Rough Idle-Surging
Anyone in the forum have this same issue. I researched it the best I could but couldn't find any info on a fix.
Service Bulletin Number: 10550361. It is fully detailed below...
Vehicle: 2013 Can-Am Spyder St
NHTSA: Action Number: 1020015 Service Bulletin Number: 10550361
Component: Fuel/Propulsion System/Engine
Summary: The Spyder ST-S has started idling rough....RPM's will race between 1000 and 2000 in a nano second and the bike will surge forward. It started happening after about 200 hundred are so miles, subtle at first, and has gotten more noticeable over the weeks. Now it has a rough idle all the time and is becoming a safety hazard while at stop lights and in traffic. When I have started the bike all this week there has been a loud beep as well. I don't know if that was always there or not. At stop lights the bike will surge to 1800-2000 and bike will lurch forward. The bike also clatters and shakes at cold take-off and reverse when the gas is applied.
If anybody else has had this issue could you reply here and tell us what the fix was.
![Quote](images/misc/quote_icon.png) Originally Posted by Spyder Hawk
My wife's 2012 RT (with the same 990 engine) had a surging problem that was not quite a serious as your's sounds. It began surging at highway speeds and later was accompanied by loss of steering assist on some turns.
Turned out to be a weak battery. Both the DPS and throttle body take a tremendous amount of power out of the system and if the battery is at all weak, it can't maintain the power needed to operate both items as well as control all the other electronics on the Spyder.
Wouldn't hurt to have a dealer check the draw on the electrical system.
Penny and Rick have owned many motorcycles starting in 1974 with Hondas, then to Suzukis, Gold Wings and ultimately Spyders.
74 Honda 360T (pair); 78 Suzuki GS 1000 (pair); 82 Honda Aspencade; 84 Honda 400; 87 Yamaha 1100; 99 Honda Valkyrie; 01 Suzuki Burgman(triked); 02 Honda GL 1800(triked); 10 Spyder RTSE; 11 Spyder RTSM; 12 Spyder RTSL (pair); 20 Spyder RTL (current)
![](signaturepics/sigpic38088_3.gif)
Okay, I'm confused. Was the service bulletin not the fix?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
The service bulletin was for the Safety Recall for melted brake master cylinder. I have no idea what this has to do with the problem you are having.
Surging and rough idle is likely from a vacuum leak or faulty purge valve. Take it back to the dealer and let them hunt down the problem.
Shutter and shake at take off when cold is a different problem again. BRP used different clutch materials for 2013 to improve performance and longevity. The side effect is this shutter issue when cold. This is considered normal and should go away after driving a short distance, 1 mile or less.
![](signaturepics/sigpic7798_4.gif)
![Quote](images/misc/quote_icon.png) Originally Posted by billybovine
Agreed. On my 2013 RT I had the rough idling, it would idle rough then race up to 3000 rpm then shut down. I had a faulty purge valve. To the OP if it is found that you have a faulty purge valve you need to insist that they replace the evap canister. Unless you like gas fumes and the risk of fire.
2010 RT- 622
PATIENCE IS KEY
My STL had a stalling issue sometimes when at lights plus the shaking and shuddering at take off when cold.
the dealer and BRP started by rebuilding the clutch as they thought the clutch shuddering might be causing the stalling that didn't fix it so they did the purge valve and spark plugs & wires that didn't fix it so they replaced throttle body and now she runs like a top the motor has a ton of power and the throttle is super responsive and no more stalling!! it has a small amount of shuddering at take off when cold I typically try to let it warm up for a few minutes and that helps.
Good luck I hope they figure out what your issue is just be patient as these are very complicated machines and it can take a while to sort through and find out what is wrong I ended up just leaving my STL at the dealer for about 6 weeks about this time last year as the dealer and BRP worked together to find the issue and it saved me a bunch of trips and frustration as the dealer wanted to get it fixed as bad as I did and that way it was ready to go by spring
I sure hope it doesn't take 6 weeks.... I live in Florida and I Really need to get my Knees in the Breeze!!
thanks
Kubie
There you go...!!
don't dawddle around get it to the dealer to sort it out...spring is out there somewhere..!!
GOS member (Girls On Spyders)
Other Possibility
![Quote](images/misc/quote_icon.png) Originally Posted by SpyderAnn01
Ann .... didn't flamingobabe have a surging problem shortly before her O2 sensor blew out? I remember reading, very early in her troubles, that the bike had started surging and then shortly after, maybe, one of the O2 sensors was blown completely out of the exhaust pipe.
Just another possibility .... from another Ann (with no 'E')
__________________________________________________ _
2016 RT Limited -- "Jubilee" (as in Cherries)
Guardian Bell (gift from spyderowboy)
ISCI Dual Flag Mount Tall Poles
Lamonster Bottle Holder and Spyder Cuff
Spyderpops Missing Belt Guard
Spyderpops Bumpskid
Spyderpops Rear Run / Brake / Turn LEDs
Spyderpops Mirror LEDs
Custom Dynamics HMT Brake
Spyderpops Keep Out The Trash (KOTT) Grills
Don't Eat Mud / mudflap
__________________________________________________ __
![](signaturepics/sigpic11148_10.gif)
Thanks everyone, all good ideas. I got the bike used if you can call it that, only 3 miles on it. The guy that bought it in 2013 never started it or drove it so it never had any of the 2013 bugs fixed. With what mine is doing I lean towards a bad throttle body or ECM. I don't think it has enough miles on it to be much else. I'm also in California so there has been no harsh weather to assault it. BRP says they are going to take care of the air flow panels and that the warranty and extended warranty should be transferable. Its been over a week now and I still can't get the dealership to transfer the ownership in the BRP Database. They won't do anything until that is done so I am stuck now. I can't even make an appointment to get it looked at. Very frustrating to spend that much cash to get something that needs a bunch of repairs out of the gate.
Spyder Hawk here is what I found out today
I Talked to my service guy at about 5:30pm. they have been on the phone with BRP Tech all day trying different things! They think they have it fixed. The New ECM was programed Wrong so they had to go through and Reprogram it, and I think they changed the Throttle body too... He told me they just came back from the test ryde and said it ran fine, but they where going to run it again in the morning and make sure before I can pick it up.... So hopefully I will be back on my Ryde with my Knees in the Breeze tomorrow... When I find out all they did tomorrow I will post... Hope you get yours figured out... it really is the best Ryde I have ever had.
Best of luck!!!
Kubie
...in the pink (Girls On Spyders)
Spyder_Cowgirl you are correct.......The original post I have highlighted......that is direct from NHTSA complaints that I posted....that is what my bike was doing...BRP and 3 different dealers could not find a fix.....Mark found one of the spark plug wires had a crack in it....all dry rot.....Mark (husband) ordered new plugs and wires from Baja Ron (better plugs and wires) and problem fixed.....as far as the shuttering and shaking...BRP replaced the entire clutch system...some plates were warped....it is 80% better...only at cold start and always in reverse......need more info ask me
I witnessed the transfer of warranty to new owner at a dealership a couple years ago and it took less than 5 minutes. It sounds like the safety recall was not done. If true the dealer should do it no matter who the registered owner is in BRPs system. That is because there is no cost to you and it is a RECALL.
