Page 1 of 3 123 LastLast
Results 1 to 25 of 61
    Default Gates Krikit II Belt Tension Gauges
    These Krikit II gauges are very accurate and quite handy to have. I get a lot of requests for this gauge but I can't always get them for a good price. I recently got a good deal on them so I'm making them available for $18.00 shipped.
    There is a great little video I've attached showing how this gauge works. This is the heavier gauge designed for the flat belts we run on our Spyders.
    There is just one gauge labeled by different companies. The video is of a Dayco gauge but it's just a relabeled Gates gauge (which is the one I have).
    I can ship these worldwide for a bit more.
    Very Active Member oldgoat's Avatar
    DDO, Montreal Island
    Ron
    Hopefully you have some tension #s filed away.
    What should I aim for on my '08 GS with all 3 wheels on the ground? I recently replaced the belt due to a stone/something hard hole.
    og
    2008 GS SM5, Full Moon Silver
    2007 Piaggio MP3 - 250cc
    Quote Originally Posted by oldgoat View Post
    Ron
    og
    160-180 # for that belt.
    Many thanks
    All PM's/Emails have been replied to. Ordered gauges will be shipping out today. Thanks!
    Default Thanks..!!
    thanks for the video and making the belt tension guage available to us. you have great stuff for the members here...
    I've gotten some emails about international shipping costs for the Krikit II Gauge.
    Shipping by USPS 1st Class Mail to;
    Canada - $2.50
    Everywhere else in the world - $3.95
    Shipping by USPS Priority Mail to;
    Canada - $19.00
    Everywhere else in the world - $23.00
    I've gotten a lot of inquiries about setting the proper belt tension with the Krikit II. This tool is simple, very easy to use and quite accurate when done correctly. But you need numbers!
    Doing some research and crunching/converting the values (Newtons to Pound Force) this is what I came up with. The original Newton specs. came off of the Internet. You should check your owner's manual to verify my numbers.
    Tension values for the 2013-2015 Spyder Belt are higher than for the 2008-2012 Spyders. I did not calculate 'Wheel on the Ground' figures for the 2013-2015 models as they will exceed the 330 lb. measuring limit on the Krikit II gauge. 2013-2015 Spyder owners will need to raise the rear wheel off the ground to get an accurate belt tension measurement with the Krikit II gauge.
    998cc All Models (2008 - 2012) Min Spec Max
    Newtons - Wheel Elevated 300n 450n 600n
    Pound Force - Wheel Elevated - Krikit II 67 lbs. 101 lbs. 135 lbs.
    Pound Force - Wheel on the Ground - Krikit II 130 lbs. 160 lbs. 190 lbs.
    998cc All Models (2013-2015) Min Spec Max
    Newtons - Wheel Elevated 900n 1050n 1200n
    Pound Force - Wheel Elevated - Krikit II 202 lbs. 236 lbs. 270 lbs.
    1330cc All Models (2014-2015) Min Spec Max
    Thank you for taking the time to post these numbers
    Very Active Member DR Buck's Avatar
    Apr 2012
    Fauquier County VA - Virginia's most carefully pronounced county.
    Thanks for posting this conversion Ron. Long over and glad it's here. Maybe it should be posted in the "shop talk" board as well.
    2012 RT Limited - Pearl White
    My Mods -
    http://www.spyderlovers.com/forums/showthread.php?39494-DR-Buck-s-2012-RT-Limited-Mods
    2012 RT Limited , Full size brake peddel White w/Red Highlights
    Quote Originally Posted by DR Buck View Post
    I am hoping that once a number of riders get these Krikit II gauges that they can confirm my numbers.
    Jan 2013
    lancater ohio
    Ron you are the man!!!! Thank you so much!!!
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Ok Ron how did you do it? Went to use my old Krikit today to check my belt tension and it no longer goes 'krik' when I press down on it. So time to order a new one. Just can't understand how you jinxed from that distance:-)
    Quote Originally Posted by PistonBlown View Post
    Takes Years of practice!
    But honestly, I've never seen one of these wear out. It is strange that yours no longer works.
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I bought one from Napa and it never worked "clicked" no matter how hard I pressed. Called Gates and they would replace and warranty the part. But, by the time paid to ship it back it really wasnt worth the $10 bucks I would save so I just bought another one.
    Got a new one and it works as advertised.
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Quote Originally Posted by M109Dreamer View Post
    Very strange. I'd have thought that Gates would just have you go back to Napa and exchange the faulty one for a good one. Napa usually stands behind what they sell as well.
    Mar 2011
    Jackson, MS
    They would have but it would of cost me that much in gas to take it back to Napa or mail it back to Gates. I had no issues in getting a new one just wasnt worth the $10 dollars versus the time it would of taken to drive back to Napa or mail it back to Gates.
    Nov 2011
    Raleigh Illinois
    Default belt tension values
    Thanks BajaRon, a most timely topic for me!! I am in the throes of my first tire change and belt tension adjustment on my new 2014 RT. Selling Dealer badly screwed up original belt adjustment, another dealer hammered an oem trailer hitch into place so tightly I had to use a scissors jack between rear tire and hitch, beating it with a deadblow hammer for 20 some minutes before trailer hitch finally came off. Belt tension was [160 on the Crickit] nowhere near the values on your chart and had lots of belt vibration starting at 71mph on oem speedo. Now I have some real numbers to aim for.
    Thanks Andy
    Quote Originally Posted by Andy Cserny View Post
    Thanks Andy
    I've gotten several feedbacks from owners saying that the numbers I've posted are exactly right. They find that the range I've posted is exactly what they get on their properly adjusted belt. I hope this helps a lot of people as incorrect belt adjustment can cause issues.
    Too tight will destroy bearings.
    Too loose will give you vibration issues.
    Hi Ron,
    I notice that your readings are all taken with the wheel elevated.
    Does this mean I must assume that no reading taken while the wheel is on the ground will be useful?
    South Okanagan, BC, Canada
    Bob, I think if not mistaken that Ron addresses that in the 3rd paragraph of his post no. 8.
    Gary
    I had missed that point on the first pass... Thanks!
    Mar 2013
    Glasgow, KY
    Default Smoothspyder Tensioner?
    Ron,
    How are these values affected by having a Smoothspyder Belt Tensioner on my 2012 RT-S SE5?
    Mike in KY
    Quote Originally Posted by metman View Post
    Ron,
    Mike in KY
    I can't give you a definite answer. But I highly recommend disengaging the tensioner before taking a reading. I would assume the tensioner would raise the reading. Though by how much, I am not sure. It may not be by all that much.
    Take a reading both ways. If the reading with the tensioner DISENGAGED is within specs, then the reading with the tensioner ENGAGED will also be within specs. In this case, simply note the reading with the tensioner engaged as that is what your 'Normal'. That way you won't have to mess with the tensioner every time you want to take a reading. As I said, the tensioner may not make much if any difference.
    Feb 2015
    United States
    I bought a Krikit II on line and it clicked 6 or 7 times and will no longer click. So I guess a few are bad like everything else. I ordered a replacement.
