2014/2015 heat
I've been reading a lot about the issues the '13s had with heat from the cat. Was this addressed and fixed for 2014 and 2015 or is the cat delete still recommended? Also, anyone on a '14 or '15 notice any heat transfer up to the driver and passenger running dead stock?
This is absolutely a non-issue for the 2014 and later RTs...
Cat delete did not fix the the 13"s. There were many other problems.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
Not a problem...
they did take care of that but you can still do the cat delete. Pipes are available for this. Some do it for the weight or sound and it will still help with the heat..
No heat issues with the 2014 - no gas smell - evap canister has been moved
Regardless of what type or style of spyder or other motorcycle that you ride, you are sitting on top of a motor that generates heat. The 14s and up have really addressed the heat issue and have pretty well nailed it so that there is minimum if any heat issues. But you are still sitting on top of an engine and there has to be some heat.
Cruzr Joe
Cruzr Joe
Joe,
I get far more heat from the passenger seat than I ever got from the motor, but that's not Can-Ams' fault
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Ha! Nice one, Joe!
Thanks everyone! I am no stranger to heat. I have ridden big V-twins most of my life. And now, in this second act of my time on this planet I need to be careful of heat and becoming overheated due to the MS. So I look for work-arounds if heat is present in any situation. On a bike the answer is simple: just go faster! lol I just didn't want to cook at a stoplight. I am better served raw! Thanks again, everyone! This is one of the more polite and informative forums I have ever been on. It's good to see, glad to be here!
Originally Posted by PW2013STL
Joe,
My 14 has no heat issues at all, they really did it right this time.
Cooler ride
I have a base model '14 RT and have no heat problems at all (previously owned an '08 GS with heat problems). One of the biggest advantages of the 2014's/15, is the split front radiator, moved forward from the '13 position, which have a reverse fan. The fan draws air in while moving, but when you are stopped in traffic, the fan reverses and blows the heat away from you. The fans are loud but you stay cooler
2020 RTL SE6 Asphalt Grey
2014 RT SE6, Pearl White 57k (2014-2020)
2008 GS Premier 17k (2012-2014)
No heat issues with the 2015
Thanks all! I have to be careful with heat nowadays. I feel much better now!
Joe,
You must be married to my wifes twin.
Ha! Nice one, Joe!
The 14s and up in the RT series are great.
Cruzr Joe
2016 RTS Special Triple Black, BRP Freedom Trailer, Spyder Pops Rear Lighting Kit, Spyder Pops Full view Turn Signals, Trunk Light, Rivco Highway Pegs. Doc's Spring Tensioners, Trunk Organizer, Magic Mirrors, Foam Grips, back to Stock Windsheild, Lamonsters cat delete, Bajaron sway bar, More Farkles to come !!
Don't
put any candy bars in that little glove box in front of the seat.
Even when you think it is cool enough to not melt your Milk Duds, it is. But you could hear your lunch in the glove box on a hot day if you needed to
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
