limited budget
Limited budget witch wound you install at Spyderfest a sway bar ,cat bypass or baker air wings and why?
Swaybar and an alignment. Handling is important.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
DIY
DIY and you can have them all.....
jmho
dan p
SPYD3R F3-S
AGREE!!!!!
If you have a limited budget, you should buy a Honda or Suzuki. These Spiders are expensive and the "Farkles" are even more. If you had to make the choice a Ron's sway bar is a no brainer.
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Sway bar is my vote. An alignment while you are there is another option hard to pass on.
There you have it..
most bang for your buck..but as SPYD3R stated you can do these installs yourself or with friends and get them all or at least more than one. but if you still have to choose..BajaRon Swaybar and hiem joints...
I can not disagree that handling isn't important but for me on '13 RT-L heat was the issues, I opt for the cat-bypass if you to are having heat issues.
This was just a question, I agree the sway bar by Ron is one best and maybe first thing we should do. This is our third spyder 2010 RSS,2012RTS,and the first two have Ron sway bar and now a 2014 RTS SE6, we will be having the sway bar installed at Spyderfest.
I'm going to say Air wings just to be different! you did not mention anything about LED's? Would consider those before sway bar or cat bypass.
Sway Bar
AJ
