2012 spyder rs sm5 clutch noise help!!!!!!
I have a 2012 spyder rs sm5 with 2500 miles. I have noticed a small noise that is in the clutch area. When I put the bike in Neutral and disengage the clutch I get a gurgling noise like something is loose and shaking. You can feel the vibration throughout the bike. If Engage the clutch lever the noise and vibration goes away. I've replaced the clutch thinking it might have been warped clutch plates , and the noise is still there . If anyone could help me it would be greatly appreciated
Tough one..!!
Have a 2012 RS sm5 as well. They all have a different sound with the clutch in and released when in neutral. Depending on oil type and condition this can vary. If you went as fas as changing the clutch package you must have a serious noise. I have 27,000 miles and the noise difference is only noticeable but not bad. The only other part would be basket and bearings....
It's normal.
I also hear the same. When u pull the clutch in goes away.
Asked the mechanic about it 2 yrs ago.
Mine changes w different speeds. I too wondered about the noise.
Thanks for the responses !! It makes me feel somewhat better I forgot to add that you hear a minor tap .
Has anyone else had similar issues ?
