Originally Posted by JerryB
Hi Voyager,
Re: Right now having just bought the bike money is tight so 400+ for them is probably out of the question now.
But, but you said: Will talk to the wife see what she wants todo!
Jerry Baumchen
PS) And I think this man knows how to stay happily married.
Yeah yeah yeah. I will say I am still in shock of her saying yes to buying it in the first place. But for sure 400 bucks is out but 135 may be doable at this time. But will see what she wants to do as it is HER bike.
And yes If momma aint happy, nobody's happy!!!!
Patrick Sharon
2020 F3 Limited Black/Chrome
2021 F3 Limited Liquid Titanium/Dark
Columbus, OH
She would be happier with the Seal. Too bad you don't have someone around with both on. Many fans here of Seal Pups or DLX. I haven't read anyone mentioning using IG floorboards...just saying
I like the looks of the SEAL a lot. Just not the price tag! and I know SHE doesn't. May just hold off for now till she gets used to riding. Ultimately it is here decision as it is her bike! :-)
Patrick Sharon
Columbus, OH
Patrick Sharon
Columbus, OH
Oh I know. Just ask my wife how much I have spent on my Voyager! And I quit going to the dealer for my motorcycles due to the costs. Do as much as I can myself and with the help of friends. $70 an hour labor charge just SUCKS!
That is a little more than 1/2 of what labor may be on a spyder depends on the dealer Unfortunately the BUDS computer hook up to the can bus is necessary for some things if you get codes. Proprietary to the dealer only.
Hello Voyager,
I saw some red closed web boards on e-bay for $300 a couple weeks ago. You may want to check that out..?
Good luck, Bill
Originally Posted by bbodah
Hello Voyager,
Good luck, Bill
You can buy my boards for $300
WTB Seal Boards 2010 RT-S SM5
Hello Voyager,
Good luck, Bill
Actually was contacted by user sledhed via PM. He had a set of seal boards and made me an offer I couldn't refuse for them. Payment sent and he will be sending them to me today!! Thanks Darin!!!
Appreciate everyone's help here!!
Patrick Sharon
Columbus, OH
Well Sledhed made me a deal I couldn't refuse on some Seal Dlx floorbards. I got them today and they are now on. The wife is looking forward to getting out to ride with them!!
Patrick Sharon
Columbus, OH
Originally Posted by Magdave
Dlx Seal( not for sale but a pic for you) That $400 price is a good one. If your looking for cheap farkles for a spyder you won't find them , unfortunately.
Do you have a better picture of your brake pedal? We got the seal boards and put them on now it seems like we need to raise the pedal a little to be able to push it down all the way. Also where did you get it from?
Thanks!
Patrick Sharon
Columbus, OH
SEAL FLOORBOARDS
Thanks!
Unless the boards are DAMAGED / BENT the OEM brake pedal doesn't travel as far as you might think........If the model floorboard you bought is different from the Spyder you have that could be an issue..........However it is very easy to check........Have someone with a flaslite help you.....Place a narrow sturdy stick on the brake pedal so it goes out towards the edge of the floorboard....then stand on the stick and the other person see if the stick lays flat against the floorboard ( it shouldn't ) ....if it does ,something is wrong. You are not getting MAXIMUM braking this way.......An easy solution is to shim up the RUBBER PAD from the arm and /or adjust the arm at the attachment point ..........good luck......Mike
Thanks!
TricLEDS
http://www.tricled.com/TricLed.com/P...__Mudflap.html
scroll down 2nd item on that page. I felt the same way and their pedal has a spacer
Originally Posted by ndspyderlover
you are missing the shim that goes under the brake pad
Does that shim come with the boards??
Patrick Sharon
Columbus, OH
Patrick Sharon
Columbus, OH
The boards came off a 2012 RT-S but from looking at Seal's site they don't list different model years.
Guess I am not picturing what you are referring too with the stick....
Ignore the shim comment get the pedal I posted and you will be happy. All year seals are the same. They do not come with a shim. If you REALLY need it some washers work but I doubt you will.
STICK DEVICE
Sorry I am not fully picturing this. You really don't need to be so rude in your response here. Don't really appreciate that type of attitude just from me saying I couldn't picture what you were saying.
Patrick Sharon
Columbus, OH
seal floorboards come with a shim (block) that goes under the brake pedal. If you bought yours used you may not have received it.
I did buy them used so must not have received it. Will reach out to them and see about getting another shim. Thank you.
Patrick Sharon
Columbus, OH
I stand corrected here is an install PDF. 2012 and up DID come with a shim. If you contact Seal I am sure you can get one.
http://www.sealfloorboards.com/images/RT_ii.pdf
