Results 1 to 9 of 9
    Fishkill, NY
    Default Help!! Clutch lever has no Tension?
    hi all, start my spyder up today, and clutch lever has no tension at all!! I'm so afraid to put it in to gear so i didn't. any though before i call my dealer. Thanks.
    its a 2013 ST-S SM5 with about 550 miles on it, not even first oil change yet...
    Nov 2012
    North Las Vegas, NV
    Check the fluid in the reservoir. Could be low or needs to be bled.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Agree..!!
    You may have to bleed the system. If it is low on fluid you need to see why. Seems to have very low mileage to have lost pressure. Check for leaks at all points. If there are none it could be in the slave cylinder. Hope you find the probkem else take it to the dealer...
    Fishkill, NY
    Default thanks,
    yeb, the reservoir is empty, there are no leak spot on the floor! i'll let you guys know how its go.
    Oct 2007
    Johnson City TN
    My GS did this it puddled on the plastic. It was a o ring in the slave cylinder. $3 fix.
    Jun 2010
    Las Vegas
    Quote Originally Posted by one2doo View Post
    I had an RT that did the same thing. Nothing on the garage floor it was all on the plastic.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2014
    Fort Lauderdale FL
    Default had the same problem
    When my spyder was new had the same problem slave end was leaking internally dealer needed to rebuild. Guess there must of been some defective 2013 sts units
    Fishkill, NY
    Quote Originally Posted by moe113097 View Post
    Thanks, will call the dealer for appointment when all the freaking snow are gone...
    Bryant, Arkansas
    Quote Originally Posted by Bee Mera View Post
    Do it now while the snow is here and ride when the snow is gone.
    Cruzr Joe
