Results 1 to 15 of 15
    Mar 2013
    Enfield, CT
    Default Frunk open - latch stuck in closed position
    Help!
    My frunk is open, but the latch is stuck in the closed position (my son was playing with it while it was open). I've tried the obvious but it did no good (pushing down and turning the key and using the electronic button).
    I thought about beating the child but figured that might make me feel better but wouldn't fix it (and I'm ignoring the fact that he's nearly my size and would probably kick MY butt).
    Any help would be greatly appreciated!!!!
    Thanks,
    Gary
    2012 RT Limited
    So the lid is open, and the latch is locked? Is that it?
    If that's the case; just take a string or a zip-tie, make a loop around the latch... Put some upward pressure on it, and hit the Frunk button.
    Unless the lid is closed. .. Then I've got nuthin'...
    Mar 2013
    Enfield, CT
    Yup, you've got it right. I tried pushing up on it with a screwdriver while my son pushed the button, but no luck!
    Thanks though!!!!
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by GMac View Post
    Help!
    Thanks,
    Gary
    2012 RT Limited
    Pull on the tab where the wire is connected it will open the lock I have a cord connected to there to open the trunk with out the key
    Default Not sure..!!
    but if you have the electronic opener you will have to actuate the switch indicating the frunk is closed before the swithch will open. If you have or see where the cable hooks to the latch you can push that to open the latch...
    Default OPEN THE FRUNK
    Quote Originally Posted by jtoro1 View Post
    ..............While working on the Spyder with the "FRUNK "off I've had to do this a number of times.........Mike
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Help!
    Thanks,
    Gary
    2012 RT Limited
    All you have to do is pull the lever toward the left side and it will unlatch.
    THAT's what we needed; a picture!
    Thanks, Doc!
    May 2013
    Stanton, ca
    Bob
    Mar 2013
    Enfield, CT
    Default A HUGE thanks to everyone!!!
    A huge thank you to everyone!
    I wasn't able to find the button some described, but I found the cable and by pushing down on that at the same time as pushing the button that opens it, it popped open easily.
    I genuinely appreciate the help!!!!
    Gary
    Help!
    Thanks,
    Gary
    2012 RT Limited
    Now; I guess you can go have that "discussion" with your Son...
    Bossier LoUiSiAna
    Nxt time the son gets stuck (inside) >. Lol
    Jul 2013
    Villanova, PA
    Default Stuck Frunk---to Doc Riverside
    Will this method work on a 2014 RT Limited?
    ]All you have to do is pull the lever toward the left side and it will unlatch.
    [/QUOTE]
    Jul 2013
    Villanova, PA
    Default Stuck Frunk
    Bob: Will this method work on a 2014 RT Limited?
    Quote Originally Posted by finless View Post
    Bob
    May 2013
    Stanton, ca
    Quote Originally Posted by odyssey009 View Post
    Yes, the only thing different on the 2014 is it is missing the electronic release solenoid but the mechanics are the same.
    Bob
Tags for this Thread
