Results 1 to 25 of 49
Thread: F3 AUX LITES
    Apr 2011
    GREENVILLE, SC
    Default F3 AUX LITES
    TODAY I HAD MY F3-S FITTED WITH THE AUXILARY LIGHTS....
    to perform the installation, they take out the 'BLANK-OFF PLATES" and install the lights...
    once all the Tuperware is repositioned, the lights have a HUGE void around them...
    i asked the technician for the 'blank-off' plates, and when i got home, i got out my old trusty 2 1/2" hole saw, and cut out the center of the 'blank-off' plate, and reinstalled them back in their original position sans their centers...
    here's the results....
    NOTE to new F3 owners: ask to keep your 'blank offs' because you are NOT going to like what you see without them...
    Dan P
    Easley, SC
    SPYD3R
    Oct 2014
    Nice to see you got them as mine are on back order. Do they not fill in the hole when the round plastic plate is removed? Looking at your pictures it looks like the lights are not as big as the round holes for them.
    Default Nicely done..!!
    wonder why they would leave it wide open. Looks much better your way...congrats..!!
    Apr 2011
    GREENVILLE, SC
    Default NO
    Quote Originally Posted by Grandpaspeed View Post
    NO, the lights are only 2" in diameter.... when they remove the 'blank off'... the sides are left open around the new lense, and you can see all the junk on the insides.... keep those 'blank offs' and if you aren't the DIY type, bring them to me, and i'll open them up for you, and re-install them.... i openned the hole to 2.500" because these lights get really HOT, and i wanted a void around them for air flow so they wouldn't melt....
    For a $499.99 option, you'd think BRP would provide such an item....
    Dan P
    Oct 2014
    Quote Originally Posted by SPYD3R View Post
    Dan P
    Thanks so much for your feedback. How is the output and if you had to do it again would you use the BRP ones or look into an aftermarket light, maybe LED?
    Dec 2010
    Fountain Inn,SC
    Dan, you are always tinkering. Real nice job. It would seem to me that BRP don't think too make the extras look nicer/or finish the small details. Again you did a nice job.
    Sep 2014
    Los Angeles
    Curious if these are a pug in an where does the switch go and does all that come with the lights ?
    Another Day To Be My Kid's Dad [emoji379]
    Apr 2011
    GREENVILLE, SC
    Default ALL
    Quote Originally Posted by GunDoctor View Post
    Doc;
    on either side of the ignition switch are two blank buttons... the left button hole is for a switch for the 'heated grips' and the right button hole is for the AUX LIGHTS... the switches for each come with these items when ordered... mine now looks 'loop-sided' so it looks like i'll have to ask ma'ma for the 'heated grips' for my B'day present.... ha ha ha ha....
    Dan
    Oct 2007
    Johnson City TN
    Thanks for info I have lights on order. Will be doing install myself.
    Henderson, NV
    IMO, for the price BRP charges they should fit with no gaps.
    You should submit an invoice to BRP for your time (don't forget to round up) to rectify their design issue.
    Apr 2011
    GREENVILLE, SC
    Default INVOICE?
    Quote Originally Posted by MMMII View Post
    Triple M2...
    i don't need no stinking invoice... if BRP wants to take 'short-cuts' that's ok with me, i'd have nut'n 2 do during 'NO RIDING TIME' pal if they were perfect.... what they should do is consult me b4 they release a product... i have 40 yrs experience in jet engine design management...
    2moro i'll take my F3 apart, and take another picture of how she looks in BRP dress, and i'll post that... watch for it...
    Dan P
    SPYD3R
    Nov 2014
    Temecula, California
    Couldn't the techs just drill a hole like you did without removing the plastic altogether???
    Think it would have been easier to due that in the first place.
    Yours definitely looks better. Good thing you're so handy.
    Sometimes I wonder what their designers are thinking, why do they seem to half a** everything!!!!
    Lots of money to put out just to have to come home and redo it the right way.
    2015 F3S , Black & White
    Apr 2009
    New Mexico
    Default I ordered the Aux Lights . . .
    . . . . but I was kind of ambivalent about them. Never had them on any of my other Spyders - got by without them.
    For some reason, I was thinking that they were LED, but after ordering them I found they were just like the old ones. So seeing what they look like, not being LED and what you went through, I am probably going to cancel the order and use the money on something else I would use a little more.
    Tom
    Default NOT TO HI-JACK BUT IT'S RELATED
    To Tom in NM , there are a ton of LED options out there in E-Bay land that will work.....Right now I am looking at putting some along side my headlights on my 2014 RT ( basic) right now they are fake ....the S and LTD have a low power led in there , but it really only a decoration......The LED I'm going to use is 2500 lumen's......I was worried about the heat issue also , so I hooked up the light on the workbench and left it on for 5 hrs....the lens and the metal housing were barely warm to the touch so I'm not worried ............I will have to trim 1/32 inch from the OEM headlight basket to get my LED in there, but other than hooking up some wires and a switch that's about it .......The two I bought would work excellent in the F-3 where Dan has his , they cost me $ 25.00 for the pair ,delivered.................Mike
    Very nice light mod.
