Results 1 to 16 of 16
    Mar 2014
    Someren, the Netherlands
    Default Ram mount on a rs
    I want to install a gps on my Spyder rs . What kind of ram mount can i use?
    Very Active Member PistonBlown's Avatar
    Jan 2013
    Christchurch, New Zealand
    Quote Originally Posted by Dutch Spyder View Post
    I use their glare screen clamp one which I clamp on the side of my screen (Part No. RAM-B-177-202U). Mine came with a diamond mount instead of the round one but I can't find that on their site.
    The bolts that came with it were plastic so I was a bit worried about it not holding but it's been fine - though it's only done 3k so far. I do have a lanyard just in case:-)
    Reason I went for this is it positioned my phone just to the right of the rev counter and quite high which I found worked best for me. I did look at the bar mounts but that felt cluttered.
    Just to mention that the one they do that fits the RT wouldn't work on an RS.
    I also looked at fitting permanent one around the clocks somewhere. Couldn't find a flat surface that was strong enough that gave me the right positioning but I'm sure some one has found somewhere good.
    Very Active Member mastertek2000's Avatar
    Mar 2012
    E Freetown MA
    i think i have one left over when i sold my RS let me look if so i will send it to you free
    MOgang Member
    Mar 2012
    Cuba, MO
    Default Ram mount
    Look on Amazon for the Atv/utv mounts. They are good if you want the mount on the handlebars.
    Mar 2014
    Quote Originally Posted by mastertek2000 View Post
    You know that I live in Europe? (the Netherlands)
    Mar 2012
    E Freetown MA
    did not see that sorry
    Mar 2014
    Active Member Spyda98's Avatar
    Dec 2014
    Default Best solution for me was...
    I have tried many RAM mounts for the '12 RS-S and the best one for me was the RAM-B-108BU.
    I purchased it from amazon for around $18 and I use X-grip to hold the iPhone 6 plus with Otterbox case while riding.
    Default Here's what I did..!!
    regular handle bar mount..toss the "u" clamp and bottom plate and bolt it on...20130228_115823.jpg 20140316_132913_resized.jpg ran a power cord to it and works great...
    Nov 2014
    TriCities, WA
    My solution, with the X-grip you can swap things around. I also made a flat smooth 2.5x5x3/8" board, stick it in the X-grip and you can stick a suction cup on it if need be.
    Aug 2013
    Ontario, Canada
    When I installed risers, I left about an inch and a half of the old bars on each end to fasten ram mount U bolt/ball attachments to the old bar ends.
    Nov 2014
    TriCities, WA
    Quote Originally Posted by xinu View Post
    Thanks for this timely post, I just got mine and am ready to put them on, what a smart idea!!!!!
    Jan 2015
    Outside L.A.
    Id like to offer an alternative idea, its slow at work today Do you need to see the screen that bad? i think they look hideous on the bars and since everyone on the planet has GPS on their phones for free, just get a bluetooth helmet and the girl will feed the directions right into your ear. Mine has the drop down sun visor as well as built in bluetooth and was less than a GPS never mind the mount lol
    Mar 2014
    Default made a choice
    Finally installed my ram and gps.
    Jan 2013
    Ziet er goed uit.
    Rit Gratis,
    Jos
    (Hope that's right, most of my Dutch was limited to "Gelieve een ander La Trappe Bier" or something like that:-))
    Oct 2013
    rome new york
    Quote Originally Posted by PistonBlown View Post
    Ziet er goed uit.
    Rit Gratis,
    Jos
