thank You
    Hi,
    Take a look at this link. http://www.leadermotorcycle.com/spyd...?sort=alphaasc - All kinds of mounts specifically designed for a Spyder. Mounts for phones, GPS and Satellite.