    Very Active Member zuni's Avatar
    Mar 2014
    JAX FL
    Wow I am surprised that the replacement heat shields did not come as part of the upgrade kit for the price they are charging. I am in the process of installing my own projector fogs for about 20% of the BRP price. The wiring and relay are already in place so I am just waiting for the factory switch. I was told that the OEM lights wouldn't be available until later in the month. I was going to do the same thing you did with cutting the plastic plug and went online to see what a replacement would cost me if I didn't like the way it turned out. While looking at the parts diagram I found that their is a part made for that. the part number is 705008995 and 705008996 and they were less than $9 each.
    CJ JAX
    Active Member RPM's Avatar
    Jan 2015
    Folsom, CA
    Nice job! My lights just came in. Kind of wish I hadn't ordered them now. I hope I can get the dealership to do what you did. Thanks for the idea!
    2022 Spyder RT SEA-TO-SKY Mystery Blue... (bought new May 2023, a work in progress...)
    2015 Can-Am Red F3-S, SE6
    CalSci shield, Elka stage 5 rear shock, stage 4 front shocks, Akrapovic silencer, BajaRon Bar, Roadster Renovations vibration dampener, Tricled LED headlights and auxiliary lights, driver floorboard, driver and passenger backrests, Tricled Safety Led package, Shad BRP/SH36 side cases, Baker built luggage rack, Tricled Rear run/brake/turn signal led, Tricled LED piezo brake bullet strobe, JDM Astar LED bulbs for rear and front lights, Airhawk seat pad, USB power outlet
    Mar 2013
    St Cloud FL
    Default Aux light heat shields Question
    I am wondering if these heat shields should/need to be installed at the same time to help deflect/keep heat from building up inside the console area?? Just a question
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Default they make a huge difference
    I actually don't mind the big blank area around the lights with the "normal" install. The lights themselves make a HUGE difference when driving at night. Anyone who's seen the difference between having them on and not has been impressed.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Oct 2010
    Somewhere out there...
    I'm working on getting some DRL's in the a-arms but in a different lumen and control.
    Sep 2014
    Los Angeles
    Doc;
    Dan
    Thanks, great info.
    Mar 2013
    Clarksville TN
    Could you share a link to those LEDs? Thanks.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2024 Corvette ERAY
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    Default Not LEDs????
    In this day and age, BRP should be ashamed of themselves for not making the driving lights LEDs.
    Very Active Member Mike,P's Avatar
    Sep 2011
    Wales , Michigan
    I will be using LEDs / Lots of options out there.... More light less money 😎
    Apr 2011
    GREENVILLE, SC
    Default OK, DUDES & DUDETTES
    HERE ARE SOME 'BEFORE & AFTER' PIX......
    I PULLED MY TUPERWARE OFF MY F3-S TODAY, REMOVE MY ALTERED BLANK-OFF AND TOOK PIX SO Y'ALL CAN SEE THE DIFFERENCE.....
    BEFORE PIX... THIS IS WHAT YOURS WILL LOOK LIKE AFTER INSTALLATION OF THE AUX LIGHTS... LOOK CLOSELY, YOU CAN SEE WIRING AND TAGS... NOT A GO SET-UP... BRP SHOULD PROVIDE THE 'BLANK OFF' WITH A 'KNOCK-OUT' SECTION FOR THE TECHS TO REMOVE WHEN THESE LIGHTS ARE PURCHASED... SHAME ON YOU BRP.....
    "PAS UN BON DESIGN BRP"...
    MY ALTERATION...
    AFTER PIC... THIS IS WHAT MINE LOOKS LIKE AFTER I ALTERED THE 'BLANK OFF' PLATES THAT COME WITH THE F3'S....
    SOMEBODY MENTIONED "HEAT SHIELD"... NO SUCH THING, NEVER SAID THAT... WHAT I SAID WAS:
    "THESE THINGS GET HOT, SO I DID A 2.5" DIA. HOLE TO ALLOW AIR TO FLOW AROUND THE LIGHTS BECAUSE I DIDN'T WANT THE PLASTIC TO WRAP"...
    I WAS AT MY DEALER TODAY, AND SHOWED THEM WHAT I DID, AND THEY ARE LOOKING INTO DOING THIS FOR ALL CUSTOMERS THAT PURCHASE THESE AUXILLARY LIGHTS AT THEIR STORE...
    DAN P
    EASLEY, SC
    SPYD3R
