Wife and I have been riding our 2013 RT in Florida for two years with no heat or any other problem. If it was a design flaw I would think many more riders would be effected.
We are a LONG way past IF. Just because you have not noticed the problem does not mean it does not exist. BRP and the NHTSA have investigated and determined there IS A DESIGN FLAW. If you don't want the fix, its your choice but there is no longer a discussion of IF there is a flaw with the 2013 RTs.
Well said!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
As of 9:50 am Eastern time, the recall has not been posted on the NHTSA site.
Looks like pre-2013's we will continue to have to deal with the gas stink. It is well documented!
I can tell you what happens or at least happened to me.
Got my 2011 and had no gas stink problem.
Then the first summer I noticed boiling gas and stink on some hot days over 90F especially if I got stuck in traffic.
I do ride mine every day 64 miles round trip for my commute to work.
First time this happened it went away until the next time a hot day and traffic.
After a few times of this happening, now every time I ride it no matter what the temps of the day are and even if the gas tank is not boiling, I have gas stink when I park it REALLY BAD!
Bottom line what happens is after a few times of boiling gas the Evap canister gets saturated and cannot do it's job anymore.
So to fix it, you have to go to the dealer and get the purge valve checked/replaced if needed, and the Evap canister replaced UNDER WARRANTY!
That will fix you until the next few hot days and boiling gas happens and the Evap canister gets saturated again!
Then once your warranty runs out, you can argue the problem with your dealer about this is a constant problem and even though your warranty runs out, BRP needs to replace it free. Hopefully BRP will continue to do this after the warranty runs out but I doubt it. When that happens, time to do a canisterectomy. Oh which is illegal in some states to do (like Ca.).
So it appears us pre-2013 owner are stuck dealing with this under warranty, and then fighting it when out of warranty.
Where have you been hiding? The 2013 STs were the FIRST ones to have this issue addressed...
Did you forget about the new bodywork, and ECM re-flashes?
But did they really FIX the issue?
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
So, I directly and respectfully asked @BRPcare twice in this thread about the gas fume issue and my 2012. Sadly, it looks like BRP is going to ignore my question and safety concern.
The silence does say a couple things. First, that BRP and the NHTSA are not looking into this gasoline fume issue. Secondly, by not even acknowledging the question I (and others) posed, it lends credence to what others have said - that they do not care. It is unfortunate that it may take a house fire, injury or death before the NHTSA and BRP acknowledge the problem and recommend a solution.
For those that will have resolution through the latest recall, and that thank BRP for 'stepping up', I do not believe it to be willingly or for altruistic reasons. They acted more so because their hand was forced with the threat of fines and penalties by the Canadian and US governments. I tried to keep an open mind but admit that I am disappointed and jaded now...
Hi Steve,you never answered my last three emails about my not being able to ride my bike because of the heat on my feet and the fact that my wife would not ride with me because of the heat/safety issues.
Because of that I traded the furnace in for the F3 and took a $6000.00 loss not to mention the money I spent to get it to the point I could ride it .
Will the people who have lost time and money be compensated by BRP?
Gene T
Ok that is never going to happen. Second you must have some faith. The F3 has barely hit the streets, its certainly not been hot enough for anyone to report heat issues on it yet and who knows what other problems it could have. I hope there is no issues but after being screwed by the last one im surprised you were willing to take that kind of hit for another one. I do think its ridiculous not to address this problem will all the years/models
I just recently got my 2008 and have been noticing the gas smell when i return from a ride. At first i thought i was just imagining it but its definitely there, it has had all its recalls done but these posts have me concerned about riding it in the summer now as it can get pretty hot here. I have not had any heat issues so far with this but i have not ridden in heat yet. i almost burned my leg off on my brothers 2012 RT so i know what the heat issue is. I can tell you where this whole problem stems from.... Building and testing these models in Quebec where the temp never rises above 80, if they are lucky!
They should have sent one down to AZ or someplace for a year to be tested, if they had they would have noticed the fact you can get your damn leg burned off and the gas smell you would have to imagine. Well i hope this fix at least helps out the 13 guys who seem to have been the worst off.
I am at a loss for words on the news that there is going to be a fix for the 2013 rt heat problem. Yes, We did own a 2013rts and did have all the problems that have been stated. My 13 did have the heat dissapation kit put on it as a try to fix the problem. It did not fix all the problems. After running the number of adding a new intake system and removing the Cat. along with the 3000 mile service we decided to trade it in. We were going to wait on the 2015's ,but with not that much differance between the 14 and the 15. We choose the 2014RTS instead. After taking a beating on the trade and throwing more money at it. We are very happy with our 2014RTS. Smoother, Quieter, and better Gas mileage.
For those of you who have stuck it out I hope the this is the fix to correct the problems.
For those of us that traded. I will always wonder if there was no heat problem. What would have been my trade-in really worth?????????
I have not been hiding! I have had the body panels replaced and ECM re-flashes done with hopes it would fix it. Sad to say it didn't! I refuse to spend more money on a new air cleaner and a cat delete to try again to make the heat problems go away when BRP should fix it. My wife won't even get on it anymore because of the heat problems and gas smell! Tried to trade it in on a F3 only to find out that in 9 months the value decreased 50% which made us upside down on it. So now we have a garage ornament!
I have a 2008 which I purchased new. I used to get the gas smell; but, not all the time. BRP sent out replacement gas caps from model year 2008 to I don't know. Since the gas cap was replaced I've had no more gas smell. Of course, maybe not overfilling the gas tank causing spill over into the canister may have also stopped the problem, at least for me.
The only serious heat problem on my 2008 was almost burning my hand when touching the 'Y' panel (just ahead of the seat). On the 2008 and 2009 GS models, some Spyders had 'Y' gaskets that failed early, and that caused the 'Y' panel to heat up. As far as the heat on my right foot (in hot weather), it's bearable, and not a real issue to me.
[QUOTE=Raknid;937263]So, I directly and respectfully asked @BRPcare twice in this thread about the gas fume issue and my 2012. Sadly, it looks like BRP is going to ignore my question and safety concern.
/QUOTE]
They started this thread to address the problems with the 2013 models.
Well; you've got yourself a $20,000 or so dollar paper weight, and a Better-Half who won't be caught dead on it...
...Why WOULDN'T you want to fix it?
Sorry... This is about the only conclusion that I can find.
I guess that I'm just not having one of my best days right now...
We've got somebody with an ST complaining in a thread started about a fix for RTs...
...And we've got a 2012 RT owner wanting answers in a thread started about 2013 models...
I'm just confused...
By the way; it's "Bob"...
Nothing to prove to anyone and no need to feel liked.....I just call it as it is....and a lot of people need thicker skin.....especially on the forums.
There's a LOT of whining that goes on here....much more than most other forums.
Anyway-
/QUOTE]
Yes... but we were all encouraged to contact the NHSTA and log issues, regardless of year, as all heat and fire concerns were being looked at. I even phoned the agency and they requested all years. I am sorry mine did not fit in the box... and happy that you are not affected.... but I still have real issue, Bob.
Oh; I believe that your bike has an issue with fumes.
But why?
Is your evaporative canister getting raw fuel in it?
do you have a problem with boiling fuel?
Did you overfill the tank?
There ARE things that can be done to solve the problem...
I spoke at length with the NHTSA and they were definitely looking at gas fumes on all model years.
2010 RT- 622
A little harsh don't ya think Bob. These are real problems. Try to remember what it was like prior to your 2014.
Jack
2015 BMW R1200R LC
